  1. Dec 16, 2021 at 3:23 PM
    raymond_hb
    raymond_hb New Member
    Oakland, CA
    07 Tundra Limited 2WD
    Howdy everyone,
    I want to get seat covers for my 07 because my seats are starting to to wear down. Any suggestions on what could match a Red Rock interior? I was thinking black but I’d like other opinions
  2. Dec 16, 2021 at 4:19 PM
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    BDS 7 w/ Fox 2.5 OME Dakar leaf pack CB +2 shackles 18x9 Method 308 +18mm 37x12.5 Toyo AT3 TRD intake/exhaust Infinity Kappa w/ Pioneer HU
    Wet Okole's would look awesome
    raymond_hb[QUOTED] likes this.
  3. Dec 16, 2021 at 7:02 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    If leather, Katskins are hard to beat.
  4. Dec 16, 2021 at 7:22 PM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    Matt Gecko bed lights. Awesome.
  5. Dec 16, 2021 at 8:22 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Color changing? Party mode?
    joseph_womack likes this.
  6. Dec 16, 2021 at 9:58 PM
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    Just picked mine up in the mail with a hood light. Can't wait to wire it up.
  7. Dec 16, 2021 at 11:54 PM
    TravisJr
    TravisJr New Member
    Lots o’ mods
    Just straight white - the night time photo makes it a little tricky to make out.
    Yeah, I got the same kit, just ran out of time. I’ll have to wire up the hood lights another day.
  8. Dec 17, 2021 at 10:40 AM
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    Installed the Trail Toys A Better Trim today. It was a bit of a pain because they really fit on there but I won't have to worry about rust settling in into the newly cut metal.
  9. Dec 17, 2021 at 1:49 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Filled up at Costco. 11.3 mpgs hand calculated.
    Winter blend and putting around town isn't helping.
    WVI and raymond_hb like this.
  10. Dec 17, 2021 at 3:35 PM
    Ericsopa
    Ericsopa Old man and the sea
    Installed the J&L oil catch can last night, then installed 3WLiners auto up/down window closer today. Sat around an hour trying to figure out how to run the little power wire through the rubber grommet from inside the door to the battery. Finally found a wire in the door to supply battery power, and used that instead. Works pretty nifty. Don't know that I'll use the key fob feature much to operate the windows, but it works.
    WVI, omgboost and MTRock like this.
  11. Dec 17, 2021 at 5:45 PM
    AstroDude
    Eddie
    They said it couldn't be done.
    They called me crazy.
    They said, I'd have a better chance of punching Santa Claus in the face.
    Well it looks like I just punched him in his fat fucking face, because I made the caliraised led molle panel made for a crewmax, fit on a double cab.
    I used an old bike tire tube as a sleeve to help reduce any chafing that would take place between the bed and the brackets.
    Now I can fit my recovery boards, propane tank and pro-eagle jack in the back.
  12. Dec 17, 2021 at 8:56 PM
    AstroDude
    Eddie
    Finally installed a light for my license plate so I can drive at night. Damn thing lights up the entire road
    Punisher17, WVI, D4x4TRD and 5 others like this.
  13. Dec 18, 2021 at 12:33 AM
    Peeeheeuuu
    Peeeheeuuu New Member
    Peter
    Elk Grove, CA
    08 Tundra CM 4x4. 21 Sequoia SR5 4wd
    How much did your steering wheel cost you and where did you purchase? I'm looking to do the same
  14. Dec 18, 2021 at 5:31 AM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    Where did you catch power from? On the 2nd gens what will the 3wL fully do?
  15. Dec 18, 2021 at 5:38 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  16. Dec 18, 2021 at 6:31 AM
    Ericsopa
    On my CrewMax with memory seats and mirrors, the outer mirror control ECU module is mounted on the driver's door just below the front edge of the window. There are two plugs into that module, N7 & N8. N7 is the smaller of the two, and pin #3 of N7 is constant battery power. It's a red wire with silver bands. I tapped in there.
    Every window (not the rear window, just door windows) will operate up and down with one touch from the driver's master switch panel. I'm not sure if they will also from the individual door controls, but I doubt it. I'll check that today and edit this after doing so. Checked this out, and as I expected, the windows operated from the individual passenger seats work as they always did, i.e., no auto up/down.
    Any door window left open when you lock your truck will close by pressing the lock button on the key fob. All door windows open by pressing unlock-lock-unlock on the key fob.
    This youtube video, embedded on 3WLiners website, shows what the unit does. In his installation, he shows the power taken directly off the battery, but he doesn't show how he got the wire to that point. The kit comes with the long power wire, but also has a another fuse on a short pigtail. That's what I used to supply power. Everything else in the kit is plug-n-play. https://www.youtube.com/watch?v=JasNy3ewPIQ
  17. Dec 18, 2021 at 6:39 AM
    COTundie
    Trey
    Pretty things
    It DOES exist!
    Might be too late to ask Santa, but definitely going on the wishlist.
  18. Dec 18, 2021 at 6:47 AM
    Ericsopa
    When I went to the 3W website a few minutes ago to grab that video, they infortunately indicate now that the units are on backorder.
  19. Dec 18, 2021 at 6:51 AM
    COTundie
    Trey
    Pretty things
    Well, if people like them, I bet they make more
    ...Maybe a second gen that includes the rear window?! Haha
  20. Dec 18, 2021 at 4:48 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    went to purchase 2 cases of transmission fluid at the stealership
    Guy at the parts desk: You don't need to change the fluid on the truck... Its synthetic blend no need for maintenance, manual calls for no maintenance
    I asked: If the transmission shifts funny and codes say change fluid as per the manual, what should I do then?
    Guy at the parts desk: So you needed 1 or 2 cases...
    LOL...
    Its on the list to do now.. trifecta.
  21. Dec 18, 2021 at 6:30 PM
    Red Sonja
    Red Sonja Mock Warrior
    Ben
    2007 Salsa Tundra LTD
    Bilstein 5100’s at top setting Eibach rears with Toytec 1.5” lift shackles 285/60 R20 Firestone Destination X/T 1.25” Spidertrax Spacers Custom 18” Magnaflow Exhaust(side middle exit) Vland LED headlights
    So they can sit back and wait to tell you that you need a new transmission.
    blackdemon_tt[QUOTED] likes this.
  22. Dec 18, 2021 at 7:00 PM
    blackdemon_tt
    LoL I know right.
  23. Dec 18, 2021 at 11:29 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    I’m going to put this on my wish list too. I have an aftermarket remote start, wonder if this will work with the aftermarket key fob?
  24. Dec 19, 2021 at 6:02 AM
    Ericsopa
    If the fob unlocks your doors, it'll work this, too. The module that controls the windows takes its cue when it senses +/- voltage to the door locking solenoid.
  25. Dec 19, 2021 at 2:17 PM
    Asmith2945
    Asmith2945 New Member
    Andrew
    Iowa
    2008 DC Tundra SR5 Grey
    Aftermarket rims, added fogs, new headlights, led brake light housings, cargo cover, nerf bars, bilstein shocks and coil overs, k&n drop-in filters, yellow sumo springs, Icon RXT leaf springs, after market 1” shackles, forged upper control arms, 3” spacer lift soon
    Added some more led reverse lights at the bumper. Used some recs from the geniuses (“genii”?) here and took very little time. Waiting for night now…F9584C35-BC7B-4D80-A5A4-2CF452C86685.jpg
  26. Dec 19, 2021 at 4:15 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Installed the RSB. I had the TRD bar powder coated semi-gloss black locally for $75 prior to install.
    Also scored a TRD dual exhaust locally on offer up for $300 a couple weeks ago. It already had the VHT black sprayed on the tailpipe sections.
    Overall I am very pleased with the changes out back!
  27. Dec 19, 2021 at 4:56 PM
    Retroboy1989
    Northern Utah
    Awesome score! I'd buy that.
    There was one local to me for $750. Doesn't tempt me.
  28. Dec 20, 2021 at 4:22 PM
    Red Sonja
    Ben
    Removed anthracite plasti dip from wheels and re-dipped them black sapphire. Did it in the dark so coverage wasn’t perfect. Oh well. Just have to make it until I can find cheap Rock Warrior 17’s and 35’s. Ha!
    Adarac M Series black bed rack on its way!!!
  29. Dec 21, 2021 at 11:10 AM
    raymond_hb
    Oakland, CA
    I love your truck man you beat to the punch. Thank I’ve been wanting to do this color with a lift looks great man!
  30. Dec 21, 2021 at 11:41 AM
    blackdemon_tt
    HELLO!!! HI!!! Long time since we've seen each other.. LoL.. I guess my fuel sender unit is no longer stuck... Its been about 5 years tbh
