Refilling tank exceeds card authorization at the pump?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Shadowfax1, Jan 6, 2022.
  1. Jan 6, 2022 at 2:44 PM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    When wife an I r on are motorcycles you should c the hassle it is!!
    Shadowfax1[OP] likes this.
  2. Jan 6, 2022 at 3:02 PM
    Shadowfax1
    Shadowfax1 [OP] New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    That's scary.
    Hey...total sidebar...you're in Dublin, CA?
    I live 5 miles away at the top of the hills of Fairview/Casto Valley. In Dublin all the time.
    You happen to know any good shops in this area where I can get some USB & AC wiring stuff done? I'm not electrically or mechanically inclined and want this done right.
  3. Jan 6, 2022 at 3:04 PM
    GravityGear
    Aurora, CO
    I have a 46 gallon tank. I just go $60 each time and call it. I don't even try to fill it anymore. Besides, I drive so little at this point that the gas would go bad in the tank before I could finish it.
  4. Jan 6, 2022 at 3:52 PM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    The Tundra Club does have its Perks and this is just one of them!
    Mine seems to have a Drinking Problem for sure and she does not really like to talk about it.
    panicman, 2mchfun and Shadowfax1[OP] like this.
  5. Jan 6, 2022 at 4:05 PM
    biebs96
    PA
    You could always go inside and ask the cashier. I know at the place I typically fuel, if the limit is going to be surpassed they allow you come inside and pre-swipe.
  6. Jan 6, 2022 at 4:07 PM
    ezdog
    ezdog New Member
    Gateway To The West
    But if you do it this way dont you have to guess how much it could be and they authorize over that so that it will flow till done?
    It just bugs me even more to have to go inside and authorize for an arbitrary guessed amount.
  7. Jan 6, 2022 at 4:14 PM
    2mchfun
    I seldom completely fill it, hoping to avoid the check valve issues some have by keeping it a couple of gallons shy of full most of the time.
  8. Jan 6, 2022 at 4:30 PM
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    That's one of the things I hated about California, they keep raising gas tax, then put those monies in to the general fund, instead of fixing the roads.
  9. Jan 6, 2022 at 4:33 PM
    2mchfun
    Easier to siphon a little extra from a general fund.
  10. Jan 6, 2022 at 4:59 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Sorry man, don’t know anyone who does electrical stuff.
  11. Jan 6, 2022 at 5:02 PM
    2mchfun
    Maybe check with some audio installers.
  12. Jan 6, 2022 at 5:25 PM
    biebs96
    PA
    I am not sure how other stations may do it. But this station just pre-authorizes the card and then completes the transaction upon fueling finish.
    ezdog[QUOTED] and Shadowfax1[OP] like this.
  13. Jan 6, 2022 at 8:21 PM
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Bridgestone Dueller Ascent tires
    Never thought this would be an issue, as a Canuck, some stations default to $100, others $200 etc, but anywhere I have filled, you can select another amount, pick your $ value before the authorization step, and go.
  14. Jan 6, 2022 at 8:32 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Was the lesson to keep your kid’s heads attached to their shoulders?
  15. Jan 6, 2022 at 9:47 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    I fill up before I reach 1/2 a tank. Costs less that way! Haha
  16. Jan 6, 2022 at 10:35 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    The most “dangerous” I lived was to keep driving my commute after the gas light had turned on, and I went another 60 miles or so. It was on empty for a day or two. When I filled, I got about 33 gallons in. So, there was probably 5 more gallons sloshing around in there.
  17. Jan 7, 2022 at 1:46 AM
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
    Good grief. Is that gas pumped from a gold nozzle by an Egyptian prince? At this rate, gasoline is going to be as expensive as the ink in inkjet cartridges sold by printer manufacturers.
  18. Jan 7, 2022 at 2:21 AM
    handyman
    handyman New Member
    Lol. I rarely ever let my tank get below 1/4 full (never knew it costs less by doing so) and always fill up before entering major cities when traveling. Some of the gas stations in cities are not places you want to hang around in long enough to even pump gas.
  19. Jan 7, 2022 at 9:05 AM
    wiltech
    wiltech New Member
    Tony
    Lafayette, IN
    2018 Inferno Limited
  20. Jan 7, 2022 at 4:12 PM
    #50
    Bentarm13
    Bentarm13 New Member
    Most pumps in FL have a 20 gallon max. PIA!
