  1. Jan 30, 2022 at 9:28 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    The heavy 150? With 7 lug wheels, or maybe it was a 250 with the 150 body?
  2. Jan 30, 2022 at 9:33 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    yea, i took grandmas 3v to the shop for plugs. But they didnt have any trouble, so it was cheap. Ive never had trouble with the 2v 6.8 or 4.6.
    i’ve got a wantin’ for a short stroke v10. Preferably with ?144? Degree firing.
  3. Jan 30, 2022 at 9:49 AM
    daveeasa
    I wish I still had the sticker from my ‘97 F150. It was a fun truck. Wrong choice given my living situation as it evolved but kind of fun.
    Having the extra back door only on the passenger side was interesting. I could see the logic of loading from the curb and the extra cab rigidity for the driver. But it also made the space behind the driver seat a bit more of a pocket that was hard to access.
  4. Jan 30, 2022 at 9:49 AM
    5.4L. He had to do a lot of work to it over the years.
  5. Jan 30, 2022 at 10:53 AM
    Casper421
    In the woods
    06 DC
    Got about 18” total.
    chrisb, bmf4069, NUDRAT[OP] and 6 others like this.
  6. Jan 30, 2022 at 11:54 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Got invited to a party tonight. Should be drank, and smoke with some old friends and new candidates.
    I might be giving 18" tonight, but I'd have to lick it and stick it 6 times, and donkey punch my way to 18" cumulatively.
    :rasta:
    chrisb, bmf4069, shifty` and 2 others like this.
  7. Jan 30, 2022 at 12:29 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Its not dumb if it works.
  8. Jan 30, 2022 at 1:45 PM
    I had to sanity check this today myself to make sure I'm not nuts. I don't get in the engine bay a lot these days and haven't on this truck a lot so it's not like I'm a master mechanic.
    I timed myself. It took me 8 minutes from start to finish with the belt install. Looks like there are two tricks here: 1) Pop off your intake, shift the air intake assembly back, then zip-tie the refrigerant hose out of the way. 2) How you start the routing is critical, it also helps if you use your long wrench/serpentine belt tool to hold a little tension on the tensioner. I had my skid plate off already, I guess that's important?
    I'll drop pics of this:
    This took me about 2 minutes to do and only wasted 1 zip tie, it left things pretty wide open to work on the belt. Five 10mm bolts total, including the 4.7 iForce cover if you have one.
    After this, I inserted my long wrench on the tensioner pulley. Lifted and popped belt off the 1st pulley below the intake, snaked the belt out, left the wrench sitting on the fan clutch with tension. Easy to do if you use a ratcheting wrench.
    Reinstall I followed this path, if memory serves. No need to futz around with shit. Just start by inserting the belt from pass side to driver side and wrap around the A/C pulley (1) and leave the excess above the power steering pulley as shown, for reasons. Get under the vehicle, pull the middle of the belt down to wrap it around the harmonic balancer (2) leaving the passenger side above the power steering pulley still. Take the slack and route the belt around the power steering and alternator pulley, (3) and (4). From this point, my wrench was already in place with tension, so all I had to do was lift that last section of belt (red arrow) from top to bottom of that upper pulley while lifting the wrench. Then just let the wrench fall back against the fan clutch and check if the belt is properly seated. Pic ... and I hope this helps?
    jmd0792, 805Tundra, 5N0W808 and 6 others like this.
  9. Jan 30, 2022 at 3:30 PM
    Mine is bigger than yours. lol
    chrisb and bmf4069 like this.
  10. Jan 30, 2022 at 3:32 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  11. Jan 30, 2022 at 3:38 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    No you can't. There is something oddly attractive about an empty bar in the morning.
    RUSTYNUTS likes this.
  12. Jan 30, 2022 at 3:42 PM
    I don't know how you find some of these but your memes crack me up.
    Tundra2[QUOTED] and FrenchToasty like this.
  13. Jan 30, 2022 at 5:05 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    chrisb, bmf4069 and NWPirate like this.
  14. Jan 30, 2022 at 5:05 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  15. Jan 30, 2022 at 5:36 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  16. Jan 30, 2022 at 5:49 PM
    I got confused. You said you checked for fuel and spark. Then ... "Still no spark". It's cool, I casually smoke crack, uh, I mean "don't proofread" sometimes too. ;) :rofl:
    (Actually, all jokes aside, I never, ever proofread worth a shit and have probably said some super confusing shit on here over my tenure)
    That makes three of us then. Because my boy and girl are the same. I legitimately think it's either some 'power in numbers' mentality, showing off to one another, or sibling rivalry of trying to outdo one another, or (D) all of the above.
    Normal for GA, you can thank ATL for that. A good portion of private drivers (hired drivers) drive black GM SUVs (i.e. luxury airport people movers, basically) and they fall under the limo category. You can confirm by looking for a small white sticker on the bumper with a red airplane outline on it.
    One of my ex g/f had a 240, that thing was fun as hell. Even as an auto!
  17. Jan 30, 2022 at 6:07 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I meant crank, but cold fingers and non-existent brain.
  18. Jan 30, 2022 at 6:39 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    bmf4069 and alb1k like this.
  19. Jan 30, 2022 at 7:03 PM
  20. Jan 30, 2022 at 8:48 PM
    alb1k
    Left Coast
    It's good
    That cat has a super fat face. It's really round.
    Tundra2[QUOTED] likes this.
  21. Jan 30, 2022 at 9:07 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    shifty` and chrisb like this.
  22. Jan 30, 2022 at 9:09 PM
    alb1k
    Left Coast
    It's good
  23. Jan 30, 2022 at 9:11 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yeeeeee
    alb1k[QUOTED] likes this.
  24. Jan 30, 2022 at 9:35 PM
    alb1k
    Left Coast
    It's good
    I think I'm going to test a new browsing approach here. Rather than read thread titles on the left, I'll try looking at who posted/responded on the right - I definitely know who I want to hear from. I'm sure I will fail my own trial, but...
    Tundra2 likes this.
  25. Jan 30, 2022 at 9:46 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    You're sick of my meme bull shit, eh?
    Jack McCarthy likes this.
  26. Jan 30, 2022 at 9:50 PM
    alb1k
    Left Coast
    It's good
    No, I love it. I realized I respond too much to random threads like Husky vs, WeatherTech.
    I have both so I'm waiting for a smirky response on that one :rofl:
  27. Jan 30, 2022 at 10:08 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Oh, yeah I stay out of them threads. I poke my head out once in a while but not too often.
  28. Jan 31, 2022 at 6:36 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    TWC is predicting 3-5" of snow on Wednesday and 8-12" on Thursday for my area.
    Who wants to place a friendly wager on what we'll actually get?
    I'm saying 4-6" total for the two days.
    Casper421 likes this.
  29. Jan 31, 2022 at 6:50 AM
    I'm aiming for 9-10" total.
    chrisb[QUOTED] likes this.
  30. Jan 31, 2022 at 7:00 AM
    Casper421
    In the woods
    06 DC
    What’s the wind gonna be like?
