  1. Dec 14, 2021 at 2:39 PM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    PC was $520 ($130 per) and OEM center caps from the nightshade and OEM black lug nuts were $235. So $755 plus the cost of the wheels, which in this case was $250 off of marketplace. So I’m into it $1,005.
    it’s just a basic gloss black powder coat.
    Bergy24[QUOTED] likes this.
  2. Dec 14, 2021 at 3:06 PM
    Zachp
    Zachp New Member
    Zach
    2016 tundra SR5 TSS 5.7
    Installed roof rack w/ light
    And light on front bumper-
    Also spod system
  3. Dec 14, 2021 at 3:29 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Very nice!
    mgm16trdpro likes this.
  4. Dec 14, 2021 at 4:55 PM
    SAGE63
    San Diego County
    Replaced Bakflip mx4 with Retrax Pro XR... Ordered mounts for track mounts for VooDoo max modular rack also. Yes it is actually Raining in San Diego
  5. Dec 14, 2021 at 5:24 PM
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    you’ll have to give us your thoughts. I’ve been eyeing these bad boys.
  6. Dec 14, 2021 at 5:29 PM
    Squatting Pigeon
    Holden
    North Texas
    I filled it up maybe halfway just to test it out, and I was really impressed with the water pressure! It did wane as it emptied out of course though.
  7. Dec 14, 2021 at 5:54 PM
    BrianH4x4
    BrianH4x4 New Member
    Shelby, North Carolina
    2015 silver sky metallic
    USB plug added for backseat 6 circuit fuse holder added Amp power steps Bed lights Bumper led ( anytime) lights Amp reasearch bed step Focal three way components up front Focal 165 in rear Jl xd200 amp for front stage Jl xd 300 amp for 10 W3 -D4 sub Maestro rr for steering wheel control
    gave her a bath today. Much needed.
  8. Dec 14, 2021 at 6:02 PM
    SAGE63
    San Diego County
    you can always pump it up with a bike pump or your compressor. There is also a pump cap available but not practical for up on the roof rack.I love my 3.8 gal waterport.
  9. Dec 14, 2021 at 6:19 PM
    Squatting Pigeon
    Holden
    North Texas
    I might get a tiny little bike pump for the tool box just in case :thumbsup:
    SAGE63[QUOTED] and HulkSmurf14 like this.
  10. Dec 14, 2021 at 6:21 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Trans and coolant flush at the dealership, now when I get my Valhalla shields I won't have to worry about taking them off for a while. :)
    Tundratoofun likes this.
  11. Dec 14, 2021 at 6:24 PM
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    Curious what is the offset for those wheels? Thinking about changing from the TSS wheels..
  12. Dec 14, 2021 at 6:29 PM
    AggiePhil
    College Station, TX
    Wired up the third brake light.
  13. Dec 14, 2021 at 6:35 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Have you got your interior strips installed yet?! Looking good @Ellis_McPickle ! You've been busy!
    AggiePhil likes this.
  14. Dec 14, 2021 at 6:44 PM
    TomballTundra76
    TomballTundra76 New Member
    2021 Tundra Crewmax Nightshade Ed
    Fitment was OK but the seat brackets are wider than the template allowed, but no biggie. Using some masking tape to hold the template in place when you mark the holes helps tremendously.
    As to the updates, my instructions stated to “cut on the line” but the YouTube vids were “inside” the lines. Just double check your instructions, rather than relying on the vids.
  15. Dec 14, 2021 at 6:50 PM
    SAGE63
    San Diego County
    Thanks. So did you cut on or inside the lines...
  16. Dec 14, 2021 at 7:07 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    According to the Google, 20”x8”, +60mm offset, 6.86” backspacing, 41 lbs.
  17. Dec 14, 2021 at 7:23 PM
    TomballTundra76
    I cut on the lines.
    SAGE63[QUOTED] likes this.
  18. Dec 14, 2021 at 7:39 PM
    AggiePhil
    College Station, TX
    Haven’t purchased any yet. Also not sure what wiring I’d tap into. Maybe the cargo light wire?
    HulkSmurf14[QUOTED] likes this.
  19. Dec 14, 2021 at 7:51 PM
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    The MattGecko Lights are pretty nice and really easy to install. I wired mine to the battery so I can turn them on at any time.
  20. Dec 14, 2021 at 9:14 PM
    badmotofing3r
    badmotofing3r To be so civilized, one must tell civil lies
    Zach
    Wyoming
    Hot Tamale
    Toytec lift and the works
    Hauled some 16' trim in the ol' Crew Max lolz
    coldcanuk, WFD473, GAknight and 4 others like this.
  21. Dec 15, 2021 at 3:02 AM
    redrum448
    redrum448 New Member
    Is this secure? as can you put tools in bed and not worry?
  22. Dec 15, 2021 at 6:24 AM
    RobertD
    Robert
    DFW, Texas
    As secure as the MX4. The retrax Pro is aluminum slats and it locks in the closed position. Only way into the bed is cutting thru the aluminum slats or tailgate, using a big pry bar to bent their way in, or if you leave either unlocked. Great to protect your gear, but if someone is set to steal from you, they will damage your truck to get what they want.
    Edit: it locks in multiple positions but I only mentioned closed since you want to secure the bed
    SAGE63 likes this.
  23. Dec 15, 2021 at 6:32 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Retrax is usually more secure than a tri-fold. Some members here have had to 'break in' to their own cover here for various reason and it's kinda easy with a coat hanger and knowledge of where to pull. My retrax kept sliding forward since it only locked on one side, so left a 1/2" gap on the other side - not enough to be able to get to the lock but enough if they had a pry bar to damage the truck and get in.
    If security is the main idea than Diamondback is the only way to go, like many things you get what you pay for. If you want to stop the snatch and grabs than both retrax or solid trifolds easily stop those.
    RobertD likes this.
  24. Dec 15, 2021 at 6:41 AM
    FitsofRage88
    Hill Country, Texas
    Thanks boss just trying to compare the wheels here on the forum found the TSS specs/info directly, attached photo of the TSS wheel. Tried searching for that other wheel per specs Could not find any facts..
  25. Dec 15, 2021 at 7:13 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    Damie 0 in 2020 so sad. We did not travel do to c19 2021 totally different..first in spring 2 months in sw.4800 miles, summer 2 months in nw 5900 miles ,early fall 1 month in sw 2400 miles..so 5 months an lots of miles with smiles. An we only paid for 7 nights of camping in 2 different national parks
  26. Dec 15, 2021 at 9:24 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    Looks like those are 9" wide after a quick search, so comparing the overall specs of the two, those would have 0.89" more poke than the wheels I'm about to install.
    Assuming these are the ones in question.
  27. Dec 15, 2021 at 11:21 AM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
    63308243-E54E-42B4-8522-CAA7949996D3.jpg Trigger showed up today.
  28. Dec 15, 2021 at 12:43 PM
    SAGE63
    San Diego County
  29. Dec 15, 2021 at 12:46 PM
    SAGE63
    San Diego County
    Yes lockable. I really need access when rack and tent are mounted. vs the tri-fold... otherwise I thought the Bakflip mx4 was great and secure
    RobertD likes this.
  30. Dec 15, 2021 at 12:47 PM
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    Got it dirty and did a little snow wheelin’ to take the dog for a hike.
    DomFasano, 300BLK, GAknight and 16 others like this.
