Yes or no
Discussion in 'Off-Topic Discussion' started by T-Rex266, Jun 3, 2017.
  1. Jun 3, 2017 at 9:27 PM
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    ColoradoTJ likes this.
  2. Jun 3, 2017 at 9:31 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Im going to guess.....Yes ?
  3. Jun 3, 2017 at 9:32 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Unless you are saying the "WHEELS are moving in the opposite direction
  4. Jun 3, 2017 at 9:32 PM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    No. It's not the wheels that need speed...it's wind and wings that need it
    Sas, Tundraplatinum, 15whtrd and 9 others like this.
  5. Jun 3, 2017 at 9:52 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    No.
    PR_02 likes this.
  6. Jun 3, 2017 at 9:52 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @Almaboy has it right, no matter how fast the wheels turn you're gonna need wing lift to take off
  7. Jun 3, 2017 at 9:58 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    c'mon man public school education with low 80's iq.....i gotta 50/50 on this....nope
  8. Jun 3, 2017 at 9:59 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Low 80s? That's twice mine
    JMB, 831Tun and zcarpenter92 like this.
  9. Jun 3, 2017 at 9:59 PM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    I agree with @Almaboy and @gosolo, a sufficient amount of air must be flowing across the wings to create enough lift to allow the plane to leave the ground. Final answer is No.
    PR_02 and Eclipsed & Floating like this.
  10. Jun 3, 2017 at 10:04 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Well, how could it? lol
  11. Jun 3, 2017 at 10:09 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  12. Jun 3, 2017 at 10:36 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Thrust...thats how
  13. Jun 3, 2017 at 10:49 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Editing my answer.....
    No if only going by the statement above of the conveyor moving and no verbiage of the plane doing any work.
    Yes if you think of the conveyor moving as just an obstacle. If the plane can turn its engines one and be forced forward with its thrust then the wheels can move at whatever speed they want. The plane will move forward and the plane will take off.
    Darth Tundra likes this.
  14. Jun 3, 2017 at 10:51 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Cmon Sean.....whats the answer :annoyed: :popcorn: :pccoffee:
  15. Jun 3, 2017 at 10:56 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    I just googled the answer.....the plane WILL TAKE OFF !!!
  16. Jun 3, 2017 at 10:57 PM
    csuviper
    Broomfield, CO
  17. Jun 4, 2017 at 12:50 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    YES. The plane cane take off. And if it's a United Airlines plane, they can take YOU off.:rofl:
  18. Jun 4, 2017 at 1:36 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Yes! Lol with a tundra!
  19. Jun 4, 2017 at 1:36 AM
    Y0TA PR0
    Rafael
    2017 TRD PRO
  20. Jun 4, 2017 at 1:50 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    @SR5TRDTUNDRA beat me to it. The wheels do not generate forward momentum for an aircraft, the engines do. So yes, the plane will still take off on a conveyor belt. It does mess with your mind a bit though. :confused:
    landphil, Darth Tundra and Y0TA PR0 like this.
  21. Jun 4, 2017 at 5:14 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    This is a physically impossible scenario. In order to match the airplane's wheel speed, friction has to work in the opposite direction as the engine thrust (this produces a proper rotational direction for the wheels). But this is static friction which has an upper limit which is not that large (think how easy it is to spin your wheels in your truck). So at some point, thrust becomes larger than friction and airplane will have net forward force. In other words, a conveyer belt that matches the airplane speed throughout its thrust is not physically possible.
    So does the airplane take off while it's not moving with respect to the ground? Probably not since thrust is still tiny.
    So does the airplane take off while it's at normal take-off thrust? Yes, since conveyer belt no longer becomes obstacle since wheels began to spin long time before this thrust is reached. So effectively it's slightly less efficient runway.
  22. Jun 4, 2017 at 5:57 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    If a man is completely alone in the woods, is he still wrong?
    Hint: ask his wife
  23. Jun 4, 2017 at 8:58 AM
    Darth Tundra
    Curt
    17 CM TRD Black
  24. Jun 4, 2017 at 10:09 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    :ohsnap:
    And delta can take you to jail!! (According to them :rolleyes::rolleyes::rolleyes::rolleyes:)
    NewImprovedRon likes this.
  25. Jun 4, 2017 at 10:38 AM
    chphilo
    Western PA
    But no one can match United's reputation. :D
  26. Jun 4, 2017 at 11:56 AM
    chphilo
    Western PA
    Concussion, two broken teeth, broken nose, all from running to his chair? How does that work? My imagination fails me at this point. (he was already boarded according to everything I read)
    Stores and restaurants are private too. But they can't bloody the customer in front of multiple cameras and expect not to be damaged in public relation.
    joonbug, NewImprovedRon and Law323 like this.
  27. Jun 4, 2017 at 12:04 PM
    I say no plane needs wind for lift i believe plane would be stationary
  28. Jun 4, 2017 at 12:06 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    After them paying for their ticket? Getting thrown off to make room for someone else when they overbooked the flight themselves?
    Also, didn't even reimburse or put the family on another flight. Screw that
    on top of that...threatening your family just because you won't give up the seat? Bullshit.
  29. Jun 4, 2017 at 1:00 PM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
  30. Jun 4, 2017 at 1:33 PM
    Ericsopa
    Ericsopa Old man and the sea
    HELL NO!!!
    But now if you could put the plane and the conveyor belt in a giant wind tunnel, that could move the air over it's airfoils at a sufficient speed to provide enough lift, then theoretically it could leave the ground and "fly" in place, if the engines were turning, providing sufficient thrust, and the conveyor belt going at a speed to match the airspeed.
    In fact, you wouldn't even need the conveyor belt in that scenario. The wheels needn't turn at all.
    Edit....BTW, what the Mythbusters video shows is completely different than the question posed by Sean266
    PR_02 likes this.
