2003 tundra air flow disaster
Discussion in '1st Gen Tundras (2000-2006)' started by Surferrob, Jan 12, 2022.
  1. Jan 27, 2022 at 1:22 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    On my other 2000 V6 I had a problem with the the engine running rough at time. Mostly at idle. Acting like it would cut off. Took to a couple places and then to dealer. Sometimes it would run a little better if I just cleaned the MAF sensor. And if the throttle body was cleaned it would run great for a short while. But problem would come back. After 6 months of dealing with this. Finally just had to replace the whole throttle body. Finally solved the problem.
  2. Jan 27, 2022 at 2:22 PM
    This guy was also going into limp mode. I'm still convinced it was just his TPS causing the prob, not the throttle body assembly, but ... We'll never know.
    Still, OP may want to check this thread out, since his is going down a similar course: https://www.tundras.com/threads/bad-idle-accel-after-spark-plug-change.93321/
  3. Jan 27, 2022 at 7:13 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Where are you finding those crazy O2 sensor prices?
    shifty` likes this.
  4. Jan 28, 2022 at 12:23 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Depends on year. Early model trucks are cheaper standard 1v sweep type o2 sensors, later model (05/06?) are the more accurate 5v air fuel ratio sensors iirc.
  5. Jan 28, 2022 at 3:17 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    $47 after shipping at least to my area.
    They're cheaper at other places. This has always been my issue with RA by the time you pay shipping, sometimes from multiple sites, it's not even worth the savings per part.
  6. Jan 28, 2022 at 6:06 AM
    Even when applying the Tundras.com forum 5% off coupon?
    I dunno, I was pretty stoked. $19 to ship a 25lb alternator and serpentine belt to me. I was expecting much worse.
  7. Jan 28, 2022 at 7:12 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Yup. For instance that sensor, RA is 38.79+6.99 shipping+ 2.75 tax for me-1.79 discount= 46.47 Besos is 45.15 total, Wally World and Home Depot have them available for around that price also.
    Even your 130amp alt, Napa has right now for $168 shipped including the core of $36 (for the reman 130amp Denso)
  8. Jan 28, 2022 at 7:36 AM
    I hear you. It's not lost on me that I'm lucky enough I can to afford to pick and choose where my dollar goes without worrying whether I can keep the utilities on, so if the price difference in supporting a family owned US business like RA versus supporting a behemoth like scAmazon, HD or Wally is only 2.9% or $1.32 in this case, I know where my money is going. :D
    For the record though, I always price against NAPA, Advance Auto and Summit Racing when buying. For my Denso 130A (210-1065). Difference was mostly negligible, but RA was still cheaper once I factor in travel time, gas, and other stuff.
    Napa: $215.99 + 85.37 core
    RA: $206.79 + $79 core (NOTE: before 5% discount)
    Summit: $201.99 + $70 core (NOTE: I'd spend $20 in gas to pickup & return)
    To boot, NAPA didn't have any locally in-stock. Summit Racing lead time was 2 months and now is listed as 'lead time unavailable'. Rock Auto had confirmed stock in-hand.
  9. Jan 28, 2022 at 8:16 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    That's a fair point. This was just an observational point from my end, 1 part typically isn't a huge deal but when you start ordering multiple things from RA and they ding you 4 separate shipping charges it's hard to accept for me. This was all pre supply chain issues also so that's made a difference as well.
    shifty`[QUOTED] likes this.
  10. Jan 28, 2022 at 8:55 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Good to know. I just ran it off my 06 and assumed it was the same price.
    So, as much as I love my 06, here are the downsides
    • Upstream O2 sensors are more
    • SAIS
    • Steering rack is about double
    • Crazy brake master cylinder is made from solid unobtanium, stupid expensive and doesn't actually exist anyway
    • The cruise control is designed to keep the rpm's as high as possible without blowing up the engine, downshift at every pebble, hold that downshift until the downhill become so steep that the rear tires are off the ground and when first set will rev the engine to scare away little cars
    On the plus side, I can fit all my kids and use my factory steering wheel controls!
  11. Jan 28, 2022 at 9:25 AM
    Wait ... I thought this point was only true for trucks w/VSC? My '06 doesn't have the unobtanium MC. And I haven't had the same experience with cruise.
  12. Feb 5, 2022 at 2:04 PM
    Curious about this. I'm getting P0161 but it's saying bank 2 sensor 2. Two codes for the same issue?
  13. Feb 5, 2022 at 4:39 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    One refers to low voltage, the other a short. Two different failures for the same part.
