'21 vs '22 tundra tug of war
Discussion in '3rd Gen Tundras (2022+)' started by tyst8, Dec 6, 2021.
  1. Dec 7, 2021 at 10:36 AM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    It'll actually be an improvement if they designed the tank so you can use all 32 gallons. :burp:
  2. Dec 7, 2021 at 11:00 AM
    nuclear
    nuclear New Member
    run*
    Cygnus X-1 and Black Wolf like this.
  3. Dec 7, 2021 at 11:20 AM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Reminds me of fast and furious
    Cygnus X-1 likes this.
  4. Dec 7, 2021 at 12:25 PM
    Cygnus X-1
    Cygnus X-1 Gangster of Boats
    Timm
    STL
    2018 Taco Sport MT
  5. Dec 9, 2021 at 1:47 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    I was curious about this too, so I did the math rather than just assume the 5.7L V8, 4.30:1 rear end, and 6 speed auto were better.
    https://www.tundras.com/threads/wheel-torque-comparison-of-2021-vs-2022-tundra.99265/
    Pretty illuminating. The 2022 has a very significant advantage in wheel torque in lower gears over the 2021. The iForceMax makes absurd wheel torque numbers for a 1/2 ton, probably going to be governed hard by electronic nannies to save u joints, pinion gears, and tires…
  6. Dec 9, 2021 at 1:58 PM
    Coal Dragger
    Kung Fu Dick
    Yeah, just turn the audio down…. makes that video much better.
    New truck is faster, and it’s not even close.
  7. Dec 9, 2021 at 2:05 PM
    Cygnus X-1
    Timm
    STL
    2018 Taco Sport MT
    That's what I did :D
    No kidding..... And the 5.7L has a "beast mode" for takeoffs, if the driver so chooses.
  8. Dec 9, 2021 at 2:21 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    New truck has beast mode as well and a level up over the tow/ haul mode, its called tow+
    Cygnus X-1[QUOTED] likes this.
  9. Dec 9, 2021 at 2:21 PM
    DexterL
    DexterL New Member
    Hybrid has a larger rear diff to handle the torque
  10. Dec 9, 2021 at 3:02 PM
    pnw_rcutv
    pnw_rcutv New Member
    Tug of war tests are pretty useless tbh. However, did you see some of their acceleration videos against the two (which also weren't exactly great)? The 22 walked away from the 21 like it was towing an anchor....Also, TFL put out a video where a 22 pulled even with the new Raptor. I dunno guys this isn't even the hybrid which will be noticeably faster. Going to be some hurt feelings soon.
  11. Dec 9, 2021 at 3:07 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    it would be cool to see that drag race with 5.29 gears on the 2.5 gen.
    Cygnus X-1 and 2mchfun like this.
  12. Dec 9, 2021 at 3:08 PM
    UATundra
    UATundra New Member
    Also, TFL put out a video where a 22 pulled even with the new Raptor on 37" tires.
  13. Dec 9, 2021 at 3:08 PM
    pnw_rcutv
    Might help until about 60mph but after that gears alone isn't going to make up that much of a difference.
  14. Dec 9, 2021 at 3:10 PM
    pnw_rcutv
    Well the 35" models are only about one to two tenths slower max. The 37" tire package is actually lighter too. Still yes, it's a 5" taller tire factory and frankly looks 100x better than the Tundra so there is that. But it's a Ford so there is that too...I won't lie I've been heavily cross shopping both.
  15. Dec 9, 2021 at 3:13 PM
    UATundra
    UATundra New Member
    I think if both were on 37's the Raptor would have likely came out ahead. I'm sure it won't be long until we find out with all these videos coming out :D.
  16. Dec 9, 2021 at 3:14 PM
    pnw_rcutv
    Very true. 100lb wheel and tires package has it's disadvantages. However, with nothing but a intercooler/tune the Raptors are 600hp/650tq all day. Going to be quite some time before any Tundra hits that...
    Cygnus X-1 and UATundra[QUOTED] like this.
  17. Dec 9, 2021 at 3:29 PM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    Believe it or not the supercharged 5.7s already are. Harrop stage 2 with headers and a larger intake are making 600 at the wheels, so crank hp is way up there. I’m sure eventually the tuned 3.5 v6 will make some good power too, I guess VF tuner already said they are supporting it.
  18. Dec 9, 2021 at 3:36 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    You guys need to lighten up. TFL drag raced the new Tundra against the Raptor because we're truck guys and that's the type of thing we do for fun. You don't have to take it (or yourselves) so seriously.
  19. Dec 9, 2021 at 3:39 PM
    MadMaxCanon
    But we have to have something to bitch about since whining about tire size threads, 10mm sockets and lift threads has gotten really old at this point.
  20. Dec 9, 2021 at 3:59 PM
    #50
    pnw_rcutv
    Hell I'm happy they did and massively surprised at the outcome having it not be a Max. Those guys are pulling mid 5-sec 0-60 times at sea level with the Raptor 37's. That means the Max is going to be faster than I think people assume. I still haven't seen very good acceleration videos of a Max. I will bet money when people start seeing the true performance numbers from these TT engines and 10sp combos the whole "well the 21 looks better" stuff will be yesterdays news.
    Cygnus X-1 and Toyota1234 like this.
  21. Dec 9, 2021 at 5:20 PM
    #51
    Cygnus X-1
    Timm
    STL
    2018 Taco Sport MT
    Yup I'm all in on this.
