Cleaning Pro Wheels
Discussion in 'Detailing' started by Borgs, May 18, 2017.
  1. May 18, 2017 at 3:34 PM
    Borgs
    Borgs [OP] New Member
    PA
    What do you use? Wheelcleaner and a brush? I think a brush may scratch the black.
  2. May 18, 2017 at 3:55 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Don't use a a brush. I like to use Sonax wheel cleaner. It takes our most grime and brake dust then just use water and soap to get rid of the rest. Expensive but works well.
    SouthBoundSteve likes this.
  3. May 18, 2017 at 3:57 PM
    Borgs
    PA
    No wiping?
  4. May 18, 2017 at 3:58 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    If it's not that dirty no wiping needed. If it's prettt dirty soap water and microfiber
  5. May 18, 2017 at 6:49 PM
    Voyagermike
    Voyagermike New Member
    California
  6. May 18, 2017 at 7:20 PM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    Vinegar based glass cleaner
    Backslider likes this.
  7. May 18, 2017 at 9:10 PM
    Borgs
    PA
    Thanks all. I really appreciate it.
    Voyagermike likes this.
  8. May 19, 2017 at 3:36 AM
    Borgs
    PA
    Beautiful- thanks so much for sharing. What kind of need bars are those?
  9. May 20, 2017 at 8:05 AM
    TexasMofo
    TexasMofo New Member
    Chad
    Great Country of Texas
    2017 Toyota Tundra TRD Pro
    Illegal Tint 2 Shims/ 3 inch Shacke
    I have used Palmolive to clean my trucks since I was 16. Just use a soft sponge on the wheels works great.
  10. Jun 1, 2017 at 6:28 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    I'm a huge fan of Sonax, I buy it in bulk. You can get 6 packs on Amazon for a pretty good deal! I'm also a big fan of griots heavy duty wheel cleaner. Suggest buying it by the gallon.
    I also coat most my wheels, either in a wheel wax, did put cquartz on my set of CCW's.
  11. Jun 1, 2017 at 6:33 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
  12. Jun 1, 2017 at 6:54 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
  13. Jun 1, 2017 at 7:04 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    I do not recommend the above unless your wheels are polished aluminum and you are actually polishing them. THat tool is not for cleaning.
    I find it funny they show it in front of a chrome plastic grill
  14. Jun 1, 2017 at 9:27 AM
    NickyF25
    NickyF25 New Member
    Nick
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    +1 on the Sonax Full Effect wheel cleaner. I worked great on my Audi S4 which always had a lot of break dust. Plan to start using it on the Tundra.
  15. Jun 1, 2017 at 9:46 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I use 50/50 mix of 5% acidity white vinegar and reverse osmosis water (distilled would work too) in a spray bottle. It costs almost nothing and works as well as or better than most of the chemicals you will find. You could use 100% 5% acidity vinegar and it would cut through almost anything without damaging painted or metal surfaces.
  16. Jun 1, 2017 at 10:48 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
  17. Jun 8, 2017 at 12:08 PM
    dmeneses1983
    dmeneses1983 New Member
    Dennis
    2016 Silver Tundra
    Might have to get this
