35's or 33's with 3"/1" or 4"/2" lift
Discussion in 'Wheels & Tires' started by alta-tundra, May 24, 2017.
  1. May 24, 2017 at 10:41 PM
    alta-tundra
    alta-tundra [OP] New Member
    Hi all,
    Novice and new tundra owner. having huge indecisiveness on which route to go for lift and wheels.
    I have a 2016, 5.7L 4x4 SR5 tundra crew max. Putting on BF All Terrains and lifting it, (suspension) to accommodate the tires. I want a combo of best performance while still looking clean. Keeping the stock rims. Just need a truck that performs better off road, nothing crazy while still doing great for street. Stuck between 33" or 35" BF AT's and the right size lift either 3/1 or 4/2. any pics of either combo or suggestions would be great. I'm looking for clean well proportioned truck. I dont want the wheels to rub and look like they are taking up the whole wheel well...
    Any help would be greatly appreciated by myself and shop owner.. ;)
    thanks,
  2. May 24, 2017 at 10:59 PM
    Puud
    Puud Graveyarder
    Nebraska
    2017 Crewmax
  3. May 24, 2017 at 11:14 PM
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    37's and 7" Rough Country lift. Mine drives/rides just like stock.
    Mountun Goat likes this.
  4. May 25, 2017 at 3:36 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    Wheel offset will govern rubbing as well.
    If you make a post like this you gotta post a pic....just say'n
  5. May 25, 2017 at 3:51 AM
    Bienvenidos de Tejas! Post pics of your ride
  6. May 25, 2017 at 5:17 AM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
  7. May 25, 2017 at 6:17 AM
    JTP
    The Big Black Moose
    NO RUBBING
    Skew12, Mountun Goat, Munk and 7 others like this.
  8. May 25, 2017 at 6:19 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    35's either way
  9. May 25, 2017 at 7:07 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    While I wait so I can afford it, I'm still pondering the same thing, so I'm following, ha. I think I'm sold on the 295/70R18 though, which is near a 34.5.
  10. May 25, 2017 at 7:45 AM
    Hannabl
    Hannabl New Member
    Apollo Beach FL
    2015 Toyota Tundra XSPX CrewMax
    Optima yellow top, K&N complete cold air intake, ANZO USA full light package(headlights,tail lights, 3rd brake light, Light bar) Gibson full stainles cat back exhaust, Bak flip G4 bed cover, Taco tunes 12" sub box w/kicker sub and Mono block D Soundstream amp, Lumar 15% window tint, PowerStop Big brake upgrade all four corners, ..... Very soon 3/1 Toytec Boss lift
    I run 33x12.5/20 on my 3/1.5 level. my wheels have a positive 12 offset and are flush with the outer edge of my pocked fenders. I had to cut and heat mold my inner fender plastic to make 33s not rub in reverse. After a insane amount of research i found out on a level lift you need a BMC or body mount chop to fit 35s with no rub. This is the exact info i wish some one would have given me. With all that said 35s would look killer.
    Les7311, JTP and Jsena like this.
  11. May 25, 2017 at 8:15 AM
    Sixpack
    Sixpack New Member
    Central Florida
    2014 Silver Sky Tundra CM TRD 4x4 Limited
    Moto Metal 951 18x9 rims with 285x75x18 Nitto Terra Grapplers , ESP lockable under seat storage, Husky mats front and rear, ReadyLift 3/1, Undercover Flex trifold bed cover, Bed Rug, interior LED's, 15% tint all around, TRD CAI, Bully Dog Platinum GT tuner, TRD rear sway bar, Flowmaster Series 44 dual exhaust system, LED head lights and Fog lights, 32" LED light bar in lower bumper cover, Switchback running lights, much more to come...
    285X75X18 Nitto Terra Grapplers, 3/1 with 285's look perfect on trucks without fender flares...
  12. May 25, 2017 at 8:18 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If you go 12.5" wide on stock wheels, you'll likely hit your UCAs.
  13. May 25, 2017 at 8:27 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Are you sure you have a positive 12'offset??
    Hannabl[QUOTED] and JTP like this.
  14. May 25, 2017 at 10:36 AM
    JTP
    The Big Black Moose
    Thats the key to what ever you do on lift, wheels, and tires. You have to get the offset correct and know exactly what your getting yourself into. I went through wheel spacer and chopping the body mounts issues on my last Taco because I got bad advice after spending serious bucks. Well worth going to a very high end knowledgable 4x4 shop and or other good sources for the real deal and real info on what you want to do.
    Every tire, wheel, and lift combo is going to be different. Pick what you want and get as much info as possible before pulling the trigger. I lucked out that my Tundra came with these wheels and lift and who ever had ordered these got the off set and lift combo dead on the money. No spacers, no rubbing, and no hacking up the body mounts and I could still go up to 37's with no issues.
    Its what I wanted, tall skinny big tires and the truck up off of the ground. My set up is for a lot of highway road trip driving plus I can go off road when I get there. (and I think that its looks cool ;) )
    Darth Tundra and Jsena like this.
  15. May 25, 2017 at 11:25 AM
    PMG
    PMG New Member
    I just did this with a 2" level and its perfect.
  16. May 25, 2017 at 11:28 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Positive 12 offset wouldn't stick out that far
  17. May 25, 2017 at 11:29 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Yea that looks looks good
  18. May 25, 2017 at 11:29 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    What wheel and offset did you get? Got any photos?
  19. May 25, 2017 at 12:17 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I think that looks about right. He has 12.50" wides.
    Jsena[QUOTED] likes this.
  20. May 25, 2017 at 12:25 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I've done a lot of research since I'm doing -18 -24 offset and when I see 0 offset it sticks out a little past reg fenders with No fenders flares. but I dont know maybe. I know wheels have to be out another 2 inches to be equal with fender flares and if that's the case. I better do some more research
    joonbug[QUOTED] likes this.
  21. May 25, 2017 at 1:25 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Every time i think I know what I want, it seems like it changes based on what someone else shows. I first thought +18, but then changed to +1. I have the OEM pocketed flares, and I want the tires to stick out just past it.
  22. May 25, 2017 at 1:30 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I'll show you a picture of a -19 offset with 12.5 wheels with no flares.
    If that had flares in it, the tires wouldn't be past the flares at all. Maybe even with it, definitely not positive 12 offset would stick out or even wIth flares
  23. May 25, 2017 at 1:48 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Well the wheels I want only come in a 20, 1, -12. So I may just have to get the -12 and live with it. Will for sure look a lot better than it does now.
    Sorry to :threadjacked:
  24. May 25, 2017 at 1:58 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    No way! These tires would be about an inch past the flares... maybe more.
    Jsena[QUOTED] and TTU19 like this.
  25. May 25, 2017 at 2:47 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    How far out do fender flares go, 2 inches
  26. May 25, 2017 at 2:53 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    :notsure: I'd say 2-3" max?
  27. May 25, 2017 at 2:56 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Same size im running....VERY HAPPY !!
  28. May 25, 2017 at 3:19 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    That's my point exCtly. :p Plus 12 I didn't not think would be that far out...
    Sooooo I just got a quote from Findlay Custom.. it's a sister company to Findlay Toyota,, quoated me
    $6000
    6 inch Ready Lift with Bilsteins rear shocks
    35x12.5 Atturo MT
    22x11 Fuel Hostage matte Black
    Hypertech Spedo
    All installed labor :gossip: thoughts
    JAMES likes this.
  29. May 25, 2017 at 3:21 PM
    Puud
    Puud Graveyarder
    Nebraska
    2017 Crewmax
    Id say thats a pretty good deal
    Noodle and Jsena like this.
  30. May 25, 2017 at 3:28 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Don't think... just do it!!!!
