DIY body lift
Discussion in 'General Tundra Discussion' started by Spvrtan, May 25, 2017.
  1. May 25, 2017 at 11:55 AM
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    Late post but before this past weekend's trip I had an hour to quickly get my homemade .75" body lift installed to help clear the 40s. Hopefully these photos help others out there with their own DIY job -- it's a really easy mod ..just kind of sketchy when you've lifted the body with wood blocks on a floor jack while sliding your fingers through small spaces.
    The reason I went with that size of a body lift is because it's the safest you can lift the Tundra body without having to modify anything else. The engine fan clears the shroud by about 2mm; the steering column gets extended by about 1mm. The material used was black UHMV plastic and I only have to swap out the 2 body mount bolts of the cab's rear because the 4 front bolts had plenty of unused thread.
    In that hour I was only able to do the cab body mounts so I'll have to do the bed mounts the next time I have a modding session, which should go by quicker since the mounts are easier to get to.
    Edit: Simplified steps below (assuming you've already made your pucks).
    1) Take all the nuts off the body mount bolt with a 17mm. There are 6 for the cab and 6 for the bed. If you have a 6.5' or larger, there are 2 extra body mounts on the bed. There are also 2 mounts on the rear bumper but I didn't bother with those since I don't have a rear bumper.
    2) Obtain access to the 4 body mounts at each corner of the inside of the cab by pulling up on each corner's carpet. I won't go into too much detail because these are pretty self-explanatory with a little common sense.
    3) From the driver's side front wheel well, peel back the rear engine bay flap to reveal the steering column. Loosen the bolt but do not remove it. Mark the two steering column shafts (where the bolt connects them) with marker or tape to make sure they don't rotate (rare that this would happen though).
    4) Working on one side of the truck at the time (ie. all driver mounts then passenger), lift up the body with a floor jack and some large pieces of wood. Be sure to have a secure jacking point because you don't want the body falling on your fingers while you're under there. Only lift the body enough to where you can slide a puck easily but no more.
    5) Push up on all the bolts or pull them up and out just enough to slide in the pucks above the stock body mount pads.
    6) Once all the pucks are in, put the nuts back on and torque to about 55ft-lbs after using threadlocker (I used blue Loctite).
    7) Once both sides of the truck are done, tighten the steering column retaining bolt.
    Rengawt, Ollie, MDHinSD and 8 others like this.
  2. May 25, 2017 at 12:09 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Wow. So you literally just lift the body up to fit the pucks in and that is it. Interesting.
  3. May 25, 2017 at 12:24 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Pucking crazy!
    BlueBottle and Voyagermike like this.
  4. May 25, 2017 at 12:33 PM
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    Nice work and nice looking beast
  5. May 25, 2017 at 12:37 PM
    Bob and csuviper like this.
  6. May 25, 2017 at 12:39 PM
    csuviper
    Broomfield, CO
    :p
  7. May 25, 2017 at 3:55 PM
    Spvrtan
    Kris
    San Diego, CA
    Oh, didn't know you guys were gonna add to that list. I'll add simple rundown of the exact steps to my first post.
    Cthulhu and T-Rex266 like this.
  8. May 25, 2017 at 6:42 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Place this on the DIY sticky thread.
  9. May 25, 2017 at 6:55 PM
    :notsure:
    Eclipsed & Floating likes this.
  10. Mar 10, 2020 at 10:20 AM
    coachflip
    coachflip New Member
    2016 CM
    ANy chance the pics can get fixed? I am interested in doing the exact same thing.
