Lifting a 3rd gen
Discussion in '3rd Gen Tundras (2022+)' started by Yota2121, Jan 6, 2022.
  1. Jan 6, 2022 at 5:24 PM
    Yota2121
    Yota2121 [OP] New Member
    chanon
    2022 Tundra Limited
    None
    I'm new here and looking for anyone that has or will be doing modifications on a 2022 Tundra. I did read that you can use the second gen's strut spacer to lift the front. Not my first choice, i'm looking for full strut and spring, 2-3 in lift for 33in tires and a little more of a aggressive look. Thanks
    Dmon187 likes this.
  2. Jan 7, 2022 at 3:18 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    So far only seen mostly everyone using spacer lift. Westscott design making their own preload collar on front but using spacer puck in rear. Only one I’ve seen so far that actually uses spring lift is from Adventure Motor, using Dobinson stuff. All still testing. This truck is new platform that just came out last month. So going to be awhile. Lol.
    FirstGenVol, DexterL and Acedude like this.
  3. Jan 7, 2022 at 6:13 AM
    Yota2121
    chanon
    2022 Tundra Limited
    None
    Thanks TakiEvo!
  4. Jan 7, 2022 at 8:16 AM
    randomquickness
    randomquickness New Member
    don't need any lift or level for 33s. Rough Country has a lift coming out soon (unknown what's included,) Westcott Designs has a collar lift coming later this month (better than a spacer lift) and there is the TRD lift kit that is very inclusive which should cost about 4k plus install. I'm sure there are more in the works, that's just what I know of right now.
  5. Jan 7, 2022 at 8:19 AM
    Yota2121
    chanon
    2022 Tundra Limited
    None
    Thanks randomquikness, yes I want to avoid spacers. I'll look into that
  6. Jan 7, 2022 at 2:58 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Dobinsons, Icon and Adventure Motors KC are all working on coilovers and rear lift kits- adventure motors will be first to market, then dobinsons if i had to guess
  7. Jan 7, 2022 at 3:18 PM
    Yota2121
    chanon
    2022 Tundra Limited
    None
    Thank you DexterL
  8. Jan 7, 2022 at 4:28 PM
    fluke702
    fluke702 New Member
    Anyone dealt with Wescott Designs? They're coming with a preload collar lift kit.
    COTundra23 and Dmon187 like this.
  9. Jan 19, 2022 at 8:15 AM
    Bulldog1598
    Bulldog1598 New Member
    Greg
    2022 Black Limited 4x4
    My truck will be here around Feb 1. It'll be going straight from the dealership to Superlift for R&D for their lifts along with some R&D for Bushwacker and N-Fab I'm told. Should take a few weeks, but Ill post pics as I can.
  10. Jan 19, 2022 at 8:17 AM
    COTundra23
    COTundra23 New Member
    While I have never purchased anything from the, I know those who have, have had great experiences. They make quality products and have a good reputation
  11. Jan 19, 2022 at 8:36 AM
    Yota2121
    chanon
    2022 Tundra Limited
    None
    Beautiful, please keep us posted. Did you get air suspension by chance? I'm waiting for nfab side steps.
  12. Feb 2, 2022 at 4:15 AM
    Mattedfred
    Mattedfred Toyota Fan Boy Since ‘04
    Ted
    Cambridge, Ontario Canada
    2023 SR5 TRD Sport DC 4X4 in MGM
    TRD Skid Plate/Running Boards, Bison Soft Rollup Tonneau, Thule Canoe Rack, Bedmat, Tailgate Black Insert Badge, Northwest Seat Covers Neoprene Custom Fit Front Row Seat Covers. Tailgate Mat
  13. Feb 2, 2022 at 7:28 AM
    21CGtundra
    21CGtundra New Member
    Robbie
    SLC, UT
    2022 Midnight Black Tundra SR5
    2" front level, 1" Cornfed rear spacer, Rally Armor flaps, Method Con-6 wheels, 285/75 Duratrac
    Nice to see some UCA's are in the works. Has anyone seen the spring perch spacers that RPG uses for the Raptors and Broncos? It seems like a simple design with the same lift principle as a 5100 or the Westcott spring perches. I think a 3/4-1" spacer under the spring perch with a 1/4-3/8" thick spacer on top (like Torq Engineering's) would be a good way to net 2-3" for fairly inexpensive and not be ALL spacer on top.
    Once my truck shows up I'm going to pull a strut apart and see what the spacer would take but judging from what I've seen it will be a 6061-t6 aluminum tube lathed to match the specs of the perch seat on the strut and cut to length desired. I'll keep this thread updated once I can get my hands on a 22' front shock.
    Yota2121[OP] likes this.
  14. Mar 23, 2022 at 5:35 PM
    Jack Straw
    Jack Straw New Member
    Any updates from people who have installed either the Wescott preload collar or the procomp lift?
    Is the preload collar just the same as a spacer lift? New to all this and trying to figure it out.
  15. Mar 23, 2022 at 9:23 PM
    MHappy4
    MHappy4 New Member
    Ty
    22 Blueprint Tundra Platinum
    Just got the pro comp lift done today-
    I was pleasantly surprised with how nice it still rides compared to stock.
    I had the AVS system, just unhooked it and zip tied the cables out of the way, no lights in the dash so that was a relief.B7A6C9AE-10D9-484E-8FC9-E14B3D7972C1.jpg
    Jack Straw[QUOTED] likes this.
  16. Mar 24, 2022 at 12:08 AM
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    That looks really good. How level is it?
