  1. Jan 14, 2022 at 7:08 AM
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Sure. Makes sense. When replacing my lower control arm bushings on my '98 Taco I had to cut one of mine out as it was frozen from years of rusting. No way it could have been moved for alignment, which made me very suspicious about my last alignment at my dealership. However, the final numbers did meet spec., so maybe that side didn't need adjusting. A couple hundred dollars does seem a bit steep to replace though. Best.
  2. Jan 14, 2022 at 7:34 AM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    well mine definitely needed adjusting lol. They showed me the numbers before they did anything after the UCA install. Just installing the JBA’s went from .20 total toe to like 1.85, from 2.4 caster to 3.9, and .2 camber to -.7. I expected the caster and camber to be different but the toe being out that far surprised me.
    but the numbers I asked for were .4/.5 toe, 3.5 caster, and -.1 camber.
    Badknees[QUOTED] likes this.
  3. Jan 14, 2022 at 7:34 AM
    D3Tundra
    D3Tundra New Member
    Dennis
    Atlanta, GA
    2018 Midnight Black Tundra Limited 4x4 CM
    Rigid fog lights Interior Led light upgrade Spray in Bedliner CRUX Avity-01 VIM Bypass module 5% tint all the way around 50% on the windshield Wireless charger arm rest mod Amp Research Steps Bak Revolver X4 Tesla Style Headunit Procomp 4" lift Toyo M/T's 35x12.5xR22 Fuel Maverick D538 wheels 22x10 -24 offset
    Do you have a link to this kit? Looks good to me
  4. Jan 14, 2022 at 7:36 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
  5. Jan 14, 2022 at 7:51 AM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Oh, I'm around. Just too busy with "stuff" to have any fun right now. :(
  6. Jan 14, 2022 at 7:52 AM
    Badknees
    Badknees New Member
    I know with the JBA's you want a caster in the mid-3's and keep the camber and toe to factory specs (at least that's what I recall). Are you sure your new toe numbers are OK? 1.85 sounds way high to me.
  7. Jan 14, 2022 at 7:54 AM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Have a picture with it installed? I have been looking at this and their organizer that goes on the back of the front seat.
  8. Jan 14, 2022 at 8:04 AM
    DCB500
    DCB500 New Member
    Oklahoma City
    The same shop did the last alignment back in August of 2020. When I drove the truck right after installing the arms I could tell right away that the toe was out. Not idea how it happened but before the UCA install truck drove perfect and the toe with the last alignment was .10 per side. Not sure how it got thrown out that far just from installing the arms but it did. Those alignment specs are what JBA recommends but factory specs don’t necessarily apply when you consider lift. Toyota specs for my truck on toe is anywhere from .2 to .55 - that’s pretty high.
  9. Jan 14, 2022 at 8:07 AM
    DCB500
    DCB500 New Member
    Oklahoma City
    And yes they brought me the sheet before they did anything to it. I was shocked that it was that far out but like I said when I drove the truck right after install it was pulling all over the place with road “ruts” so given that the number makes sense.
  10. Jan 14, 2022 at 8:15 AM
    Badknees
    Badknees New Member
    Something seems way off if you have to have 1.85 of toe to make everything OK, but I'm not an alignment expert so I'll stop asking questions. Best.
  11. Jan 14, 2022 at 8:18 AM
    DCB500
    DCB500 New Member
    Oklahoma City
    I agree man that’s why I was surprised when I saw it. The toe I wouldn’t have thought would have been impacted at all just changing control arms but the road manners right after installing certainly indicate toe being way out.
  12. Jan 14, 2022 at 8:23 AM
    odymar
    odymar New Member
    Marcus
    21 SW CM SR5 4WD
    Installed the ME-SO ultimate dome and map lights today. I ended up being able to remove/install everything without pulling the assemblies out like their videos show. I just made sure to flip the light switch off before I started disconnecting anything electrical.
    Dsptundra, AggiePhil and Taco-Spike like this.
  13. Jan 14, 2022 at 8:25 AM
    Badknees
    Badknees New Member
    How much are you lifted? My Taco is not too high at 2.5", but I was able to get the camber and toe back close to spec with the new JBAs. Might be worth a call to JBA?
  14. Jan 14, 2022 at 8:38 AM
    DCB500
    DCB500 New Member
    Oklahoma City
    3” - the shop didn’t seem to concerned that they wouldn’t be able to get the t back in requested spec. Possible I misread and it was .85 but I did a double take when I saw it.
  15. Jan 14, 2022 at 8:45 AM
    Badknees
    Badknees New Member
    0.85 is a little easier to swallow!
  16. Jan 14, 2022 at 8:46 AM
    snowman19
    snowman19 New Member
    Scott
    Cypress, Texas
    2019 White Tundra CM
    Katskin leather seats, painted engine cover, fuse box cover, Rigid 30" light bar in bumper, Method 605 wheels, Bak roll up bedcover, Rhino lined grill surround and bumper caps
    Mine arrived yesterday, installing today, did you disconnect battery before installing?
    Taco-Spike likes this.
  17. Jan 14, 2022 at 9:40 AM
    odymar
    odymar New Member
    Marcus
    21 SW CM SR5 4WD
    I didn't, but it would be safer to disconnect. I accepted the risk.
  18. Jan 14, 2022 at 10:16 AM
    ThisGuy03
    ThisGuy03 New Member
    Las Vegas, NV
    ‘17 CM LTD TRD 4x4 MGM
    King 2.5s..TC UCA..35x12.50-18 M/T..AMP Steps
  19. Jan 14, 2022 at 10:31 AM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    now just pop led bulbs in your fogs and its killer.
    HulkSmurf14 likes this.
  20. Jan 14, 2022 at 10:33 AM
    ThisGuy03
    Las Vegas, NV
    One step at a time haha! I have a popping noise up front I’m trying to figure out. Annnd I want to chrome delete. Another thousand bucks lmao I go in phases with this truck. Sometimes I dump dough, then months go by I don’t even want to put gas in it lol
    batman900 and welshmike like this.
  21. Jan 14, 2022 at 10:34 AM
    Mobeyk
    Mobeyk New Member
    Got lettering done on the truck then IGL Ceramic coating done. Here the before and after of the IGL ceramic coating.
    Shiniest work truck east of GTA. 5EA324AE-40D7-48D5-901D-B05F2ACF6D2E.jpg C2AFF596-7A5A-459E-AA8C-3F77F2CBBC97.jpg
  22. Jan 14, 2022 at 10:36 AM
    Nice.
    :101010:
  23. Jan 14, 2022 at 10:54 AM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    Gave ol girl a bath since it was decent weather today.
  24. Jan 14, 2022 at 10:59 AM
    Taco-Spike
    Two Trucks
    Looks so good!
    EatSleepTacos[QUOTED] likes this.
  25. Jan 14, 2022 at 11:06 AM
    Nice, wish I could.
  26. Jan 14, 2022 at 11:12 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    Thanks! I’m very happy with how it’s sitting now.
    Taco-Spike[QUOTED] likes this.
  27. Jan 14, 2022 at 11:18 AM
    D3VA
    D3VA New Member
    NoVA
    2021 TRD Pro in the MGM Master Race!
    Keeping with the small changes, chrome delete starts with the easy stuff.
    GAknight, GELCW, WawaLunar and 4 others like this.
  28. Jan 14, 2022 at 11:42 AM
    D3VA
    D3VA New Member
    NoVA
    FWIW - There's a multi-prong test on salary vs SCA / hourly. You may want to ensure the company followed the rules or they will owe her some significant back pay.
    batman900[QUOTED] and Taco-Spike like this.
  29. Jan 14, 2022 at 12:09 PM
    cementsharktrd
    cementsharktrd New Member
    Demetrio
    2021 Cement Tundra TRD Off-Road
    7 inch bds coilover lift kit
  30. Jan 14, 2022 at 12:40 PM
    twotrack
    twotrack New Member
    Clint
    Tampa, FL
    2015 Tundra SR5
    Installed my charging tray and MX4 today...
    Loving them both so far!
    GAknight, camron1039, Vr0ck and 4 others like this.
