  1. Dec 13, 2021 at 9:00 AM
    Openbaffle
    Openbaffle New Member
    That is what I saw too, which is why I posted my picture of the 265s on my truck. Maybe they are 285s though?
  2. Dec 13, 2021 at 9:00 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    The label on the top one says 285 and they all appear to be the same size.
    I'll take a closer look at lunch in a minute.
  3. Dec 13, 2021 at 9:01 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    mine has a steel core that translates the sound a little better.
    yea, im wandering around with a beer in a robe and pajama pants at 11am.
    obviously the deer suck at yardwork.
    NWPirate, dinosaur, bmf4069 and 2 others like this.
  4. Dec 13, 2021 at 9:09 AM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Epic!
  5. Dec 13, 2021 at 9:11 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    FB294FE4-6709-462D-8747-53738BC50226.jpg 00802C55-1C3B-49E4-B887-CB82D4DB116E.jpg
  6. Dec 13, 2021 at 9:11 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    you know which axle he used? Im thinking ?10.25? Furd or 12/14 bolt gm or 44+ dana.
    or going full silly with TTB’s front and rear.
    oscardog86 and jerryallday like this.
  7. Dec 13, 2021 at 9:13 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Paint ‘disco trek’ letters of ‘em.
    chrisb likes this.
  8. Dec 13, 2021 at 9:19 AM
    Openbaffle
    Nice. The pic I posted up above with my LTXs are 285/70R17s. I don't think they look too small.
    Voss and chrisb[QUOTED] like this.
  9. Dec 13, 2021 at 9:21 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  10. Dec 13, 2021 at 10:09 AM
    EvilMilkshake
    EvilMilkshake New Member
    05 AC Limited 4x4
    Nice. I got these a month ago and so far I'm happy with them. Good dry traction, and fine in light rain on the road. Haven't driven in the heavy stuff or mud just yet. Light hum is there in the mid speeds 40-60, but real quiet above or below that!
  11. Dec 13, 2021 at 10:16 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Excellent news. Thanks for chiming in!!!
    The late model Taco bros seem to like them and their trucks are the same size as ours, but with v6s and big monthly payments. Seemed like a pretty safe bet.
    Darkness, shifty`, dinosaur and 4 others like this.
  12. Dec 13, 2021 at 10:20 AM
    Voss
    2003 AC TRD 4x4
    I had the light hum with the new KO2s as well. Went away after a couple k miles once they were broken in
  13. Dec 13, 2021 at 1:23 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Anyone have any insight into the valve stems? I was going to bring my Sprewells in tomorrow to get them mounted up.
    @Darkness @empty_lord @KarmaKannon
  14. Dec 13, 2021 at 1:30 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Never heard of that. I have E rated tires and regular rubber stems. I think they charged me $2 per wheel for them.
  15. Dec 13, 2021 at 2:38 PM
    Openbaffle
    Still rattling. The screws and backer rod didn't get it. But here's a nice looking picture anyways.
  16. Dec 13, 2021 at 2:46 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    I see the dash rattle issue is still alive and well around here, haha. After years fighting it I just shove a pen cap down between the dash and windshield. Tried backer rod (few times) and removing stereo and doing what I can through the opening. Every time I declare success but over time it comes back...
    Nice truck!
  17. Dec 13, 2021 at 3:15 PM
    Openbaffle
    Thanks. The LTXs are growing on me too. I’m kind of digging them.
  18. Dec 13, 2021 at 10:28 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I put backer rod in my dash and it slowly worked its way out in several spots.
    Jack McCarthy and Tundra2 like this.
  19. Dec 14, 2021 at 1:19 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You’ve got TPMS yea? Just uh.. run those
    The TPMS stems can handle the higher pressure vs the rubber stems
  20. Dec 14, 2021 at 4:21 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Technically, yes. My truck came with TPMS. It's disabled tho and and I have little desire to reenable it.
    My plan is to leave the TPMS stems in the stock wheels and have them in the basement. Then, should I ever sell the truck, I can sell it with the stock wheels and keep the Sprewells.
    shifty` likes this.
  21. Dec 14, 2021 at 5:18 AM
    pretty sure those higher load rated tires have a higher max psi. If your not gonna run 55-80psi in them, regular valve stems will do. Ultimately though, if you end up needing to or selling them, it would be nice to have the appropriate spec.
  22. Dec 14, 2021 at 5:59 AM
    daveeasa
    This is one aspect I wish we could easily swap. I would really like to have TPMS via my scangauge. I probably spend too much time with the nanny.
  23. Dec 14, 2021 at 6:12 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    The Coopers are E load range and the max inflation pressure is 80psi.
    I've ordered some high pressure snap-in stems. I'll have them in an hour or so. Same cost as the full rubber guys on our shelf.
    KNABORES[QUOTED] likes this.
  24. Dec 14, 2021 at 6:49 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Day 3 with new reflashed ECU. Feels more responsive and mid range definitely feels improved on highway runs. MPGs thankfully stayed the same. I still wanna buy another spare ECU and send in to DAP for his tune to compare both. Scheduling a dyno run for next week.
    bmf4069, shifty` and Openbaffle like this.
  25. Dec 14, 2021 at 7:06 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    And now I've ordered a set of 1" wheel spacers. I'm worried they won't stick out far enough to properly fill the arches.
    All my math is based on pictures and specs of my fave 1GT. We'll see how my math checks out this week.
    bmf4069 and oscardog86 like this.
  26. Dec 14, 2021 at 7:58 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    how thick is the sidewall?
  27. Dec 14, 2021 at 8:06 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Hard to say, but my not-so-calibrated pinch-micrometer says at least 10mm, if not 13.
    I can google and see if there's a spec on Cooper's website.
  28. Dec 14, 2021 at 8:08 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    No worries, dead reckon is good enough for me.
  29. Dec 14, 2021 at 9:22 AM
    dasanto2
    dasanto2 New Member
    2006 Tundra 4X4
    What size lift are you running in the front and rear? Did you have to upgrade your upper control arms and sway bar links?
  30. Dec 14, 2021 at 10:28 AM
    Openbaffle
    I am running this OME lift/level kit. I replaced both my UCAs and LCAs in the process. The replacement LCAs are OEM and I went with the SPC UCAs. I have a Torch off-road add-a-leaf in the back (as well as their pinion angle shim). I didn't replace the rear leaf springs, just added the extra leaf. I got about a 1.5-2" lift out of the back after adding the camper shell and bumper. I got about 2.5" of lift out of the front with the 2885 springs. I also replaced the outer tie rods, LBJs and got the suspension maxx extended links (also from 1st gen off-road). It's sitting pretty level now that it has settled.
    I'm running 285/70R17s now. In retrospect, if I did it again, I likely would have gone with the 2884 springs to have the front sit down a hair more. But I like the stance, wheel size etc. I'm running 1.25" spacers with +15 4Runner rims with no rubbing now that I removed the mud guards.
