  1. Nov 25, 2021 at 9:29 AM
    Openbaffle
    Openbaffle New Member
    I think mine are 16x7 too, right? ETA — they are of course 17s…
    I’m wanting to step up to wider tires too. Thinking of the 285/70R17s would look really good with the rig.
    272ABD29-8AA4-4AA0-A3E3-6ED850222918.jpg EC187141-0ED5-4836-A24D-385009C6B878.jpg
    alb1k and daveeasa[QUOTED] like this.
  2. Nov 25, 2021 at 10:35 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Yes, if the parts are available.
    OEM and TRD LSD's are this way as well.
    Punk1974[QUOTED] likes this.
  3. Nov 25, 2021 at 10:38 AM
    Those are early 5gen trail wheels from a 4runner, somewhat rare because now all of them are black faced. But those are 17x7.5. I have them on our SR5 runner and I have a spare for the truck with one.
    Openbaffle[QUOTED] likes this.
  4. Nov 25, 2021 at 11:58 AM
    Openbaffle
    Yea these ones. Can you run big tires on these like the 285/70R17s? I’m assuming these have a better offset for our trucks.
    0h6SR5 and abcinv like this.
  5. Nov 25, 2021 at 12:12 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Those should be +15mm offset IIRC. When I went to 0MM and 8.5", the combination pushed me out about an 1" on each side. (outside of wheel)
    abcinv and daveeasa like this.
  6. Nov 25, 2021 at 1:16 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    Ive seen dudes run that size on those, but most get spacers. I think it will hit the UCA without a spacer. I use to have a pair in that hyper silver and I still think they are the best oem wheels i have seen, but I never put 285/70r17 on them
    abcinv and alb1k like this.
  7. Nov 25, 2021 at 3:45 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    I know the 275/70's will fit -
    Darkness, sn_85, bmf4069 and 5 others like this.
  8. Nov 25, 2021 at 3:50 PM
    alb1k
    Left Coast
    It's good
    me too.
  9. Nov 25, 2021 at 4:50 PM
    0h6SR5
    0h6SR5 New Member
    2006 Phantom Grey Tundra
    3 inch OME with AAL wheels and tires. 285 70 17
    that’s awesome!
  10. Nov 25, 2021 at 4:52 PM
    abcinv
    Tommy
    South of ATL
    Very nice sir!
  11. Nov 25, 2021 at 4:54 PM
    Openbaffle
    Dig those Methods. Must. Not. Buy.
  12. Nov 25, 2021 at 5:03 PM
    Openbaffle
    I have this wiring harness from my Baja Designs Squadron SAE fogs that I didn't need to use because I just tapped into my existing fog light wiring. I should be able to use these connectors for my 3rd brake light on my Snugtop cap, right? There is just a molex hanging out there now, but these seem a bit more rugged and waterproof. I was planning on just tapping off the left tail brake light. I'm assuming the 3rd brake light on the cap works, I didn't try it. Out of energy for today. Will attack it tomorrow.
    FrenchToasty and 0h6SR5 like this.
  13. Nov 25, 2021 at 5:21 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    I had em on both my 1st gen tacos. I wish I had kept them for my tundra
  14. Nov 25, 2021 at 7:04 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Pulled the trigger on long tubes. Sure wish I could’ve gotten a set of stans before he retired. I was about 3 weeks too late like everyone else.
  15. Nov 25, 2021 at 7:56 PM
    Henry1stGen
    Henry1stGen New Member
    Henry
    2002 Tundra AC TRD
    Headlights, audio, interior, suspension, bed lights, and more
    I soaked my belts in warm water with purple super clean. Did three 6 hour soak each belt until water stayed clean. It made a big difference. The silicone helped even more but then had a reverse effect by adding weight to a dry belt and attracting dirt. I need to do another soak without the silicone spray. Belts must be fully dry before letting them retract back.
    I used this video as a guidance link: https://youtu.be/Ob0AJvTbR_k
  16. Nov 25, 2021 at 8:00 PM
    alb1k
    Left Coast
    It's good
    Nice. Thank you.
  17. Nov 25, 2021 at 8:06 PM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    The front bumper came off today, and the Amazon cheapo wiring harness came out along with the flush mount lights. The bumper is waiting for the local fab shop to have an opening. I did a really poor job cutting the 3" sexy laser-cut holes into the nasty jagged abominations you see below. The shop is going to sandblast the bumper and add some weld beads into the bad areas/fill in some holes. I haven't decided if I'm going to pay to let them do the cleanup work or if I'm going to try again. After that stuff, I've got a place lined up for powder coating. I'm planning on having the bumper powdered in black (although the thought had crossed my mind of getting them powdered in the same bronze/brownish color as my wheels).
    Simultaneously, I've begun collecting parts for the GX460 front brake upfit. $200.44 OTD for OEM Pads/Rotors/Hardware, plus $147 for reman Calipers. I've got a buddy with a tool and die shop that's going to machine the calipers for me and give me a hand with the brake job. I'm going to have to check brake caliper clearance on my current wheels. All the posts I've read say you have to go 17s (I'm running 16s), but I've got my fingers crossed since I've got larger than normal spacers (1.5 as opposed to 1.25).
    NUDRAT, bmf4069 and alb1k like this.
  18. Nov 25, 2021 at 10:02 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    Who's Stan?
    FrenchToasty and Openbaffle like this.
  19. Nov 25, 2021 at 10:41 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Stans headers made the really nice tri y headers for our trucks
    lsaami and Openbaffle like this.
  20. Nov 25, 2021 at 11:21 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    Interesting. I never seen em
  21. Nov 26, 2021 at 4:22 AM
    I could be wrong but I'm not sure spacers are going to create more clearance for bigger calipers. I thought all they do is push the wheel out.
    w666 likes this.
  22. Nov 26, 2021 at 5:05 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    If the 'bigger calipers' run the same (or very similar) sized rotors, the caliper itself can foul the back of the wheel faces more so than the inside of the barrel. In this particular instance, spacers will help.
    Also, I've forgotten who's got the hissing intake, misfires on all 8, and lean codes on both banks, but that sure sounds like text book vacuum leak.
    If you backfired through the intake and then all this began, a pushed out gasket, cracked hose, and a cracked manifold are all likely culprits. Time to get out the brake clean and start spraying.
    bmf4069 and Punk1974 like this.
  23. Nov 26, 2021 at 7:15 AM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    when down a rabit hole for two days on the seat belt research and discovered secret sauce is the combo of silicone plus teflon spray the telfon is the secret supposedly?.?
    RUSTYNUTS and FrenchToasty like this.
  24. Nov 26, 2021 at 10:28 AM
    Is that old clear bra on your rear flares? If it is, and you want some help popping it off, happy to help... (pics of my before/after in signature link)
    BTW - did I ever ask you about road noise with those tires?
  25. Nov 26, 2021 at 11:43 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Yup.
    TRDGen, jImmegart, abcinv and 3 others like this.
  26. Nov 26, 2021 at 11:59 AM
    Openbaffle
    Wired in the third brake light to the shell. Confirmed it works. I need to run a constant power for the dome light and bed lights that I want to install. I've got 4 conductors on the wiring harness I rigged up, so likely ground, 3rd brake light, dome light and switched bed lights. I just have the dome light tapped into the second conductor of the brake light. The gas springs on the back of the shell need to be replaced, I think. The glass was gross, but cleaned up well. Now I can see out of the back. Likely have too much tint. I've got the tint on the back window and both windows on the shell are tinted. Will live with it for a bit. I thought my rear window motor went out, but it was just a loose connector on the driver's door, thankfully. Applied silicone lube to the window channel. I got a bit of water coming into the front of the bed underneath the shell (by the cab) last night, so I'll have to address that before getting started on my camper build.
    Made a quick walk-around video.
    https://youtu.be/yn0crEaaUVQ
    912, abcinv, bmf4069 and 2 others like this.
  27. Nov 26, 2021 at 12:06 PM
    empty_lord
    05 rollover special
    Copy cat!
    I would recommend some split loom on the wires. It won’t take long for vibrations to cut through that wire in the hole
  28. Nov 26, 2021 at 12:18 PM
    biebs96
    PA
    @dpast88 maybe find out his location
  29. Nov 26, 2021 at 12:19 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Can also buy a cheapo grommet kit from Big Gurrl and avoid the corrugated tube.
    Openbaffle and FrenchToasty like this.
  30. Nov 26, 2021 at 12:20 PM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I get tired of being asked wheel/tire specs, but I really like the look of those tires.
    285/70/17 or larger? Wildpeaks right?
    Openbaffle likes this.
