Cruzer's Re-Build for the Rubicon
Discussion in '2.5 Gen Builds (2014-2021)' started by Cruzer, Dec 8, 2020.
  1. Nov 30, 2021 at 1:24 PM
    #541
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    I understand completely.:rofl:
  2. Dec 1, 2021 at 10:46 AM
    #542
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    So here's a video of the day trip out to Sand Hollow, from Las Vegas, back in June. Was doing both halves of Wayne's World.
    Could not get any traction with the loose sand when trying to get over obstacles.
    https://youtu.be/feW3gIFPbso
    Hightide, TG705, alb1k and 3 others like this.
  3. Dec 1, 2021 at 10:47 AM
    #543
    Sunnier
    Sunny
    San Diego, CA
    So then, you need beadlocks AND different tires. :p :spending:
  4. Dec 1, 2021 at 10:48 AM
    #544
    Cruzer
    Cruz
    Sunnyvale, CA
    True. I had 39s back then :D
    eccracer104 and Sunnier[QUOTED] like this.
  5. Dec 1, 2021 at 10:55 AM
    #545
    Sunnier
    Sunny
    San Diego, CA
    Can’t you just buy 3 sets: mud, sand, everything else…. Just wear one set and carry two…. :D
  6. Dec 1, 2021 at 10:59 AM
    #546
    Cruzer
    Cruz
    Sunnyvale, CA
    I was thinking along those lines this morning. I'll keep what I have on now as my daily. Then get a beadlock set with Mickey Baja Pro 40s for when I wheel.
  7. Dec 3, 2021 at 8:54 PM
    #547
    Built2Ride
    Built2Ride PM Me Let’s Ride Out
    JB
    SE
    2010 RCSB 4WD
    I got popsicles, whatchu got?!
    Sub’d
    Cruzer[OP] likes this.
  8. Dec 4, 2021 at 4:31 AM
    #548
    dorton
    dorton #RockCreekOverland
    North Carolina
    2020 Black Tundra SR5
    CBI Off Road Front Bumper, Rock Sliders, Skids, and Bed Rack. Prinsu Designs Roof Rack, CVT Hybrid Rainier Tent, Old Man Emu lift, Fuel Vectors, Yokhama 305/70r18s
    Cool thread. Looking forward to more.
    Kiddnapped Tundra and Cruzer[OP] like this.
  9. Dec 10, 2021 at 3:32 PM
    #549
    Cruzer
    Cruz
    Sunnyvale, CA
    So I started a new project - bed slides. I ordered Vadania locking 5ft super heavy weight slides. I cut a 10' 2x4 in half and bolted the slides onto it with the tops flush. The 2x4s are bolted directly to the bed via 3/8 carriage bolts. I added 1" angle iron on the inside track where I plan to use 2x2s to sit on top of it for cross supports.
    Thought my bed was flat but I guess through the years of beating it up it's developed some bumps and bruises. I got this far. Tomorrow I'll need to shave the bottoms of the 2x4s to accommodate for the bumps and ensure they are level and true.
  10. Dec 11, 2021 at 9:18 AM
    #550
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    Nice! We have those Vadania slides on some of our fire engine compartments, they sure can take a beating!
    Cruzer[OP] and eccracer104 like this.
  11. Dec 12, 2021 at 11:54 AM
    #551
    Cruzer
    Cruz
    Sunnyvale, CA
    Did some more yesterday, didn't finish though. Decided to use 2x6s instead of 2x2s for the cross support. Figured I'd over build it instead of fixing it later down the road.
    Can hold my weight fully extended out
    Hightide, 2mchfun, B.Ross and 6 others like this.
  12. Dec 16, 2021 at 9:29 AM
    #552
    Cruzer
    Cruz
    Sunnyvale, CA
  13. Dec 17, 2021 at 9:33 PM
    #553
    twintundra31719
    twintundra31719 New Member
    NV
  14. Dec 19, 2021 at 6:14 PM
    #554
    Cruzer
    Cruz
    Sunnyvale, CA
    I’ve been carrying my spare parts, tools, full size jack, liquids, and what not in those large 50gallon containers that you can get at Home Depot. I strap it to the bed to minimize movement but usually after one wheeling trip it gets thrashed and needs to be replaced. That ends here.
    Made a multi-level dual CV axle holder/full size jack carrier/long tool holder.
    Bolted it to the bed slide
    Made supports for the CV axles, which lifts it up so that the boots are not touching anything
    The lid has the same supports and will lock the axles in place.
    With the lid in place I can put the jack and all my long tools on top. Still need to get a threaded rod that will come up from the bottom to cinch down the jack and lid.
  15. Dec 19, 2021 at 6:19 PM
    #555
    twintundra31719
    NV
    Awesome work!!
    Cruzer[QUOTED][OP] likes this.
  16. Dec 19, 2021 at 6:31 PM
    #556
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    @Cruzer: I'm gonna break stuff and need essential parts.
    The rest of us: I may get a flat. Honey, you see my patch kit?
    Hightide, TheBeast, Kgfit85 and 7 others like this.
  17. Dec 19, 2021 at 8:47 PM
    #557
    Sunnier
    Sunny
    San Diego, CA
    Looks good!
  18. Dec 19, 2021 at 9:12 PM
    #558
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Badass product right there
    Much respect for your use of pocket holes :hattip:
    2mchfun and Cruzer[QUOTED][OP] like this.
  19. Dec 20, 2021 at 4:21 PM
    #559
    Cruzer
    Cruz
    Sunnyvale, CA
    So I added a 2x4 block at the center of the floor jack to prevent forward, back, and side to side movement. I then installed a 12" carriage bolt from underneath the bed slide and up through the lid and block where I secured an 1/8" metal bar that I pounded to make a clamp - waiting on a wingnut from Amazon. Now the floor jack, lid, and CV axles can no longer move up/down. Next up: make cubbies on the passenger side bed to better utilize that wheel well hump space.
    In other news:
    - Received my motor mounts from Solid Offroad - probably won't get that installed until next year.
    - Just got tracking info from Alcan on my new leaf springs. Thinking that'll arrive after the Cougar Buttes trip. Can't wait to get that ass up in the air - higher than it already is :D
    - Passed the HAM radio Technician License exam on Saturday and my name now shows up on the FCC database making me officially licensed :woot:
    TexasTundra27, Mater, Kgfit85 and 7 others like this.
  20. Dec 20, 2021 at 5:27 PM
    #560
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Congrats on the ham license. Once they assign you a call sign you may be able to switch it for free to something you like better. I switched mine to K2SGU.
  21. Dec 20, 2021 at 5:33 PM
    #561
    alb1k
    Left Coast
    It's good
    Hopefully there's a "C" and you can replace Charlie with Cruzer. And then they revoke your HAM, lol
  22. Dec 20, 2021 at 5:54 PM
    #562
    Cruzer
    Cruz
    Sunnyvale, CA
    SGU? :monocle:
    Are you moonlighting between BASTRDS and SGU? :rofl:
    831Tun[QUOTED] likes this.
  23. Dec 20, 2021 at 5:55 PM
    #563
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    It's all one big happy wheeling family.
  24. Dec 20, 2021 at 6:46 PM
    #564
    Cruzer
    Cruz
    Sunnyvale, CA
    Mine sucks KN6SFM :confused:
    Wonder if KR0OZR is available :monocle:
  25. Dec 20, 2021 at 9:41 PM
    #565
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Congrats on getting your license.
    It looks like “KR0OZR” is used and expires in 2030. Getting a vanity callsign is pretty straight forward. I used this site to help me find mine:
    https://www.ae7q.com/query/
  26. Dec 21, 2021 at 6:30 AM
    #566
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    I still need to do that test lol.
  27. Dec 21, 2021 at 7:15 AM
    #567
    Cruzer
    Cruz
    Sunnyvale, CA
    It’s actually pretty easy.
  28. Dec 21, 2021 at 8:09 AM
    #568
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    KR0OOZ appears to be available
  29. Dec 22, 2021 at 7:36 PM
    #569
    Cruzer
    Cruz
    Sunnyvale, CA
    Vanity call sign request submitted for this :fingerscrossed:
  30. Dec 23, 2021 at 9:44 AM
    #570
    RoninPro
    RoninPro Abecedarian BASTRD
    East Bay
    17 CM TRD Pro
    Nice. Next trip you will switch to a ‘Certified Ham’ radio?
