  1. Jan 6, 2022 at 5:55 PM
    T2ndLife
    T2ndLife New Member
    JD
    '02 4.7L 225K 4WD Ext Cab
    WIP - keeping stock Kenwood DNX9960 GPS Nav/Stereo NexD XD400/4 400W Amp Wood Trim package added 4Runner alloy 17 inch wheels
    Like we said working in the shipping biz, factory packs for the product are NOT intended for shipping. That box should have been packaged into another. Of course with shipping costs as high as they are, virtually nobody is doing that. No great wonder product damage happens.
  2. Jan 6, 2022 at 6:00 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    But it would be even. And then you can still lower the whole seat down with that big lever
  3. Jan 6, 2022 at 6:00 PM
    I'm sure it would be fine if I was ordering a shrink wrapped pallet full of them. :rofl:
    Believe it or not, if they just glued down the styrofoam blocks in place within the box, it would help to isolate the radiator from the edges of the box and keep it from shifting in the package.
    chrisb, T2ndLife[QUOTED] and NUDRAT like this.
  4. Jan 6, 2022 at 6:08 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Ugly.
    Ditto.
    I got about 1mpg on mine iirc.
  5. Jan 6, 2022 at 6:15 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    It would for sure overlap, the top one just about rests on the bottom one as is. I remember PHM using some washers, that might be the ticket and obviously more economical. I'll drive it as is and report back
    alb1k[QUOTED] likes this.
  6. Jan 6, 2022 at 6:44 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Yes, it would be higher front and back, and roughly the same level as stock. I think most people like the angle of higher front, but maybe it's really the raised height, distance from knees to the floor part. But, if you are 6'3" higher sounds like it becomes a problem, I don't know. My big lever adjustment has been at the lowest level since I was 6'2"
    chrisb and txagg like this.
  7. Jan 6, 2022 at 11:24 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    What is a flip fob?
    Yes please share link
    What’s the easiest way to find out which keyless system I have? I know it’s the stock system, 2000 AC SR5
  8. Jan 7, 2022 at 12:32 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    It wasn’t personal. I honestly did not remember who shared the screwdriver fix, but you weren’t the only one. I was close to joining your club as well, a couple times. After being stuck at the gas station doin the key-jiggle for several minutes before finally popping, the lock was removed
    bmf4069[QUOTED] likes this.
  9. Jan 7, 2022 at 3:56 AM
    EvilMilkshake
    EvilMilkshake New Member
    05 AC Limited 4x4
    As someone who is 6'0" with a non-height-adjustable manual bench seat, the seat jackers are great. Definitely keeps my butt in the back of the seat where it should be and the back of my knees are actually on the seat. Way more comfortable. Price is steep for two sets, but they are really well made. I trust them in a crash more than less threads holding the seat to the floor by adding washers with the stock bolts, so if you go that route, get longer bolts.
    It took about about a week for it not too feel weird though, but that happens anytime you lose the memory of a power seat as well.
    txagg and chrisb like this.
  10. Jan 7, 2022 at 5:17 AM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    I agree with this, and believe the seat jackers are worth every penny. The bolts they supply are a higher grade than the factory ones, quality U.S. made kit that works well. Height wise I am on the other end of the spectrum, I bet they are perfect for the majority of drivers. I also need to add again that I have no drive time with them installed. Lastly, I am fixing this truck for my dad and he is much shorter than I so they might end up being perfect for him.
  11. Jan 7, 2022 at 5:29 AM
    Anyone have a link to these Seatjackers? Are they custom for our trucks or just universal?
  12. Jan 7, 2022 at 5:58 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Yea i wanna know more about what happened too! I hope the dogs were okay! Hope all is well despite wrecking your Tundra like that
    shifty`[QUOTED] likes this.
  13. Jan 7, 2022 at 6:25 AM
    daveeasa
    Desert Does It. Please double check my links, kinda not yet awake. Also, some mechanical engineers have concerns about the safety of the front jacker design from a bolt sheer perspective. I happen to be mid size myself so I’ve found no height adjustment to work best in both my trucks.
    Front
    Rear
    I have some super nice aluminum / delerin rear seat risers which were hand-made by the same guy who made my SS shift knob which match the countors of the rear seat mounts. One pair of 1” and one of 1.5” and I don’t think I will end up using them. I will double check how nice they fit our Tundras sometime and probably send them to someone in this FGT circle down the road. They are beautiful. Somewhat disappointingly, both my wife and I prefer stock height.
  14. Jan 7, 2022 at 6:30 AM
    daveeasa
    If you have the RS3000 system with the oem oval shaped fobs, like I do, this may work for you. It works for me, though the panic is annoying and the lock and unlock buttons work like the old single button fob in that any signal is a lock of the vehicle if it is currently unlocked or an unlock if it is currently locked. Beeps the same as the OEM fob, one beep is lock, two is unlock.
    You would want to confirm the FCC ID is an exact match with the receiver per this thread.
    RUSTYNUTS[QUOTED] likes this.
  15. Jan 7, 2022 at 7:22 AM
    alb1k
    Left Coast
    It's good
    They are Gen 1 specific
  16. Jan 7, 2022 at 7:50 AM
    Delrin, as in the plastic? The plastic which was the downfall of Simplex back in the day, because all of their parts would crack with age, causing countless injuries and probably some deaths? :rofl:
  17. Jan 7, 2022 at 7:58 AM
    daveeasa
    I may be wrong on material. It’s a hybrid version with an inner cylinder of aluminum for structure and an outer shell of hard plastic (I thought it was delerin since that is what he uses for shift knobs) for aesthetics matching the OEM curves. I can post a photo if you’re curious.
  18. Jan 7, 2022 at 9:04 AM
    Nah, we're good. I think Simplex's issue may've been with how thin they were making the plastic parts. But there was also controversy over using Delrin in the Corvair for the cooling fan, with problems glanced on in this article. Delrin is definitely still a thing today, DuPont makes it. I dunno if they've improved on it at all, but it has a miserable and problematic history not a lot of people are aware of. Maybe that's why they're still using it, or maybe DuPont made changes to stop it from weathering, greying, and offgassing, getting fragile.
  19. Jan 7, 2022 at 9:13 AM
    daveeasa
    I’m unable to resist sharing photos of these. They are beautiful.
    90CDFF2B-6336-4788-A3A2-6BFF5F8AC0AB.jpg 3008C9A7-CF6F-4589-B19B-ADCA265DA881.jpg 1ED7FF41-FA54-4097-88F5-DD61D4B30C49.jpg
    bmf4069 likes this.
  20. Jan 7, 2022 at 9:14 AM
    alb1k
    Left Coast
    It's good
    Those are awesome.
  21. Jan 7, 2022 at 10:30 AM
    Yeah, I just don't trust Delrin. I've had too many bad experiences with Delrin material fatigue, I've seen it rampant both in '70s-80s moped and bike applications.
    It's one thing if it cracks at an inconvenient time on a shift knob, probably nothing will happen. If it cracks on a seat riser, bad things are inevitable, just like times when it's cracked on a rear derailleur body, or jockeys, or on a front derailleur clamp while someone was riding and - teeth or noggin on pavement.
    I can show you some pictures of multiple examples. Don't relive the 1970s and 1980s. We learned our lessons with using Delrin back then, the hard way. Those who fail to study history are doomed to repeat it. I'm actually shocked anyone would use it for this purpose unless it's been reformulated.
    Seriously. Plenty of info on the internet about Delrin and structural cracking/offgassing/fatigue. Google: Simplex Delrin Crack.
  22. Jan 7, 2022 at 10:51 AM
    daveeasa
    The aluminum is where the bolt shank threads through. Then the aluminum collar seats the delerin. The Aluminum is 100% of the structure. The delerin is the window dressing. If it cracks away completely it makes no difference on the mechanics.
    chrisb, CodyP and KNABORES like this.
  23. Jan 7, 2022 at 12:22 PM
    Ah. I was thinking the Delrin part was the riser.
  24. Jan 7, 2022 at 12:24 PM
    daveeasa
    I like your cautious approach. But I posted the photos so it would hopefully be clear how I thought the design was pretty slick. At least from a "I have no mech E background whatsoever" perspective.
    KK6PD, shifty`[QUOTED] and alb1k like this.
  25. Jan 7, 2022 at 2:29 PM
    TonnoPro Tri-fold installed. Not sure if I feel it was worth $247 shipped.
    Curious to see how I feel about it once it has time to settle in.
    Also curious if this muffles any of my sound when the rear window is open.
  26. Jan 7, 2022 at 2:33 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I think that’s a pretty good price considering. I always have mine covered so can’t help if it cuts down on noise or not.
    FirstGenVol and alb1k like this.
  27. Jan 7, 2022 at 2:36 PM
    alb1k
    Left Coast
    It's good
    looks good. If it holds up and wears good it's worth it.
    CodyP likes this.
  28. Jan 7, 2022 at 2:37 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Interested in this for crackie, and the V6. Unsure if crackie came with RS3000, but feel like it should have. Didn't come with fob, but given it's history.... I would not be surprised if it was lost to the ages.
    As far as the V6, I lost the original remote about the same time that my flea-bay replacement shell arrived at the house. Typical.
    @daveeasa, what does the trunk button do for our trucks? This spurred you on to find the pop'n'lock for the tail gate?
    RUSTYNUTS likes this.
  29. Jan 7, 2022 at 2:40 PM
    daveeasa
    For mine, it's effectively 3 one button remotes glued together along with one button that does nothing. :)
  30. Jan 7, 2022 at 2:42 PM
    PS - quick tag to thank @FlightSimGuy for the reco on this. The place I bought it from only had two in stock at this price around NYE, and all other sellers were at least 10-20% higher. I Inbox/d FSG since I saw he had one installed, he gave feedback within hours. I was able to order the very last one before anyone else snatched it up.
    FlightSimGuy, chrisb, NUDRAT and 2 others like this.
