3in lift wheel and tire combos
Discussion in '2nd Gen Tundras (2007-2013)' started by TundraCarter, Jan 27, 2022.
  1. Jan 27, 2022 at 7:14 AM
    TundraCarter
    TundraCarter [OP] New Member
    Curious what kind of wheel and tire combinations that you guys are running on your 3in lift, was planing on running 295/70 r18 KM3s on TRD pro wheels. Curious what you guys can fit and what will look good. Would love to see any wheel and tire combo you guys have just keep it around a 2-4in lift
  2. Jan 27, 2022 at 7:16 AM
    SAGE63
    San Diego County
    Check out the wheels and tires channel
    pyrite808 and toyofan87 like this.
  3. Jan 27, 2022 at 7:28 AM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    6112's top setting front, 5160's rear; 295 70 18's on stock TRD wheels; Cooper AT3 xlt's, only removed little front mud flap, and cut skid plate inside of front sway bar. Basically leveled to PRO level.
    Tundra805 likes this.
  4. Jan 27, 2022 at 7:30 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Same as @SAGE63 , research under the garage section, both wheels/tires and suspension.. Plenty of threads of members set-up and feedback.. Good luck.
  5. Jan 27, 2022 at 11:00 AM
    Landodnal
    Landodnal New Member
    2008 Toyota Tundra Limited Slate Grey 4WD
    2" Leveling Kit
    2008 Tundra Limited. 2 inch lift in front, 1 inch in rear. 1.5" Bora wheel spacers. SPC adjustable upper control arms. Running 275/65/20 Cooper Discoverer AT3 XLT's on factory '08 20" aluminum rims. Overall, these are 34.21” tall tires. If the caster is just right, the front tires don't rub on anything. But after my last alignment, I do get a little rubbing on the mud flap. Just takes a little cutting away of plastic to get rid of the rub.
    toyofan87 likes this.
  6. Jan 27, 2022 at 11:18 AM
    toyofan87
    Seth
    Gettysburg, Penna
    Another Slate..3/1.5 Coilovers Toytec, JBA's UCA, with 295/70/18s Falkens WP..sits pretty even...
    Landodnal likes this.
  7. Jan 27, 2022 at 12:24 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    Welcome and if you research your going to get a wide range of answers based on how much $$ you want to spend and how much work you want to do. I thought I only wanted 35’s but the more I look at trucks with 37’s wouldn’t mind doing that someday. Anyways here’s mine. Approx 3.5” in the front, 2” in the rear, Camburg UCA’s, 35x12.50 on 17” methods with 0 offset.
  8. Jan 27, 2022 at 1:28 PM
    COElkHunter
    COElkHunter New Member
    Jeremy
    2012 Silver Tundra TRD limited Crewmax 4x4
    3" OME lift w/ UCAs. ARE overland shell w/ ARE roof rack. 34" Falken Wildpeaks. ARB awning. Road shower. Wilco Offroad Hitchgate Solo High Clearance. LED lighting upgrades. Lockerdown console safe. Weathertech floormats. Duluth deluxe rear seat cover to go under the offroad approved car seats.... :P
    3" OME Coilovers w/ Dakkar leafs + AAL. 275/65/20 Falken Wildpeaks (Roughly 34") on factory 60 offset wheels. Using a 1.25" Spidertrax spacer. Bent the skid plate corners up and took off the mudguards, no rub. Bought my tires before I got the lift installed because I bought the truck with garbage tires. Would have gone straight to 35s once I realized how much room I had with the lift...
    Tundra805 and Landodnal like this.
  9. Jan 29, 2022 at 1:43 AM
    pyrite808
    pyrite808 Real TRD Pros are built not bought
    Anthony
    Mid Tennessee
    08 DBL Cab Pyrite
  10. Jan 29, 2022 at 7:17 PM
    TundraCarter
    From what I'm gathering, the consensus seems to be that a 35x12.5 is very possible on a 3in lift
