Who still makes fog lights and a housing for 2006 DC?
Discussion in '1st Gen Tundras (2000-2006)' started by Heger, Nov 26, 2021.
  1. Nov 26, 2021 at 8:49 AM
    Heger
    Heger [OP] New Member
    I want to get fog lights on my 06 DC, but I can't find any outfit that still makes the a fit kit or housing for the fog light? Looking any recommendations. All the other posts on this are too old. I pinged Baja Design and Rigid directly, but no luck. Thanks in advance for any help.
    thunder100 likes this.
  2. Nov 26, 2021 at 9:08 AM
    lowell66dart
    lowell66dart New Member
    lowell
    South Louisiana
    2001 Tundra 4WD
    Rough Country level, RAS rear springs, Magnaflow, custom front bumper
    Rock Auto have some.
    2006Tundra likes this.
  3. Nov 26, 2021 at 9:15 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    @Heger I bought my OEM style on Rockauto.
  4. Nov 26, 2021 at 9:36 AM
    Cummins3500
    Logan
    Oem is gonna be your only complete plug and play option. Nobody makes a kit specifically for the 1st gens. The custom route turns out pretty good though 6E9EFE8F-804B-444F-822E-AE8E42B23479.jpg
    Rocketfuel12, dinosaur and Darkness like this.
  5. Nov 26, 2021 at 12:04 PM
    Heger
    @Cummins3500 So you just mounted those Baja Designs fogs in the empty existing black plastic “tunnel” that your Tundra came with, right? And you got them very flush and set back.
    Cummins3500 likes this.
  6. Nov 26, 2021 at 1:57 PM
    Cummins3500
    Logan
    pretty much got the jist of it. The Baja designs squadron sports and squadron sae’s like I used set in pretty far. Drill a hole top and bottom of the blanks. Top hole is for your mounting bolt and bottom hole is for wiring. Mine are wired straight to the oem wiring and works with the switch in the truck. Not a bad build out. I used flat washers and a lock washer to take up the slack on mine.
  7. Nov 26, 2021 at 2:16 PM
    Heger
  8. Nov 26, 2021 at 5:19 PM
    Openbaffle
    Openbaffle New Member
    Did this with my squadron SAEs.
  9. Nov 28, 2021 at 10:15 AM
    Heger
    @Openbaffle Can you please explain that 2nd picture a little more? I want to be sure I understand the flat metal piece with the bolt through it and the zip-tie. Thanks in advance.
  10. Nov 28, 2021 at 10:56 AM
    Openbaffle
    This should help:
    https://youtu.be/3ENzlpG1CQQ
  11. Nov 28, 2021 at 4:50 PM
    2006Tundra
    Lou
    Long Beach, CA
    That's really clean. Anyone know where I can buy the baffles? I don't have a 3D printer.
    fighthedude likes this.
  12. Dec 1, 2021 at 6:30 PM
    C_Wood
    C_Wood New Member
    05 Tundra
    @Openbaffle Where did you get that piece 3D printed from? Is it something that can be ordered online? If not do you have the file to make myself?
    Those plug & play fog light adapters are sweet too.
  13. Dec 1, 2021 at 7:27 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 340k+
    2” Lift, Bilstein 5100’s and 885’s, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags with Daystar Cradles. Spider Trax 1.25” Wheel Spacers, Factory Wheels wrapped with Toyo 285/70r17 AT2’s.
  14. Feb 25, 2022 at 12:49 PM
    Nick.hiatt
    Nick.hiatt New Member
    ordered all the parts for this mod, then watched OpenBaffle's tutorial on Youtube and realized that he uses that custom 3D printed shroud.
    Any follow up on how you obtained these, OpenBaffle?
  15. Feb 25, 2022 at 12:54 PM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
    get the STL, send that to me as well as filament and i can print them for you.
    Nick.hiatt[QUOTED] likes this.
  16. Feb 25, 2022 at 12:57 PM
    Nick.hiatt
    I would love to purchase a set from you as well if willing!
  17. Feb 25, 2022 at 1:01 PM
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
    Shoot me a PM. I don't have the file but if @Openbaffle provides it then i can print it and send it to you. I wouldn't charge you but id keep the leftover filament.
  18. Dec 28, 2022 at 7:41 AM
    CarolinaYota
    CarolinaYota New Member
    2005 1st Gen Tundra
    Any one ever get the 3D print file for this?
