  1. Dec 17, 2021 at 9:48 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    You monster! Wheres your inner fenderwell to frame covers. TMI!
    Voss, Jack McCarthy, bmf4069 and 2 others like this.
  2. Dec 17, 2021 at 9:55 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    So, cambergs and fox, huh. A little overkill for a black truck, right?
  3. Dec 17, 2021 at 9:57 AM
    NWPirate
    Zach
    WA
    So sexy!
    Darkness[QUOTED] likes this.
  4. Dec 17, 2021 at 9:58 AM
    Unless running 35's, what is the benefit to removing them?
  5. Dec 17, 2021 at 10:08 AM
    I can see those JBA headers you installed years back aren't so pretty anymore. Ceramic coating might a better choice next time round.
    Darkness[QUOTED] and Siebler like this.
  6. Dec 17, 2021 at 10:14 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    i dont want to cut mine, but i’ll have flappy bits if i dont trim ‘em.
    Darkness likes this.
  7. Dec 17, 2021 at 10:17 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    *black Fox's
    I used to go off road before work became life :oops:
    To be fair I ripped them out while doing suspension work, meant to put them back in the next weekend and didn't bother. For Fox it does help since I had to relocate the resi on each side. I also ripped out the windshield washer resi.
    The metal isn't bad, its not rust. They turned brownish after a few months but haven't gotten worse. Visually it just isn't pretty.
    chrisb and Jack McCarthy[QUOTED] like this.
  8. Dec 17, 2021 at 11:44 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    This picture hurts my head.
  9. Dec 17, 2021 at 11:47 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Their aftermarket headlights run circles around first gen.
  10. Dec 17, 2021 at 11:49 AM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Was looking over my new to me 2000 Tundra, and noticed the Coil's are not factory or Denso. The good news is they look new, bad news is I would rather have old OEM or Denso's. Upon further inspection, I noticed all the harness wires going to the coil's are in no way covered. Anybody have a picture of what they should look like? Does Toyota make a cover set or is this a build your own situation?
  11. Dec 17, 2021 at 11:51 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Just tape?
    txagg likes this.
  12. Dec 17, 2021 at 12:05 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    @Sirfive Awesome! Thanks for the picture. That stuff kind of looks like the covers you heat up over a soldered wire. The way the ends closest to the coils looks, they must not be there for heat protection. Just to keep them from getting snagged. If I can't find a way to match the factory looks, I'll just go with braided sleeving
    Sirfive likes this.
  13. Dec 17, 2021 at 12:22 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea, loose shrinkwrap. And i havent had any problems with the wires, but the emission hose rubbers are suspect.
  14. Dec 17, 2021 at 2:25 PM
    Openbaffle
    Openbaffle New Member
    More headlight aiming...
    bmf4069, chrisb, Darkness and 2 others like this.
  15. Dec 17, 2021 at 3:10 PM
    .Looks like the left/driver needs to come down a smidge, but the rotation on it looks better now.
  16. Dec 17, 2021 at 3:46 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Swapped my tailgate over to crackie for sister help adventure tomorrow
    NUDRAT, chrisb, Voss and 2 others like this.
  17. Dec 17, 2021 at 3:59 PM
    Openbaffle
    I guess that was a question…is it a best practice to have one step or two? I’ve got more LEDs to swap out tonight (trying for green LEDs on the center console again. One more shot before I give up). I also wanted to wire loom the retro harness. I’ll see if I can get both of those things done later.
  18. Dec 17, 2021 at 4:16 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Pulled my other tacoma wheel out of the bed of the solver truck since it's now tail gate less. Bummer. Guess being flat for 30 minutes busted a band inside.
    Guess I need tires for the Tundra soon too. The other steel wheel will have to keep chooglin till payday
  19. Dec 17, 2021 at 6:38 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    My jba long tubes shipped and will arrive next week! I ordered new 3” cats, resonator, and muffler.
    bmf4069, RUSTYNUTS, chrisb and 5 others like this.
  20. Dec 17, 2021 at 6:38 PM
    lowell66dart
    lowell66dart New Member
    lowell
    South Louisiana
    2001 Tundra 4WD
    Rough Country level, RAS rear springs, Magnaflow, custom front bumper
    Installed Toyota upper ball joints today. My crappy HF tool did not have enough reach/room and Auto Zone didn’t have a tool so I cut the studs off and then was able to easily press the joints out. Install was tedious dueto space but not too bad. I did this on the truck, lower ball joint connected.
    I have now installed new coil overs, upper and lower ball joints and cv axles all at different times. Not recommended but I am really good at tearing this sucker down:)
    oscardog86, bmf4069 and hammeron like this.
  21. Dec 17, 2021 at 6:56 PM
    I was taught the departure line of the driver should always align with the entry line of the passenger. In that light, it looks like your driver fixture is aiming about 1" too high at its target, whereas it should appear like one cohesive line with two peaks.
    Was I taught right? I dunno. It also looks like both are aimed too high, but I can't tell how far from the garage door your truck is, and I don't see tape marks to gauge the height.
  22. Dec 17, 2021 at 6:59 PM
    daveeasa
    If I were smart I’d be playing with green bulbs right now while I’m stuck in LA traffic.
  23. Dec 17, 2021 at 7:00 PM
    Found the issue! There's a fix for that!
    bmf4069, chrisb, txagg and 1 other person like this.
  24. Dec 17, 2021 at 7:04 PM
    lowell66dart
    lowell
    South Louisiana
    2001 Tundra 4WD
    What I did was aim at my door and level the lights. Took a ride and looked at light output which was great. Then I pull up behind cars at traffic lights. If I’m not lighting up their interior I’m ok.
    chrisb and Openbaffle like this.
  25. Dec 17, 2021 at 7:06 PM
    Yesss!
    Duals or single exhaust?
    I still haven’t grown tired of mine
    Voss likes this.
  26. Dec 17, 2021 at 7:43 PM
    Openbaffle
    it looks high because my driveway is on an angle so the level is fine side to side but the height is all jacked up. I drove around this evening and it was overall too low I think. I did fix the 1” difference and brought the driver down, but now I think I need both up 2” or so.
    I am def. Not lighting up the interiors right now. I need to come up a bit because the beam isn’t throwing enough down the road.
    I also tried new green LEDs tonight and I don’t love them. Did the wire loom. That worked well. Replaced a blown led in the front (the little 194). I’ll play around with it more tomorrow.
    shifty`[QUOTED], chrisb and daveeasa like this.
  27. Dec 17, 2021 at 9:02 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I wouldn't go off your guesstimation. Just go by the FSM and do it the right way.
  28. Dec 17, 2021 at 9:14 PM
    daveeasa
    Another option for plastic trees to hold loom.
  29. Dec 18, 2021 at 5:10 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    Arringtonpalmer, shifty` and Voss like this.
  30. Dec 18, 2021 at 5:13 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
