1st Gen 2WD DC
Discussion in '1st Gen Builds (2000-2006)' started by alb1k, Apr 5, 2021.
  1. Nov 18, 2021 at 8:44 PM
    #181
    alb1k
    alb1k [OP] Always Coming From Take Me Down
    Left Coast
    05 2WD DC w/ attitude
    It's good
    A little update for my two friends. The front end feels new with limited wheel time. It needs a double check of torque and an alignment. That can wait, because I can drive the boy's truck. The rear end has the long-awaited shock relocation coming. As noted before,I made the frame weak by removing the OEM hitch, the spare tire, and stressed it more with longer shackles. It's complaining now. Like a bitch. I really like Archive Garage (10%) off now although not on the homepage - I got it, try adding something to the cart to check. I was on the phone. Or email Eric. Anyway, the bed is coming off after the weekend. Time for shock relocation, finish hitch and support bumper welds, assess frame bracing needs. I have AG hammer hangers in route and the bed brace DIY plates. I may fab a brace in addition. Skid plates are here, but they can wait as well, first things first. Other things that can wait are new lic plate bulbs, updated stereo, back up cam, compressor mount, lights.....geez, I'll stop.
    Darkness likes this.
  2. Nov 18, 2021 at 8:47 PM
    #182
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Do you need to put in the hammer hangers before you set up the rear shocks? Not sure if they affect travel or not. Maybe?
    Maybe they don't as long as you keep the shackles you have.
  3. Nov 18, 2021 at 8:58 PM
    #183
    alb1k
    Left Coast
    It's good
    I think definitely. Even if not, the lower shock mount locations are critical and I don't want to set those and then change droop or anything after. Thank you @Darkness. And thanks again for your generous offer. I think that stuff worked out. I have a surf contest to watch (both kids) on my next day off, and am waiting on parts and probably will be taking a trip to the metal supply. So, I'll just have to be patient, and the bed will likely sit next to the truck for a while. I think in the end, I will add limit straps back there. The best ones are relatively cheap, but they take thought and math and time as well. This should be the "slow is pro" part. Measure twice and all of that. And I can always move to electrical if I'm at a stand still...
    Darkness[QUOTED] likes this.
  4. Nov 21, 2021 at 4:50 PM
    #184
    alb1k
    Left Coast
    It's good
    Plenty going on here.
    300BLK, Darkness, des2mtn and 2 others like this.
  5. Nov 21, 2021 at 5:01 PM
    #185
    Cummins3500
    Logan
    Dang I wanted those archive springs but I don’t need that much lift in the rear, probably be alright for the few months my camper top is on in the winter time. I’ve got the hammer hangers & cross bar, archive shackles, and the shock relocation in my parts pile for the truck. I may need to go back to looking at the deavers. :monocle:
  6. Nov 21, 2021 at 5:08 PM
    #186
    alb1k
    Left Coast
    It's good
    Reconsider. I had stock, Deaver and these. I did tame the lift of MD Archive springs by just under an inch with TC lowering shackles, but the springs are awesome. Hold a heavy load and run great empty. I wish I started with Eric.
  7. Nov 21, 2021 at 5:27 PM
    #187
    Cummins3500
    Logan
    You think those archive springs will settle any more? I hate I’ll have to buy another set of shackles with them :rofl:but that’s life I guess. The archive shackles are pretty awesome
    I agree Eric’s awesome, his cx service is top notch. I’ve spoken to him a couple times about different combos for the rear and squeezing a set of ads 12 inches remote reservoirs on the rear of my truck. He suggested the medium duties for my truck.
  8. Nov 21, 2021 at 5:28 PM
    #188
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    im really debating the medium duty springs.. but i dont know how well they'll handle towing vs my AAL and stock leafs... they've been able to support a damn taco without much squat
    FrenchToasty, MDobb79 and lsaami like this.
  9. Nov 21, 2021 at 5:45 PM
    #189
    alb1k
    Left Coast
    It's good
    I have his hammer hangers on order, but my shackles are TC and the hangers are currently OEM. These MD Archives could settle like any I guess. And then I could put OEM length shackles back on. But the build of them is really good, and I anticipate keeping it as is - except for the hammer hangers, which don't add or lose lift.
  10. Nov 22, 2021 at 1:44 PM
    #190
    alb1k
    Left Coast
    It's good
    Dry fit of the rear shock relocation.
  11. Nov 22, 2021 at 1:45 PM
    #191
    alb1k
    Left Coast
    It's good
    Place holder.
  12. Nov 22, 2021 at 2:15 PM
    #192
    alb1k
    Left Coast
    It's good
    I’m not at full droop yet, but clearly limit straps are in order.
    FrenchToasty, SharkDog and Darkness like this.
  13. Nov 22, 2021 at 2:17 PM
    #193
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    From the first pic it looks like you have limit bolts :rofl: not a wear item like those pesky straps! Now im curious if my leaf springs hit that way, maybe not since I have stock shackles still.
    Second pic is just telling you to chop the last foot of tailpipe off like I did.
    FrenchToasty and Tundra2 like this.
  14. Nov 22, 2021 at 2:34 PM
    #194
    alb1k
    Left Coast
    It's good
    Lol, those are wannabe limit bolts, that would just bang and cry! I’m not going to worry about those until the new hangers are here. But, this is needed….
    Darkness and des2mtn like this.
  15. Nov 22, 2021 at 6:16 PM
    #195
    alb1k
    Left Coast
    It's good
    Full droop. More available if I push down on the tides. But a good limit point.
    yup on the tailpipe. Just waiting to look at shock clearance so I make an informed cut.
  16. Nov 22, 2021 at 7:03 PM
    #196
    Super weird observation, but the 1st time I looked at this picture, I saw hearts in these two spots while zoomed out. When I zoom in, clearly it's a round void. Optical illusion? Or maybe I'm just projecting how much I'm loving this build!
    daveeasa likes this.
  17. Nov 22, 2021 at 7:18 PM
    #197
    daveeasa
    I keep dreaming of an option for 8' of this. It would be insane.
  18. Nov 22, 2021 at 8:25 PM
    #198
    alb1k
    Left Coast
    It's good
    I see them too, now that you drew them on there...:0
    shifty`[QUOTED] likes this.
  19. Nov 23, 2021 at 9:37 AM
    #199
    alb1k
    Left Coast
    It's good
    Interesting morning. Drive the kids to practice at 0530. It’s a couple of miles. Cross PCH on the way home and head to a merge. There is a guy on my tail, so close I can’t see his lights. I know I have a problem, we are about to merge and there’s traffic. I cover the brake and coast, traffic slows, even before I start braking, I start moving toward a hole. Doesn’t matter, dipshit rear ends me. Fuck. I pull into the right and go slow to the first turn out. He follows but as soon as I turn right he runs off.
    Now, flame away but don’t do what I did. That’s my advice.
    Fuck that I say to myself. Pursuit mode in the boy’s V8 4R. Catch him, steer him to a stop and tell him to follow me or he’s screwed.
    The rest is a lot of I’m sorry, let’s get cash, I (the girlfriend) have to get to work.
    The only funny part was when I’m out of the car and the girlfriend is out and I see her in a t-shirt and underwear. It’s not pretty. At all. I don’t think she was going to work, however. I doubt he’s insured. I got his info and 100 bucks he’s not if anyone likes to wager. Unless that’s against the rules here then no bet.
    Back to regular programming.
    Centering punches are great.
    des2mtn and Darkness like this.
  20. Nov 23, 2021 at 9:45 AM
    #200
    daveeasa
    On that subject, I was at Costco recently and what I think was a kid driving a nissan with both his parents accelerates strongly and slams a camry hybrid into the pillar next to the tank, trashing both wheels and the whole rear end. Then he throws it into reverse and smashes the car which used to be right behind him. I was 2 cars back and happy for the cover. I went wide to a different aisle for gas.
    Then, walking back to the van yesterday (windshield crack which safelite took all day to replace and still couldn't get the electronics calibrated so now I have no safety anything) someone slams into a parked truck, all side curtain airbags deploy, not sure if it was medical or just looking at a phone or something dumb like that, seemed like she was having some trouble in the car, people talking to her through the windows around the airbags.
    Something is definitely going on these days, it's loco.
    alb1k[OP] likes this.
  21. Nov 23, 2021 at 11:03 AM
    #201
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Oh man sorry to hear about the accident. Hopefully no real damage.
    That center punch looks like it did work well, I need to pick one up. Are you using step bits from here or something better?
  22. Nov 23, 2021 at 11:12 AM
    #202
    alb1k
    Left Coast
    It's good
    I love step bits but for this I buy the cheap Costco titanium bits. Run a 5/32 or close backwards to clean the punch, then forward to drill the pilot. Then straight to 1/2. Oil on the bigger bits. I toss the small bits, sharpen the bigger. If I was on a press, good bits.
  23. Nov 23, 2021 at 11:18 AM
    #203
    alb1k
    Left Coast
    It's good
    These are Amazon/Chinese. No way precision but good enough for who they are for. Served me well in many applications.
    FrenchToasty and Darkness like this.
  24. Nov 23, 2021 at 11:19 AM
    #204
    alb1k
    Left Coast
    It's good
    It’s getting exciting.
    Punk1974, Darkness and des2mtn like this.
  25. Nov 23, 2021 at 11:24 AM
    #205
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Looks like a bit more than a foot was cut off of that tailpipe! Coming along nicely.
    FrenchToasty, Darkness and alb1k[OP] like this.
  26. Nov 23, 2021 at 11:26 AM
    #206
    alb1k
    Left Coast
    It's good
    Yeah, there was no where else to cut it that wasn’t up. Shock interference…
    Darkness and des2mtn[QUOTED] like this.
  27. Nov 23, 2021 at 1:33 PM
    #207
    alb1k
    Left Coast
    It's good
    Shock mounts lower than I would like, but I spread them out as far as I could. At first I was thinking about maximizing droop, but this spring setup will go forever. So I decided, hopefully rightly, to focus on compression and ensure they can’t top out. Straps for droop. The only thing that would turn up the mounts, would be shorter shocks. That would raise the low points 1-1.5 inches. Going from a 12" to a 10" shock would probably defeat some of what we are doing here.
    HBTundra and Darkness like this.
  28. Nov 23, 2021 at 1:50 PM
    #208
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Might be time to join the Spintech club :fistbump:
    Is that with 12" 2.0 shocks?
    Did you measure right to the bump stop, or did you allow room for squish?
  29. Nov 23, 2021 at 2:08 PM
    #209
    alb1k
    Left Coast
    It's good
    I looked at where the bump stop would squash down to the hardware and explode. That’s what I was going for anyway. Yes, 12” thanks @Darkness insert fist bump
  30. Nov 23, 2021 at 4:30 PM
    #210
    alb1k
    Left Coast
    It's good
    I might be walking the line on compression. I think I'm still in the green, but I'll have to see when it's all loaded up and big dips. You definitely know those shocks are back there...
    Ignore the zip ties and temp bolts. :0
    Punk1974, dinosaur, shifty` and 3 others like this.
