Cleaning Pro Wheels
Discussion in 'Detailing' started by Borgs, May 18, 2017.
  1. May 18, 2017 at 3:34 PM
    Borgs
    Borgs [OP] New Member
    PA
    2017 Limited Crew TRD Off-Road
    Pro Grill and Bulge TRD sway BAK MX4 Tonneau
    What do you use? Wheelcleaner and a brush? I think a brush may scratch the black.
  2. May 18, 2017 at 3:55 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Don't use a a brush. I like to use Sonax wheel cleaner. It takes our most grime and brake dust then just use water and soap to get rid of the rest. Expensive but works well.
    SouthBoundSteve likes this.
  3. May 18, 2017 at 3:57 PM
    Borgs
    PA
    No wiping?
  4. May 18, 2017 at 3:58 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    If it's not that dirty no wiping needed. If it's prettt dirty soap water and microfiber
  5. May 18, 2017 at 6:49 PM
    Voyagermike
    Voyagermike New Member
    California
  6. May 18, 2017 at 7:20 PM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    Vinegar based glass cleaner
    Backslider likes this.
  7. May 18, 2017 at 9:10 PM
    Borgs
    PA
    Thanks all. I really appreciate it.
    Voyagermike likes this.
  8. May 19, 2017 at 3:36 AM
    Borgs
    PA
    Beautiful- thanks so much for sharing. What kind of need bars are those?
  9. May 20, 2017 at 8:05 AM
    TexasMofo
    TexasMofo New Member
    Chad
    Great Country of Texas
    2017 Toyota Tundra TRD Pro
    Illegal Tint 2 Shims/ 3 inch Shacke
    I have used Palmolive to clean my trucks since I was 16. Just use a soft sponge on the wheels works great.
  10. Jun 1, 2017 at 6:28 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    I'm a huge fan of Sonax, I buy it in bulk. You can get 6 packs on Amazon for a pretty good deal! I'm also a big fan of griots heavy duty wheel cleaner. Suggest buying it by the gallon.
    I also coat most my wheels, either in a wheel wax, did put cquartz on my set of CCW's.
    MAC25Tundra likes this.
  11. Jun 1, 2017 at 6:33 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
  12. Jun 1, 2017 at 6:54 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
  13. Jun 1, 2017 at 7:04 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    I do not recommend the above unless your wheels are polished aluminum and you are actually polishing them. THat tool is not for cleaning.
    I find it funny they show it in front of a chrome plastic grill
  14. Jun 1, 2017 at 9:27 AM
    NickyF25
    NickyF25 New Member
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    +1 on the Sonax Full Effect wheel cleaner. I worked great on my Audi S4 which always had a lot of break dust. Plan to start using it on the Tundra.
  15. Jun 1, 2017 at 9:46 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    I use 50/50 mix of 5% acidity white vinegar and reverse osmosis water (distilled would work too) in a spray bottle. It costs almost nothing and works as well as or better than most of the chemicals you will find. You could use 100% 5% acidity vinegar and it would cut through almost anything without damaging painted or metal surfaces.
  16. Jun 1, 2017 at 10:48 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
  17. Jun 8, 2017 at 12:08 PM
    dmeneses1983
    dmeneses1983 New Member
    Dennis
    2016 Silver Tundra
    Might have to get this
  18. May 7, 2025 at 6:07 PM
    JBplays
    JBplays New Member
    Jeff
    2018 Crewmax
    You use this mixture to clean TRD Pro BBS rims?
    And you've had no problems after??
  19. May 7, 2025 at 7:00 PM
    Backslider
    Tooele, UT
    Is there something about these wheels that makes them different than any other forged aluminum, painted wheels?
  20. May 7, 2025 at 7:07 PM
  21. May 10, 2025 at 9:13 PM
    MAC25Tundra
    MAC25Tundra New Member
    2025 Limited Crew Max 4x4
    Another vote for Griot’s Heavy Duty.
  22. May 19, 2025 at 12:05 AM
    MALIBU1794DC
    MALIBU1794DC Like a Japanese Texas built Rock
    2019 Double cab 1794
    Sonax for me.
    20250420_152005.jpg 20250420_184053.jpg 20250420_152026.jpg 20250420_161420.jpg
  23. May 19, 2025 at 12:12 AM
    MALIBU1794DC
    20250423_190719.jpg 20250420_184057.jpg 20250420_184059.jpg 20250420_184117.jpg
    You spray the sonax on a cool and dry wheel.
    Let it dwell for 5 minutes.
    Then use a $2 soft detailing brush, they are like synthetic horse hair brushes.
    The sonax has an iron remover component in its chemistry. It'll go from bright yellow to purple.
    Once it goes purple you use the brush to agitate it all. Takes 5-10 minutes to brush up each wheel. Just light pressure. Get into every crevice. Make multiple brush passes so over. The sonax does 90% of the work and the brushing is what makes it the chefs kiss.
    You can't be cheap with the sonax , you kind of need it to make it all wet. The brush helps distribute it. If you see areas that seem dry , spray more sonax. To clean 4 wheels that are filthy, Like years of no cleaning. To clean extra extra extra good. I might need 2 bottles.
    Usually to maintain. 1 bottle gets me 4 car washes/ uses. So, I use 25% of the bottle for 4 wheels. So 1 bottle let's me do 16 wheels. That seems to be my rate of consumption of sonax. But, I do do the tires as well. If I do a regular sized car wheel, not truck wheel, I can get maybe 6 uses out of a bottle, 24 wheels. And if you don't do the tires, Maybe 8 uses on car sized wheels.
    Then use the hose with it highest pressure nozzle you got and blast off the sonax.
    It's ph balanced. Has never messed up a wheels finish for me.
    Sonax products are made in Germany. Good stuff.
    Might have to do a second round after you hose off and let it dry.
    The sonax spray bottle even sprays like a German made spray bottle. Really good spray spread.
    In the past I've scrubbed wheels for hours. Used Palmolive, used vinegar, used acid, used almost every wheel cleaner. Used power tools. I've tried it all.
    The iron remover in sonax does molecular unbonding of the iron in the brake dust and the actual wheel. Just sonax , the brush, and light agitation gets it done perfect.
    Sonax wheel cleaner is awesome for cleaning mufflers and exhaust systems. Exhausts get hot then catch brake dust all day. Sonax makes exhausts look new.
  24. May 19, 2025 at 12:55 AM
    MALIBU1794DC
    These brushes are what I use.
    They get really nasty after. Super contaminated.
    Don't forget to sonax and brush your tires too. It gets all the brake dust off tires perfectly as well
    After the wheels are clean I'll use a microfiber towel to dry the rims. The microfiber does the final wipe.
    I've also observed that by using sonax on the wheels and tires. It all lasts better and longer. I never get dry rot or crusty sidewalls anymore. I think by keeping it clean then putting a silicone free plastic dressing on, like 303 or chemical guys. It all stays fresh up to the end of the tires life.
    KNABORES likes this.
  25. May 22, 2025 at 10:42 AM
    MALIBU1794DC
    Palmolive rips off clear coat. It's too strong for automotive finishes. Not good for wheel finish and not good for paint finish.
    You've been doing it since 16, you can do it till you're 100. Still wrong for automotive applications.
