SR Trim
Discussion in '3rd Gen Tundras (2022+)' started by TicTacx, Dec 4, 2021.
  1. Dec 30, 2021 at 3:33 PM
    #61
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
  2. Dec 30, 2021 at 3:35 PM
    #62
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Max payload is a SR 2wd config
    Mattedfred likes this.
  3. Dec 30, 2021 at 3:39 PM
    #63
    ezdog
    ezdog New Member
    Gateway To The West
    I know was just kidding really but not too big of a difference really and in SR trim maybe not the highest numbers anymore either?
    They had to do something different to lower the power and towing specs?
    1UP[QUOTED] likes this.
  4. Dec 30, 2021 at 3:40 PM
    #64
    1UP
    1UP Truck Gang
    I believe your right.. I don't think they can Max tow (11k lbs) due to the detuned power.
  5. Dec 30, 2021 at 7:22 PM
    #65
    TitanTiger09
    TitanTiger09 New Member
    Biggest issue I have with the SR trim is the fuel tank size. Don’t think you can add the 32.5 gallon tank to the SR can you?
  6. Dec 30, 2021 at 7:43 PM
    #66
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Nope, have to get the SR5 with the SR5 convenience package with option to get 32 gal tank.
  7. Dec 31, 2021 at 5:31 PM
    #67
    Joe T
    Joe T New Member
    Anyone see any 8ft beds yet?
    May order one as a company vehicle. As long as the hitch, springs, and axle are the same I think 11,000 towing would be fine.
    Whats the leadtime on ordering?
    Henry1jg likes this.
  8. Jan 1, 2022 at 8:16 PM
    #68
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    SR max towing is 8300 lbs, cause of detune engine
  9. Jan 1, 2022 at 8:25 PM
    #69
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    they are forcing buyers to buy a 50k truck
    OnThaLake likes this.
  10. Jan 1, 2022 at 8:48 PM
    #70
    Joe T
    Joe T New Member
    I dont think it will have a problem as long as the rest is the same. 8000 is a little tough because a good trailer weighs 3000+ lbs itself.
    Some of the derate and detune stuff is just to keep commercial users from maxing them out constantly and durability issues.
    On the Ford for example they come with different axles and frames for some selections and models. It looks like Tundra they are all the same.
  11. Jan 2, 2022 at 4:32 PM
    #71
    yooperbikemike
    yooperbikemike New Member
    2022 SR5 TRD OR Premium CM 5.5
    I must say that I'm intrigued by the SR. I look at it as kind of a Super Tacoma.
    Let's say you're a Tacoma owner and you're a Toyota guy and you want a bit more power, towing, a roomier interior but don't want to spend $50k for a strippo SR5.
    The Good: ~70 more HP and 135 lb/ft of torque, ~2000 lbs more towing capacity. 6-7" wider cab and even the double cab has a bit more legroom(about an inch) than the Taco Double cab. More modern suspension and transmission than the taco.
    The Bad: Heavy -- 800 lbs or so heavier than a Taco. Lack of options -- Lets face it, If you're considering an SR, you're probably not the sort who can pay for a platinum out of pocket change. The only things I would want are, the towing package, alloy wheels and a bigger gas tank. However, you're going to be able to buy new take-off wheels on E-bay (there are already some listed) and even the small tank is 1.5 gallons bigger than the Taco with comparable MPG.
    I haven't seen an SR and who knows, maybe it's horribly cheap looking compared to the upscale specs, but I doubt it. . .
    mountaingroan and Mattedfred like this.
  12. Jan 2, 2022 at 5:43 PM
    #72
    Shackleton
    Shackleton New Member
    Former Tundra current Gladiator
    I owned a 2013 Tundra Grade double cab 4x4 with the small V8. I put take off wheels on it after my stock tires were worn out. The truck was black and back then the base model had a black grill and black bumper. I thought it looked pretty good and I think I paid 24.5k new for it back then- it probably stickered for 32k if I had to guess. I think this SR could work well with take offs but I’m really not certain what I’d be giving up with the detuned engine. Are there any other mechanical changes? The key is for the bumper and grill to not make the truck look cheap. I feel like I’d need to see one in the wild. The small screen and lack of package options don’t bother me and I think I can live with a slightly less powerful engine but if it looks bad, even with take offs I think I’d have to move up. When the truck first came out I thought I wanted a TRD grill but I think I might be open minded enough now to see what the SR looks like. We will see. Hoping someone posts pictures soon
    yooperbikemike likes this.
  13. Jan 2, 2022 at 5:48 PM
    #73
    TicTacx
    TicTacx [OP] New Member
  14. Jan 2, 2022 at 6:57 PM
    #74
    Joe T
    Joe T New Member
    No SR in my zip it looks like. Going to call a dealer tomorrow a forum member hooked me up with their sales guy.
    We just need a shop truck for someone at work.
    Anyway, I bet a tune could bypass the detune. A set of black wheels would look nice, the trim is black mix of satin and gloss.
    They could get fleet sales with a crew cab 6.5 bed truck, that is a popular style. We just need a double cab 8ft bed, will put a shell on it.
    SoTexasReds and Mattedfred like this.
  15. Jan 3, 2022 at 11:57 AM
    #75
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    A tune will void warranty too
  16. Jan 5, 2022 at 6:12 PM
    #76
    Shackleton
    Any sightings of this trim level yet?
  17. Jan 5, 2022 at 6:17 PM
    #77
    yooperbikemike
    Local dealer is supposed to get 2 in 10 days or so
  18. Jan 5, 2022 at 9:01 PM
    #78
    mass-hole
    mass-hole New Member
    the power difference is in how the engine is tested(chassis vs engine dyno) and the emissions compliance it has to meet. I believe on the heavy duty/commercial trucks they have to dyno them with the EGR active.
    ford had a PDF somewhere that explained the difference in the ratings.
  19. Jan 5, 2022 at 9:24 PM
    #79
    mass-hole
    hey, that was my post!
    I can only see two options. Either Toyota is sandbagging to push people up into higher trims, or the SR is somehow less capable. That could be cooling, axle, frame, etc. Who knows until we see one.
    Or, i kinda wonder if we might see a turbo 4 cylinder in the upcoming Tacoma and that would become the entry level option for the Tundra. Something similar to GM’s 2.7L turbo. The detuned 3.5 is just a placeholder until then.
    TicTacx[QUOTED][OP] likes this.
  20. Jan 9, 2022 at 7:31 AM
    #80
    Mattedfred
    Mattedfred Toyota Fan Boy Since ‘04
    Ted
    Cambridge, Ontario Canada
    2023 SR5 TRD Sport DC 4X4 in MGM
    TRD Skid Plate/Running Boards, Bison Soft Rollup Tonneau, Thule Canoe Rack, Bedmat, Tailgate Black Insert Badge, Northwest Seat Covers Neoprene Custom Fit Front Row Seat Covers. Tailgate Mat
  21. Jan 9, 2022 at 1:20 PM
    #81
    mountaingroan
    mountaingroan New Member
    Frank
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
    Parker Toyota has one sitting nearby in CDA idaho, if it were a 6.5 I'd buy it and retro the 32 gallon gas tank down the line.
    Can't use the 8.1 bed though, I don't want a bowling alley following me around everywhere....
    Elevatorguy likes this.
  22. Jan 20, 2022 at 5:17 PM
    #82
    gulfcoast850
    gulfcoast850 New Member
    I have an sr crewmax 4x4 on order. Hope to have it any day now. My question is does the heated side mirrors? It says on spec sheet but want to be sure. Also spec sheet says day time running lights. Can anyone confirm this?
  23. Jan 20, 2022 at 5:26 PM
    #83
    mountaingroan
    Frank
    North Idaho
    Heated power outside mirrors Standard on SR trim. ....Yes.
    LED headlights with Daytime Running Lights (DRL), auto on/off feature, and manual leveling adjustment Standard on SR trim....Yes.
    I'm gonna trust the spec sheet on this.
  24. Jan 20, 2022 at 7:17 PM
    #84
    chrispar
    chrispar New Member
    Weird, In Canada (toyota.ca), the detune engine Sr can tow 5060kg, more than any other models
  25. Jan 20, 2022 at 7:39 PM
    #85
    Totherion
    Totherion New Member
    Yes to both. SR trim comes with a lot of standard equipment.
  26. Jan 20, 2022 at 8:04 PM
    #86
    TitanTiger09
    Agreed. Just wish it had an option for the 32 gallon fuel tank and trailer brake controller. If both were offered as an add on package I think the SR trim would be a hell of deal when compared to other base model trucks. Toyota probably didn’t include these two options on the SR to get people to step up to the SR5 and spend a little more money.
  27. Jan 20, 2022 at 9:49 PM
    #87
    mountaingroan
    Frank
    North Idaho
    Yep, agree 100%. I'm buying one anyway, the 22.5 tank was really close to a deal breaker but for the $7000 savings over most of the cheaper SR5 pricing, We'll see how it goes.
    Gotta wonder if a guy slipped that 32 gallon under there after the fact the techs would even notice re. warranty. They probably would, but maybe not.
    As far as I'm concerned the SR with the 32gal would be the perfect truck and at a bargain price. In 20-30K miles, I'll watch for a 32 g tank from a wrecked truck and will grab it.
  28. Jan 21, 2022 at 12:40 AM
    #88
    Mattedfred
    Ted
    I agree 100% with both of you. Great idea about getting a tank from a wrecker. Especially now that they're ABS. Watching videos where they show the underside, I gotta say that it looks like there might be room for a tank even slightly larger than a 32.
    All I really need is an SR with; tow package, brake controller, large tank and towing mirrors. I detuned powertrain output and towing capacity works for me.
    mountaingroan[QUOTED] likes this.
  29. Jan 21, 2022 at 6:30 AM
    #89
    ezdog
    ezdog New Member
    Gateway To The West
    Given the past mixed reviews of the Toyota Brake Control and the great performance of my Tekonsha controllers the lack of a built-in brake control is really a good thing to me.
    The small tank and detuned engine,not so much.
    Mattedfred[QUOTED] likes this.
  30. Jan 21, 2022 at 6:42 AM
    #90
    yooperbikemike
    I'm wondering just how easy a tank retrofit would be. I seem to recall someone who did this on the last gen and they had to modify the frame to do it
