  1. Jan 10, 2022 at 11:48 AM
    02ducky13
    02ducky13 New Member
    Terry
    TSS 2017
    None
    Made some quick changes to the front end and got rid of the chrome... now looking for hood bulge replacement.
  2. Jan 10, 2022 at 11:54 AM
    Taco-Spike
    Two Trucks
    20GR8 Super likes this.
  3. Jan 10, 2022 at 1:21 PM
    truckguy84
    truckguy84 New Member
    2011 Black Tundra SR5 TRD
    Gave the Truck a rare winter wash.
  4. Jan 10, 2022 at 2:48 PM
    Mr Zanderson
    Mr Zanderson New Member
    Alexander
    Knoxville, TN
    2013 Toyota Tundra Crewmax 4x4
    Installed a 2020 Toyota Sequoia TRD Pro grill on my 2013 Tundra
  5. Jan 10, 2022 at 8:01 PM
    02ducky13
    Terry
    TSS 2017
    None
  6. Jan 10, 2022 at 10:51 PM
    Peeeheeuuu
    Peeeheeuuu New Member
    Peter
    Elk Grove, CA
    08 Tundra CM 4x4. 21 Sequoia SR5 4wd
    Bought another 2nd gen. (Wifey's new ride)
    It's a 21 sr5 4x4, already have some goodies on the way
  7. Jan 11, 2022 at 4:32 PM
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    BDS 7 w/ Fox 2.5 OME Dakar leaf pack CB +2 shackles 18x9 Method 308 +18mm 37x12.5 Toyo AT3 TRD intake/exhaust Infinity Kappa w/ Pioneer HU
    Poly bushing swap - LCAs and steering rack, with LBJs. Drives firmer, but good for a lifted truck and closer to new/stock. OEM rubber was toast.
    Had to drop the bracket lift to get to the steering rack, which required disassembling the entire front end, that was fun. A ton of work alone, but well worth it.
    Final project - repainting hood and roof. AZ sun baked the clear coat off.
    Then I'm planning on selling... unless I can convince myself otherwise.
  8. Jan 11, 2022 at 4:51 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Temporarily mounted one of the platform on the canopy. Temporarily because I will transfer it to the cab after I get the Backbone mounted this week and I didn't want to haul it in the bed. I'll mount the other one on the canopy and add the rail kits next time I go down off the mountain. I also put new struts on the canopy glass (now I don't have to use a prop rod) and lubricated all the door hinges, handles, and latches.
  9. Jan 11, 2022 at 11:44 PM
    Qwe123
    Qwe123 New Member
    Los Angeles
  10. Jan 12, 2022 at 1:41 PM
    JCtheOtherOne
    JCtheOtherOne New Member
    Jack
    Outside of Philly
    2011 White Tundra TRD- Philly
    Added MOLLE storage to the DC folding chair back.
  11. Jan 13, 2022 at 11:32 AM
    sharkmango
    sharkmango New Member
    2014 Tundra TRD 4x4 White
    This right here is a great idea, even on the models where the seats fold up from the ground. Thank you for the paradigm shift!
  12. Jan 13, 2022 at 12:40 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    I've never bought anything from this company but some of their products look like good ideas. https://www.roaringfiregear.com/new-items-and-deals
  13. Jan 13, 2022 at 1:02 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    Put in some work.
  14. Jan 13, 2022 at 1:24 PM
    Windsor
    Homeless in Oregon
    Some.
    Mounted the RR Backbone on the truck. If anyone installs one, I highly suggest skipping using the included rivnuts. Instead, drop the headliner and use bolts and nuts with SS fender washers. The rivnuts don't all expand below the lowest layer if metal an instead I had half of them expand inwards. I am also going to change out the RR stainless internal hex bolts and put in stainless bolts. The included bolts have very small heads and the included washers leave a bit to be desired. So, I will use 1/4-20 ss nuts and bolts with SS washers that are a bit bigger.
  15. Jan 13, 2022 at 3:11 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    Has your truck ever seen these substances called rain or snow? That truck looks like it came off the factory floor.
  16. Jan 13, 2022 at 5:44 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    spent this morning finding a place with spring press machine since after I pulled the passenger side coil over out the table top plastic case spring compressor wouldn't fit in the coils. Pulled the drivers side coil over dropped both off to get new 5100s put in em. And then spent my time cleaning hardware and cleaning the frame and suspension and hitting it with black paint. By that time I got the call they were ready and picked em up stuffed them back in. :rofl: Hour day well spent
    E5C9C1D3-16B3-46F4-B8D7-305F372BC3A7.jpg 2EA91C91-D501-4705-8682-7F760039F3D9.jpg 35D5E504-2C09-40C0-ACB5-A68C62A102A7.jpg A333A3A3-1530-40AB-A40C-CE7A0CF06B6E.jpg
  17. Jan 14, 2022 at 6:08 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    Re-hardwired my escort radar detector
    Tapped into floor light so it comes on and off with that cycle.
  18. Jan 14, 2022 at 6:59 AM
    Retroboy1989
    Northern Utah
    California....
    That's his wife's '21 sequoia, but still.... California...
  19. Jan 14, 2022 at 11:30 AM
    Ricos
    Ricos New Member
    Ricardo
    2010 Tundra SR5 White Widow
    Never stopping ...
    :help: Openend up the bottom,rod bearings of cilinder 2 are f*cked,hoping to save the crankshaft and blue marks on the rod end.
    wv00097, Prostar 190, D4x4TRD and 4 others like this.
  20. Jan 14, 2022 at 3:38 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Y’all know the deal
    ACDC2ZZTop, WVI, nb_nielsen and 19 others like this.
  21. Jan 14, 2022 at 5:17 PM
    NueveTundra
    Planet Earth
    cleaned and painted my tow hitch , just trying to keep things from underneath looking horrible. :rofl:
  22. Jan 14, 2022 at 5:33 PM
    JCtheOtherOne
    Jack
    Outside of Philly
    Is that a home plow? Not tilt from side to side right?
  23. Jan 14, 2022 at 6:05 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Yep. Side to side manual 3 point. Auto winch lift/lowering. Dk2 summit 2. Absolutely love it :)
    JCtheOtherOne likes this.
  24. Jan 14, 2022 at 6:17 PM
    JCtheOtherOne
    Jack
    Outside of Philly
    This is my bad boy
    D4x4TRD, WVI, Prostar 190 and 7 others like this.
  25. Jan 14, 2022 at 6:27 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Saweet :fistbump:
  26. Jan 14, 2022 at 7:39 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    Lol it only has 300 miles on it. It's a 21 sequoia, still more goodies comming in
    D4x4TRD, WVI, AstroDude and 11 others like this.
  27. Jan 15, 2022 at 9:20 AM
    COElkHunter
    COElkHunter New Member
    Jeremy
    2012 Silver Tundra TRD limited Crewmax 4x4
    3" OME lift w/ UCAs. ARE overland shell w/ ARE roof rack. 34" Falken Wildpeaks. ARB awning. Road shower. Wilco Offroad Hitchgate Solo High Clearance. LED lighting upgrades. Lockerdown console safe. Weathertech floormats. Duluth deluxe rear seat cover to go under the offroad approved car seats.... :P
    Morimotos and TRD Pro Sequoia grille conversion. Yota LED amber Raptor lights are next.
    WVI, toyofan87, Beachcomber and 16 others like this.
  28. Jan 16, 2022 at 6:33 AM
    Windsor
    Homeless in Oregon
    Some.
    Moved the platform from the canopy to the cab to get everything marked for it's final location. I'll take it off next time I go off the mountain so I can wash the truck and wax the roof and canopy. Then, they both go back on with their rail kits.
    I also pre-drilled holes to mount side lights on the backbone. I'll tap them before I wash the truck.
    D4x4TRD, WVI, Red Sonja and 5 others like this.
  29. Jan 16, 2022 at 7:47 AM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    Did you get cloth interior or leather? I'm curious if the newer cloth SR5s still get the folding passenger seat.
    Wynnded and joseph_womack like this.
  30. Jan 16, 2022 at 8:56 AM
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    Installed a diff drop (3.5 inch lift), installed a swing out bike carrier and my RRW came in. 17 inch, 0 offset
