  1. Nov 26, 2021 at 12:22 PM
    Openbaffle
    Openbaffle New Member
    For sure. I thought I had some more, but I don't. Heading to grab some right now.
  2. Nov 26, 2021 at 12:25 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    You are correct.
    chrisb[QUOTED] likes this.
  3. Nov 26, 2021 at 1:21 PM
    daveeasa
    FWIW, those connectors appear to be weatherpack. I have some males if needed.
  4. Nov 26, 2021 at 3:10 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    @bmf4069
  5. Nov 26, 2021 at 4:05 PM
    dinosaur
    dinosaur New Member
    Dave
    2004 DC Tundra 4x4
    I did an oil change and installed a new short antenna today.
  6. Nov 26, 2021 at 4:42 PM
    Openbaffle
    Got my new deflecting beam torque wrench today and re-torqued the Torch u-bolts to 110 and my lugs to 83. Also verified the rear shock bolts. The deflecting beam is pretty cool.
    Measured the height post-cap. On the driver's side I'm sitting pretty level -- right around 23" in the front and 23.25" in the back. The passenger side rear, however is 22.5". Front passenger is right over 23". I've got about a .75" difference in the axle perch to the frame from side to side.
    I'm getting it re-aligned Tuesday, where I hope they can move the caster forward as much as possible per your recommendations to address the space in front.
    The side the side variation perplexes me, however.
    I ordered the replacement parts for the shell. 17" 40 lbs gas struts and the techflex for the wires. Also going to run a wire back to the fuse box in the front so I can have continuous power for the dome light. I need to figure out which size dome light is in there so I can get a matching LED. I suspect it is a 41mm or so.
    I also have to fix the dome light pressure switch.
    Finally, I grabbed some mini projectors for my current empty headlights, because I don't know when my retrofits are going to be done and it's getting dark here way too early to not have headlights.
    I need to pull my fogs lights out tomorrow and put Loctite on the bolts and do some other stuff this weekend. All the rest of the parts come Sunday so I should be good to go before the weekend is over (until the next thing to work on!).
    If anyone has any ideas or anything to check on the side-to-side level or axle, let me know. I'm open to ideas. Or maybe I am stressing out about it too much.
    Torque wrench.
    Driver's front:
    Driver Rear:
    Passenger Axle Perch to Frame Bottom:
    Driver Axle Perch to Frame Bottom:
  7. Nov 26, 2021 at 4:52 PM
    bmf4069 Captain wtf
    I did this today:
    Then I found this:
    So then I bought this:
    And I did this with them:
    Guess what? Ironman idles like normal again! No more lunging, no more big block idle, no more codes. So I didn't get to do my axles this weekend like I wanted, but I do have a driveable truck again. I'm just glad it didn't suck a piece of that gasket in. For anybody wondering, those are the ITM gaskets on rock auto. I put them in about 3 years ago, about 3000 miles I believe. It's on my VC thread when I did it. I'd recommend AGAINST buying them for this reason. Anyways, here's a booty shot of the intake manifold for you pervs.
    oscardog86, hammeron, chrisb and 18 others like this.
  8. Nov 26, 2021 at 5:28 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    I need to take the time to clean those areas up for sure, I may take you up on your offer!
    The KO2's are actually really quiet for what they are, most folks running these will agree. But they are a mother to balance. Took me three trips to my local tire shop to get them right (3rd time they finally did the road force balance).
    Openbaffle likes this.
  9. Nov 26, 2021 at 6:17 PM
    Agreed. I'm surprised at how quiet they are.
    chrisb, des2mtn and abcinv[QUOTED] like this.
  10. Nov 26, 2021 at 6:22 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    Really? I ran them for about a year and compared to my Geolanders, they were pretty noisy.
  11. Nov 26, 2021 at 6:57 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    How’s the reception? I’ve never had a tiny antenna that was worth a damn
  12. Nov 26, 2021 at 7:01 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    The one I have seems fine, but honestly I haven't pushed it. Pandora.
    chrisb and dinosaur like this.
  13. Nov 26, 2021 at 7:33 PM
    dinosaur
    dinosaur New Member
    Dave
    2004 DC Tundra 4x4
    Well then, you haven't tried "The Original" 6-3/4" Antenna! Here's a link to where I got mine https://www.ebay.com/itm/332601919442? . Actually, I would say it is about 95% as good as stock. One station, from a town an hour away, had a little static in my garage, which cleared up after I backed out. The stocker didn't have this static in the garage, but did have some issues in different parts of town -- more testing needed. All the local stations were great.
    Darkness and TRDGen like this.
  14. Nov 26, 2021 at 7:38 PM
    alb1k
    Left Coast
    It's good
    And somebody’s listening to this. That below is what I got.
    dinosaur, Darkness and des2mtn like this.
  15. Nov 26, 2021 at 7:39 PM
    People still listen to the radio?
    I have the stubby antenna and it works fine.
  16. Nov 26, 2021 at 7:45 PM
    dinosaur
    dinosaur New Member
    Dave
    2004 DC Tundra 4x4
    Scary. This is the world we live in now, no going back. It's so convienient.
    Yeah, and I have an aftermarket HU with a CD player, which was not that easy to find.
  17. Nov 26, 2021 at 7:58 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
  18. Nov 26, 2021 at 9:27 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    They're getting harder to find for sure. I had to have a touch screen with CD/DVD player so I can watch movies when I'm stuck in the truck at work or to lul me to sleepy time while camping
    dinosaur[QUOTED] likes this.
  19. Nov 26, 2021 at 9:58 PM
    empty_lord
    05 rollover special
    Believe it or not occasionally I do
    dinosaur likes this.
  20. Nov 27, 2021 at 4:37 AM
    I feel old now. I listen to the local news on AM but its mostly to hear the HS game scores for baseball and football when my nephews were playing.
    dinosaur, bmf4069 and FrenchToasty like this.
  21. Nov 27, 2021 at 5:20 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I use my stubby to pickup signal from my Bluetooth to FM transmitter; works great for that.
    dinosaur and bmf4069 like this.
  22. Nov 27, 2021 at 7:18 AM
    alb1k
    Left Coast
    It's good
    I do that too (both)
  23. Nov 27, 2021 at 8:25 AM
    Henry1stGen
    Henry1stGen New Member
    Henry
    2002 Tundra AC TRD
    Headlights, audio, interior, suspension, bed lights, and more
    I went with a mechless HU only because I have already converted my CDs/DVDs to digital media that I can store on a micro SD card. I am able to play on my HU using a android app that plays all digital media.
    1. You will need a android HU with a SD card reader.
    2. That HU must be able to download a app called MX Player or similar from Google Play.
    3. You will need a computer with a CD/DVD that you can use to convert to digital media using software such as DVDFab or similar.
    4. If your computer does not have a SD card reader/writer you can buy a USB card reader on Amazon.
  24. Nov 27, 2021 at 8:35 AM
    shifty` Goons of Hazzard
    Well, that explains the hissing in the intake area. Guess that should've been a no-brainer to explain vacuum-leak-like condition where hissing is coming from the intake.
    Glad you figured it out. Even gladder you fixed it.
    https://www.youtube.com/watch?v=VD7BV-z5GsE
  25. Nov 27, 2021 at 8:42 AM
    daveeasa
    I have a 10 year old alpine on eBay which does dvd and includes the phone module. Free to anyone here if you want it. Some gorilla glue which might be possible to remove.
    7BDA90E1-603F-42DE-B1D4-AC96CA0F1962.jpg E1762760-790D-4B67-AA93-855BA1A62A30.jpg
    I listen to the radio when I don’t have kids in the car. I’ve started doing country radio actually. And I don’t even like country. Wtf right?
    dinosaur and Darkness like this.
  26. Nov 27, 2021 at 9:05 AM
    Openbaffle
    I got a metal ruler this morning to re-measure the after-lifted height again a bit more accurately. I think I'm overthinking this. But more accurately measuring the height now I get (full tank of gas, more or less):
    Front L: 22"
    Front R: 22.5"
    Rear L: 22.75"
    Rear R: 22.5"
    So I'm about a .75" rake on the left side and nearly level on the right. I'm only .25" different in the rear L/R, which is likely OK.
    Darkness and dinosaur like this.
  27. Nov 27, 2021 at 9:10 AM
    alb1k
    Left Coast
    It's good
    You are over thinking it - but, FL up 1/2" or so likely gets everything within 1/4 with gas and before you sit in it, maybe after. Or a tad town FR.
    Edit: I focus on the front. unless the rear is visibly canted. More travel in the rear and generally less weight, front is more critical IMO
  28. Nov 27, 2021 at 9:52 AM
    alb1k
    Left Coast
    It's good
    @empty_lord - Do you remember who? I feel like I've seen them, but for the life of me can't find them...
  29. Nov 27, 2021 at 9:53 AM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    99% of "county" radio stations play a warped sort of Pop they call country. That might explain it. Especially in San Diego. Even KSON gave in a long time ago, aint the station my grandparents listened too anymore thats for sure.
    des2mtn, shifty` and dinosaur like this.
  30. Nov 27, 2021 at 10:00 AM
    daveeasa
    For sure. Every now and then it’s got a little bit of country but mostly pop.
