  1. Nov 24, 2021 at 6:31 PM
    20GR8 Super
    20GR8 Super -
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    I’ve got one of these and seems to work just fine for me.
    Snd000h[QUOTED] likes this.
  2. Nov 24, 2021 at 6:41 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    X2
    Snd000h and Half Assed like this.
  3. Nov 24, 2021 at 9:57 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    I'll put my angle finder on it tomorrow and see if they are actually the same angle, my concern was that they weren't, along with the picture!
    raymond_hb[QUOTED] likes this.
  4. Nov 25, 2021 at 3:22 AM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    I bought a set of these from Amazon.
    Dasen Low Profile LED Light Hood Ditch Mount Brackets Compatible with 2009-2021 Toyota 4Runner & 2007-2021
    Tundra
    1. [​IMG]
      T
      hey were pretty good quality and had holes to zip tie the wiring. They definitely angled down, which I didn’t prefer. I ended up ordering the CBI which are definitely a better quality bracket, didn’t angle down (at least for me), but did take several weeks to get.
  5. Nov 25, 2021 at 3:28 AM
    BoysandHisToys
    Central Virginia
    The short antenna’s usually perform much worse. I did order the one below, and seeems to do OK. Although I use Apple Music more than radio now.
    Rydonair Antenna Compatible with Toyota Tundra 2014-2022 | 13 inches Flexible Rubber Antenna Replacement | Designed for Optimized FM/AM Reception
    #1 Best Seller in Antenna Toppers
    1. [​IMG]
  6. Nov 25, 2021 at 5:19 AM
    Retroboy1989
    Northern Utah
    2012 DC 4x4 5.7 SR5 TRD OR Barcelona
    Snug top 20" TRD Sport wheels 275/60R20 Tires Additional Trans Cooler
    This is mine. I usually use Spotify or an audiobook, but I've never noticed reception issues when I do use the radio. I'd buy this one again. In fact, I may just get one for my dad's Taco...
    6 3/4" Inch - PREMIUM CHOICE
    https://www.amazon.com/dp/B01NALK2FC?_encoding=UTF8
  7. Nov 25, 2021 at 7:35 AM
    raymond_hb
    raymond_hb New Member
    Oakland, CA
    07 Tundra Limited 2WD
    That’s 2 for CBI the waiting won’t be much of a bother I’m doing a list of things I want to get most have a pretty long waiting time on them including the ditch lights I plan on installing. This helps narrow my options a lot more
  8. Nov 25, 2021 at 9:36 AM
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    Yea, a shin hazard!!!
    Retroboy1989[QUOTED] and Wynnded like this.
  9. Nov 25, 2021 at 1:29 PM
    Windsor
    Windsor New Member
    Oregon
    2008 Tundra Crewmax 5.7L
    Seat covers, SnugTop.
    Cut a hole in the firewall and stuck some wires through it. Going to start wiring accessories tomorrow. Need to rotate the tires today.
  10. Nov 25, 2021 at 10:31 PM
    raymond_hb
    Oakland, CA
    Happy Thanksgiving to all my fellow Tundra enthusiast. May you all have a wonderful and safe holiday :thumbsup:
  11. Nov 25, 2021 at 10:37 PM
    Dr Doobie
    Talkeetna,Alaska
    :cheers:
  12. Nov 26, 2021 at 2:08 PM
    Retroboy1989
    Northern Utah
    TRD rear sway bar. The truck feels much more planted and handling is much improved. I didn't mind how it drove before, but this is even better.
    D4x4TRD, Prostar 190, Zebruaj and 8 others like this.
  13. Nov 26, 2021 at 2:09 PM
    BoysandHisToys
    Central Virginia
    Can these be installed with lift kits? Does the size of lift matter?
  14. Nov 26, 2021 at 2:33 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yes, but in your case, you will need custom links because of the unusual amount of lift your truck has.
  15. Nov 27, 2021 at 8:54 AM
    chaosbooboogunner
    chaosbooboogunner New Member
    Dennis
    2012 Tundra Crewmax White
    Today I will be adding some new backup lights.
  16. Nov 28, 2021 at 8:25 AM
    Ricos
    Ricos New Member
    Ricardo
    2010 Tundra SR5 White Widow
    Never stopping ...
    Half way of the top-end rebuild
  17. Nov 28, 2021 at 8:26 AM
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    I installed my Ironman4x4 Foam Cell Pro Level 2 yesterday. Forged aluminum UCAs
  18. Nov 28, 2021 at 8:28 AM
    AstroDude
    Eddie
    Rose the truck 3.5 inches
    D4x4TRD, Prostar 190, rruff and 13 others like this.
  19. Nov 28, 2021 at 5:29 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Beefy lift... Looks like SoCal
    Go get it aligned and take it off some sweet jumps.?
  20. Nov 28, 2021 at 7:24 PM
    AstroDude
    Eddie
    Yeah I got it aligned and took it out to Anza Borrego but nothing crazy. I plan on taking it out to Sandstone Canyon in a couple of weeks. Today I installed my Trailtoys high clearance bumper. Next on the list is rock sliders and a front bumper. I'd get under armor plates but my wife said I need to chill for a little lol
    I ordered some race relation wheels 5x RR7-H
    D4x4TRD, Prostar 190, rruff and 9 others like this.
  21. Nov 29, 2021 at 6:51 AM
    COTundie
    Trey
    Pretty things
    Anza Borrego area is very cool.... Or I guess hot.
    Been almost 20 years, but I remember the oasis fondly. Bet there are some fun trails around there.
    I remember some fun trails out past Julian as well. Used to go shooting around there
    AstroDude[QUOTED] likes this.
  22. Nov 29, 2021 at 7:19 AM
    AstroDude
    Eddie
    Yeah it's pretty hot in the summer time but in the winter it's perfect. We go there all the time because it seems like the only place in SoCal to do anything offroading.
  23. Nov 29, 2021 at 9:16 AM
    aelarson
    aelarson New Member
    AZ
    2011 SR5 Tundra (Silver Sky Metallic)
    Drove from MN to CO for a hunting trip (2,500 miles total). The Slurp was the MVP of this adventure, no question. I have a whole new appreciation of the capabilities of this vehicle. I drove up a gnarly National Forrest access road (3 times) to get into our hunting spot. Not sure how the Slurp crawled up this road or how I have running boards left. Also crossed over the 150,000 mile mark driving home, long live the Tundie!
  24. Nov 29, 2021 at 7:02 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Ordered the rear sway bar. Best deal I could find.
    Will be blasting and powder coating black before install
  25. Nov 29, 2021 at 8:01 PM
    angkorstrong
    angkorstrong New Member
    2020 Sequoia TRD Pro
    our sequoia barely squeezed through some of the sections lol
    AstroDude likes this.
  26. Nov 30, 2021 at 6:02 AM
    SilverSkySurfer
    SilverSkySurfer DIY till ya die
    Augusta, Georgia
    2012 Silver Sky DC SR5 4.6L 2WD
    Method Con6 Wheels, LED Swap, LED taillights, BAM 8” exhaust, Eibach Spro sport leveling front shocks, AJT Shift knob and AC controls, Cover king seat covers, husky floor liners, color matched mirror caps and door handles, retrax bed cover, shorty antenna, D ring tow Shackles, rear TRD sway bar, JVC KW-Z1000w head unit, Morimoto Fogs, Alpharex Headlights
    finally got around to painting and installing my cat shields from Valhalla Shields
  27. Nov 30, 2021 at 10:14 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Bought these:
    https://3dcarstickers.com/product/t...stickers-decals-tribar-logoblack-background-/
    TOYOTA OLD 3d car wheel center cap emblems stickers decals :: Tribar logo/black background :: (83 mm, 4 decals) (x1): USD 10.99
    And these:
    https://aoonuauto.com/products/toyo...an-coupe-series?find=2007-toyota-tundra-12077
    Toyota Illuminated Door Sills 4 Piece (Front & Rear Doors)
    VEHICLE
    TUNDRA 2007-2013
    LOGO (Refer to description)
    TUNDRA
    LINE STYLE (Refer to description)
    STYLE 3
    COLOR
    White - stay on
    Quantity
  28. Nov 30, 2021 at 11:13 AM
    joseph_womack
    Joe
    Louisiana
    I'm sorry! I thought I already did this!!
    IMHO, I wish the CBI brackets weren't angled, they seem like the angles aren't the same on each mount, and to me it just seems like poor worksmanship. But then again they're the cheapest ones for our truck... and it does come with longer bolts for your hood
  29. Nov 30, 2021 at 1:22 PM
    raymond_hb
    Oakland, CA
    Ha! That’s alright it’s the holidays but I do see what you mean about the angle the driver side looks slightly more angled than the passenger. Although I’m thinking it’s because the passenger side has an extra attachment to it that makes it look more flat/centered. I would say that maybe modifying it by cutting that side piece out but it might defeat the purpose of having room to open up the hood and not have it scratch the windshield area.
    For example take a look at their website picture. It almost looks like there’s no outside angle might be because it’s a side shot picture
    And I was thinking they should have made the hole where is circled red but again I would have to see it in person to really get a better idea. Hey much appreciated for the reply in the end I’ll end up going with these since they are cheaper than most lol
  30. Nov 30, 2021 at 1:30 PM
    joseph_womack
    Joe
    Louisiana
    Yeah I agree with your thoughts, I’ve thought about cutting them and rewelding to a flat/level surface instead of the angle, I can get you a picture with the hood open… also thinking about heating them up in the vice and just bending them straight
