  1. Dec 4, 2021 at 7:54 AM
    Lovely. This was done by a plumber too. Can you send me a link to what you're talking about.
  2. Dec 4, 2021 at 7:56 AM
    I don't see seals on the T either.
  3. Dec 4, 2021 at 8:00 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I ran at just over 3" lift for a bit over a year with stock links. That included a lot of fast abusive runs through fire trails. I didn't have a problem. Then I removed the whole assembly and still drive without it.
    Then again, I live in CA and metal likes it here, in states that are harder on metal maybe an upgrade is sensible. A lot of guys run beefier links like these, and maybe they can be found cheaper.
    https://suspensionmaxx.com/product/SMX-122270T
    If your links are not broken I would try running what you have for now and see where it takes you. If they are damaged, good time to upgrade. At least they don't affect alignment or anything.
    dinosaur and chrisb[QUOTED] like this.
  4. Dec 4, 2021 at 8:02 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Excellent.
    I'll look for those.
    Going to try stock before I go too far overboard. The truck isn't my primary project...and does most of its miles on the freeway. I'll see what I can dig up that's stock and upgrade to the maxx links if I find myself in need.
    Mine have already been recycled. They would not come off the LCAs, so they went in the bin.
    Darkness[QUOTED] likes this.
  5. Dec 4, 2021 at 8:10 AM
    See that opaque white ring on the right side of the tee after you loosened that nut, that’s why should be there, or
    https://www.homedepot.com/p/Everbilt-1-1-2-in-Sink-Drain-Pipe-Plastic-Slip-Joint-Nut-with-Rubber-Reducing-Washers-C2698C/205154062
    or something like this if that 90 doesn’t actually slip up into the basket strainer
    https://www.acehardware.com/departments/plumbing/faucet-and-faucet-repair/plumbing-washers/44373
  6. Dec 4, 2021 at 8:11 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Between the strainer and the elbow pipe there should be a flat style plastic washer. It isn't the beveled style, its more of a tee style like this. It goes on the flat flange of the pipe and the nut on the basket sandwiches it. Look fot "drain tailpiece washer"
    The other pipes will have the beveled washer that Noah mentioned
  7. Dec 4, 2021 at 8:11 AM
    I think I have a few of those on hand from previous work. Thanks!
    Tundra2 likes this.
  8. Dec 4, 2021 at 8:15 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Top one at the basket butts up, the rest are slip fit with beveled washer. Check those for broken washers, happens pretty often. Those nuts don't need to be super tight either, just a little past snug. They don't hold pressure.
    And white pipes drain the slowest.
  9. Dec 4, 2021 at 8:34 AM
    I mean, I'd just like to have the step bars and associated hardware if they're in good shape. I've been meaning to tuck a pair a way 'just in case'
    We used to find them all the time in grove ponds, golf courses, grove irrigation canals (which always had some HUGE largemouths here and there!) and anywhere else. But much of my time was spent at least 20-30 minutes inland.
    I can tell you with high confidence, the fastest way to find out if there's gators in a body of water is to take a stick and thrash it around in the water for 60 seconds like an animal that's drowning. If there's a gator within 100yds, it'll show up. This is what we'd do any time we went giggin' for bullfrogs. At night, shining a flashlight across the top of the water you're milling around in, their eyes will light up like lasers also. Though, IMO, you need to have a brass pair to do what we used to do as teenagers and young adults. The froglegs were worth it, but my sense of consequence is a little higher these days, don't think I'd wade for something to stick like we did back then. Shore gigging only.... Or treble hooks with red cloth.
    bmf4069 and dinosaur like this.
  10. Dec 4, 2021 at 8:35 AM
    NWPirate
    Zach
    WA
    Is your wife T1D?
    Hooptytrix[QUOTED] likes this.
  11. Dec 4, 2021 at 8:36 AM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Yes she is, can't hide that big white sucker
    NUDRAT[OP] and NWPirate[QUOTED] like this.
  12. Dec 4, 2021 at 8:43 AM
    NWPirate
    Zach
    WA
    That's one of the smaller ones I've seen, does that inject insulin or just transmit to a Dexcom?
  13. Dec 4, 2021 at 8:47 AM
    Is one of these better than the other?
  14. Dec 4, 2021 at 8:55 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Left one goes between basket and the elbow, flat side up.
    Other one is a thick boy but thats for the slip fit joints where pipe goes into other pipe.
    MS22 and FirstGenVol[QUOTED] like this.
  15. Dec 4, 2021 at 9:00 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    you guys talking about the little running bulbs On the inner side of the headlights? I didn’t get 4. I just got 2 switchbacks for the separate turn housings. If I need two more what size are they?
  16. Dec 4, 2021 at 9:04 AM
    Hooptytrix
    Dirty South
    Transmit only. She stopped wearing it cause they keep falling off and there expensive. She goes back to the Dr on Monday and hopefully he can find something else that she can be ok with
    NWPirate[QUOTED] likes this.
  17. Dec 4, 2021 at 9:29 AM
    dinosaur
    dinosaur New Member
    Dave
    2004 DC Tundra 4x4
    They are the same size as the ones that I already bought - 3157A. I don't have that little corner light on my 2004. Based on what @empty_lord said, I should get 2 more 3157A bulbs in LED to match. I may see if I can get something cheaper as those Diode Dynamics were a lot $$$
    Cummins3500 likes this.
  18. Dec 4, 2021 at 9:31 AM
    NWPirate
    Zach
    WA
    Best of luck with that. T1 life isn't easy, as you know.
    Props to you guys.
  19. Dec 4, 2021 at 9:33 AM
    dinosaur
    dinosaur New Member
    Dave
    2004 DC Tundra 4x4
    Better check what you have, because Access and Double Cabs are different - maybe different years of DC are different too.
    CodyP likes this.
  20. Dec 4, 2021 at 12:07 PM
    Helped JPink move a couch and buy some drugs today. Goober lost his wallet. Check out his custom plate. :D
    jpink, chrisb, bmf4069 and 4 others like this.
  21. Dec 4, 2021 at 12:31 PM
    Looks just like the Bernie & Phil sleeper sofa special I picked up on 4th of July for 70% off.
  22. Dec 4, 2021 at 12:38 PM
    As it turns out, there is already one inside the PVC elbow where it's leaking. I don't see how it's possible to add another one on the other side because this lip is there and the nut won't come off.
  23. Dec 4, 2021 at 1:04 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Pull that one out, put the new one in and smear some vaseline on the top surface and the threads. Reinstall and tighten it up. Half the time they loosen up and leak even if retightened.
  24. Dec 4, 2021 at 1:18 PM
    Good call. That's what I did minus the Vaseline since I don't have any. That old seal was loose. The new one is snug. I put some pipe thread seal on the threads.
  25. Dec 4, 2021 at 1:21 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    If you swap an open diff carrier (center of 3rd member that the ring gear bolts too and has the spider gears in it), you can.
    I have one if anyone wants one. I'd give it away, or maybe trade for a worn OEM LSD I can rebuild.
    dinosaur likes this.
  26. Dec 4, 2021 at 1:25 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Those guys don't seal on the threads but it isn't going to hurt anything, just something to help out turn a little easier.
  27. Dec 4, 2021 at 1:28 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Fedex changed my delivery date from Tuesday to Friday, then predictably from Friday to today. Problem is I'm out of town this weekend for a funeral. I talked to my neighbor and he was gonna grab it for me.
    I woke up this morning to an alert saying Monday. So I told him never mind and didn't leave him a key.
    An hour ago I got a text from FedEx, delivered. WTF. I text my neighbor to grab it and bring it into his house.
    chrisb, bmf4069 and dinosaur like this.
  28. Dec 4, 2021 at 2:26 PM
    daveeasa
    I can definitely send you my LSD once it’s out. Maybe even drop it somewhere on the next horse haul and you pick it up like a treasure hunt. It could be a while before it’s out though, I assume I have to get to Chandler for that?
  29. Dec 4, 2021 at 2:46 PM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    wow the 9006 to 9012hir (low beam) and 9005 to 9012hir (high beam) both in a reflector housing makes a huge improve. last night was projectors and tonight another car with reflectors. i’ve done the 9006 to 9012hir in another car and it was tremendus. same thing on this today.
    anyone with the 9006 should at least do this to 9012hir.
  30. Dec 4, 2021 at 3:15 PM
    daveeasa
    I bought these earlier today mid kid screaming / fighting. I’m not sure at all if I need them. But it seemed like maybe a good idea once I get the suspension on. Just waiting on Deaver and Fox to deliver.
