Gun Pics..whatcha got?
Discussion in 'Guns & Hunting' started by R0CKETMAN, May 22, 2017.
  1. Jan 16, 2022 at 5:50 PM
    #3751
    Hurricane
    Hurricane Default: Aggressive
    NC
    2017 White 1794
    None
    Building an AR properly is far more complex than just piecing random parts together.
  2. Jan 16, 2022 at 5:57 PM
    #3752
    Azblue
    The Dirty T ( ^_^)_且
    You can shoot mine when we come and liberate you during the great invasion.
  3. Jan 16, 2022 at 6:12 PM
    #3753
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    Not today J Edgar............. Not Today ;-)
    D3VA and tech1208 like this.
  4. Jan 16, 2022 at 6:22 PM
    #3754
    Outbound
    Aaron
    Northern Alberta
    :yes: :fenforcer:
    ToyoMafia and Azblue[QUOTED] like this.
  5. Jan 16, 2022 at 9:05 PM
    #3755
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Yes. There are so many springs and pins to keep track of. :annoyed:
    :fistbump:
    ToyoMafia likes this.
  6. Jan 17, 2022 at 4:20 PM
    #3756
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Took a break from running the chainsaw to run my AK
  7. Jan 18, 2022 at 3:46 AM
    #3757
    Hurricane
    NC
    2017 White 1794
    None
    Also torques and staking that most people don’t know how to do or how to do properly. Some manufacturers don’t even do this to their guns, which can be kinda scary lol.
  8. Jan 18, 2022 at 7:44 AM
    #3758
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I'm a professional, I stake the castle nut to the buffer tube end plate :anonymous:
  9. Jan 18, 2022 at 9:03 AM
    #3759
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2000 4.7 AC SR5 4wd
    Midwest tall NV mount. About .625in taller than my LaRue LT660. Window in mount under optic for BUIS.
    Less neck strain, more heads-up, and no more fighting with muffs/stock. Changed zero to 65yd/200yd to accommodate additional sight over bore distance. 5.56 77gr 2730fps... from 40yds to 200yds trajectory deviation from line of sight is about an inch below/above.
    WVI, Okie3006, Prostar 190 and 4 others like this.
  10. Jan 21, 2022 at 7:13 PM
    #3760
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Walked into the gun store to get a stripped lower and walked out with a Diamondback DBX, which I had never heard of! Weighs 3lbs, shoots 5.7, piston operated, and about an inch wide. Time to finally buy some 5.7 ammo, which probably means a PS90 for the wife is in the near future.
  11. Jan 23, 2022 at 10:31 AM
    #3761
    Dwarven1
    Dwarven1 New Member
    Ross
    2018 SR5 w/TRD Off-Road.
    2018 SR5 - Bolo Mark XXb - Unit DNE of the Line. "Denny"
    Happy Feast of St. Browning Day!!
    Go shoot one of your Browning designed guns today!
    And if you're not fortunate enough to have one of the Saint of Orem's designs, that's OK. Go shoot something in .25ACP, .32ACP, .38 ACP, .380ACP, .45 ACP or .50BMG - all of which were designed by the master.
  12. Jan 23, 2022 at 10:35 AM
    #3762
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Amen!
  13. Jan 23, 2022 at 3:10 PM
    #3763
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    The great John Moses Browning and I share the same birthday! Took some of my favorites out with the boys and had a blast (pun intended)!
    Sighted in my AK finally. First 3 shot group from a rest at 25 yards with tula ammo. Not sure if this is good or bad for an AK but I'll take it!
  14. Jan 23, 2022 at 8:10 PM
    #3764
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    My 2nd one. Highly underrated IMO.
  15. Jan 23, 2022 at 8:52 PM
    #3765
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Any suggestions where would be good sources which ones to avoid…
    Looking for a 30 blackout full upper
  16. Jan 23, 2022 at 8:59 PM
    #3766
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    I have one with the same holster....however my clip falls out sometimes....not sure if I just need a new clip or a new magazine release
  17. Jan 23, 2022 at 9:06 PM
    #3767
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    BCM is really good without being crazy expensive. Not PSA or Del-Ton low prices, but not Daniel Defense high either...
    TNTundra16 and gosolo[QUOTED] like this.
  18. Jan 23, 2022 at 9:15 PM
    #3768
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    How are you liking the octane 9? I did the BOGO and got the hybrid 46 and octane 9. Both in NFA jail. For now.
  19. Jan 23, 2022 at 9:20 PM
    #3769
    alb1k
    Left Coast
    It's good
    Nice. That's a slick zero as well. I'm probably going to do something similar.
  20. Jan 24, 2022 at 2:32 AM
    #3770
    Kalash1794
    Kalash1794 New Member
    Murrayville
    2016 White OR 1794
    DD ditch lights Tyger blade Borla cat back OEM led headlights Excelon reference
    One that got away SGL31-94, the ban on Russian imports drove the prices up to where I could not resist selling, no regrets as I really prefer 7.62 AK’s.
  21. Jan 24, 2022 at 3:12 AM
    #3771
    RainMan_PNW
    Casey
    Clark County, WA
    I’m a big fan of Aero Precision. BCM makes some good stuff. Neither will break the bank and make good stuff.
  22. Jan 24, 2022 at 7:28 AM
    #3772
    snivilous
    SW UT
    I haven't shot any other 9mm suppressors, so my only comparison is my other suppressors. Not to be a downer, but it's honestly my least favorite :rofl: it doesn't seem to be particularly quiet, after watching some other videos the Dead Air seems to be noticeably better. To be fair it's the smallest can I have, and I'm not complaining that much but just should be noted. The two bigger issues, is mine didn't come with any tools or anything to tighten any of the caps, so everything is hand tight which is common practice in general, but soon after getting it I got a baffle strike on the end cap. Make sure you have the root threads tightened all the way down! And of course Silencerco doesn't sell the tip cap for the Octane 9, just every other can they sell. They'll replace it but then I have to send it back etc. etc. Turns out it's a common issue for the Octane 9 too. I'll put that on me, but retarded that I have no way to tighten the can and then it got loose immediately and enough to cause a strike on the end. My last complaint is it has a metric ass load of blowback. Again, this is only comparing to my 300 OSS which had all the fancy reduced blowback design or my 22 cans which have about double the volume and a smaller round, but just "normal" shooting quickly and my eyes get teary. Even on the MPX which is piston operated so cleaner in theory, there's a lot of gas coming back.
    Maybe all of this is normal for 9mm suppressors, I don't know. The baffles are just a bunch of cones, so this is actually what drove me to do a Form 1 for my next suppressor, since the Octane 9 isn't anything special internally which is also why I think the performance is kind of lackluster. It's a good can, I like it, it just seems pretty average. Excuse the long post.
  23. Jan 24, 2022 at 8:24 PM
    #3773
    TRDProLife
    St.Louis
    Well that's somewhat disappointing. I will still keep my hopes up. I don't think I can really complain since it was free
    snivilous[QUOTED] likes this.
  24. Jan 25, 2022 at 9:06 AM
    #3774
    snivilous
    SW UT
    It's not a bad can, and I suspect most suppressors have similar characteristics. My comparison size is only against much larger, and in the OSS case, much fancier options. So it's not really fair to the Octane and are relatively minor gripes. I think you'll like it; I slap it on every 9mm gun I have!
  25. Jan 25, 2022 at 3:31 PM
    #3775
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Some surplus parts installed. Romanian cleaning rod, Hungarian cleaning kit, Polish sling, and Croatian bho mag.
  26. Jan 25, 2022 at 3:34 PM
    #3776
    alb1k
    Left Coast
    It's good
    That is awesome.
    TNTundra16[QUOTED] likes this.
  27. Jan 25, 2022 at 3:35 PM
    #3777
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Dang...I feel like a need one of the furry Russian hats..
  28. Jan 25, 2022 at 3:36 PM
    #3778
    alb1k
    Left Coast
    It's good
    Ushanka
    RainMan_PNW likes this.
  29. Jan 25, 2022 at 5:52 PM
    #3779
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Thanks Erik :hattip:
    alb1k[QUOTED] likes this.
  30. Jan 25, 2022 at 5:53 PM
    #3780
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
