  1. Nov 19, 2021 at 4:30 PM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Good question. Seems to be throughout the Power band and up to red line.
  2. Nov 19, 2021 at 4:34 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    I've heard the opposite, Dyna Packs seem to read high and Dynojets read low.
  3. Nov 19, 2021 at 4:47 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Not much power bump at peak. But that torque. That’s a nice gain
  4. Nov 19, 2021 at 5:38 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Yea, I think a tuned ECU by DAP or other can increase that peak power. Also these trucks are notoriously difficult for finding any horsepower. I was an emissions tech for Toyota R&D in LA for many years and always picked the brains of the power train engineers while I was there. they insured me that it was difficult to find power in the 4.7 or any other engine for that matter because they were tuned very well from factory to be reliable at max power while maintaining emissions.
    jerryallday and shifty` like this.
  5. Nov 19, 2021 at 6:06 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    After a month’s forced vacation, a lot happened, and it’s time to catch up.
    did the timing belt with my brother. That was a job. Took us two full days and an evening.
    And guess what! The timing was off by a tooth on the crank!
    We put it back right, and after driving it, I didn’t gain much fuel economy or 0-60 time, but there’s a definite gain in torque from 2000-3000rpms.
    also, I sold the Milestar Patagonia’s to my brother and picked up a set of Dick Cepek Trail Country EXPs. They’re SO MUCH QUIETER. I have about a thousand miles on them so far, and they’re great. Got them for $176/tire.
    [​IMG][​IMG][​IMG]
    Also, my deer hunting setup.
  6. Nov 19, 2021 at 6:07 PM
    empty_lord
    05 rollover special
    the 2gr with a velocity stack, MAF tune and some headers can do 300whp with an s54 manual trans.. theres power to be made. but they dont make it easy. it was discovered the MAF pipe and removing the catalyst over temp protections made pretty large gains for the ol 3.5
  7. Nov 19, 2021 at 7:32 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Mustang dyno's read low, dynapack and dynojet reads higher. Of course, there are settings the Dyno operator can use to fudge any result, so ymmv.
    Mustang and Dynapacks are able to load the engine and are better for tuning. Dynojets only have a heavy roller. IIRC
  8. Nov 19, 2021 at 8:06 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Not done yet....what y'all think of my template? I got semi roasted for using rusty kitchen scissors for the last attempt at splash guards lol.
    oscardog86, Voss, bmf4069 and 12 others like this.
  9. Nov 19, 2021 at 8:13 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    I think they look great! Nice work.
    chrisb likes this.
  10. Nov 19, 2021 at 9:24 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Gonna get some generic mud guards and cut them up or what are ya gonna use?
  11. Nov 20, 2021 at 6:54 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    Probably some 1/16" rubber from a hardware store if I can find it. The last stuff I used was thicker and harder to cut. Plus the push pins didn't like it.
    CodyP[QUOTED], chrisb and Punk1974 like this.
  12. Nov 20, 2021 at 6:57 AM
    Make sure you get a material that is oil/gas resistant?
    Not sure how deep you are, but Ark splashguard makes a set for our trucks for around 100$
    Punk1974 likes this.
  13. Nov 20, 2021 at 7:17 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    Yeah I saw those. I read that the fit could've been better from somewhere/one.
    I haven't spent anything yet. Just a few beers worth of time... I thought about that also, La resistance, that is. I don't think it should be that big of deal, shouldn't be much of that there if everything is good on the truck? Toyota sure didn't care. I'll check when I buy the rubber if they have that info.
  14. Nov 20, 2021 at 10:24 AM
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    All this mirror talk recently gave me autodim envy. My stock SR5 mirror was the scungiest thing on my truck so I looked into Gentex etc. I didn’t need the compass or temp or homelink since I have it in the center stack already. ended up finding an OEM limited mirror on eBay for a steal and picked up a gen harness for ~$20 at the dealer. Looks much nicer.
    Voss, bmf4069, Hi06silver and 5 others like this.
  15. Nov 20, 2021 at 11:10 AM
    ThatYeti
    ThatYeti New Member
    2000 Tundra SR5
    Replaced all the bulbs in the dash/HVAC panel (only counted 6 btw) and I can see the ones on the edges lighting up (consequently the smaller ones) and I used the adapters these came with for the bigger ones but either it's too bright out or they won't work.
    bmf4069, Tundra2 and 912 like this.
  16. Nov 20, 2021 at 12:21 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Did you turn the socket around 180°? Leds are polarity sensitive which means they only work positive to positive, negative to negative.
  17. Nov 20, 2021 at 1:08 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    hehe
  18. Nov 20, 2021 at 2:41 PM
    shifty` Goons of Hazzard
    Glad to see I'm not the only one whose stock mirror was doing that weird double-image thing. It hasn't bothered me not wiring my Gentex replacement up yet, the image through the 453 I installed is so much better than my factory mirror that it's a huge win already. Having a hidden behind-glass compass and Homelink v3 *would* be nice though!
    912[QUOTED] likes this.
  19. Nov 20, 2021 at 3:03 PM
    empty_lord
    05 rollover special
    After many months of waiting the my odyssey battery finally showed up.
    now I need to have the @Coupe trd hold down re powder coated due to this delay being long enough for the battery corrosion to eat the power coat! Bah
    shifty` likes this.
  20. Nov 20, 2021 at 3:13 PM
    ThatYeti
    ThatYeti New Member
    2000 Tundra SR5
    Didn't but then I didn't really pay attention to the bulbs coming out either. Seemed like there wasn't any metal in the new bulb/adapter that was going to be touching the housing that comes out but that the new bulb had metal on top that would at least touch the truck side
  21. Nov 20, 2021 at 3:24 PM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    not only try turning led bulbs 180° you should use the original socket and always test the bulbs before reinstalling panel
    des2mtn, Tundra2 and ThatYeti like this.
  22. Nov 20, 2021 at 3:45 PM
    ThatYeti
    ThatYeti New Member
    2000 Tundra SR5
    Ya....that would've been smart... always next time I guess
    Punk1974[QUOTED] likes this.
  23. Nov 20, 2021 at 3:54 PM
    Punk1974
    J.P.
    whenever you see mirror delamination its usually from cleaning product like windwex dripping into and around the edges of the glass and reacting and delaminating the silvering best to sqwirt rag and clean glass or use a foam cleaner that stays in place until wiped
    912, chrisb and Sirfive like this.
  24. Nov 20, 2021 at 4:29 PM
    ThatYeti
    ThatYeti New Member
    2000 Tundra SR5
    Dark enough out now...got one out of six...
    Guess I'll try again tomorrow....maybe test em before putting it all back together this time
  25. Nov 20, 2021 at 5:43 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    I been wanting to do this but I do want the compass. I can take or leave ambient temp since my scangauge2 shows me intake temp and it's basically ambient temp +2°F at highway speeds
  26. Nov 20, 2021 at 5:49 PM
    Best part is, you only need to flip the others 180, and you should be good to go.
    FrenchToasty and Tundra2 like this.
  27. Nov 20, 2021 at 7:43 PM
    Openbaffle
    Openbaffle New Member
    Got half of the add-a-leaf kit from Torch installed. The kit was great. I actually ended up not using the shim or longer u-bolts because they seemed way too long. I bolted the OEM u-bolts back on but they seem a little short. I did get a full 1.5" of lift from the extra leaf. My c-clamps suck. I need beefier ones to compress the springs that was a real chore. Other than the rust it was a slow-going, but pretty straightforward process. I suspect the other side will be a bit shorter tomorrow.
    Voss, 912, chrisb and 1 other person like this.
  28. Nov 20, 2021 at 8:47 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Wow, that gave you 1.5". Awesome. I don't imagine you have driven it yet?
  29. Nov 20, 2021 at 9:54 PM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Tinkered with the headlights today. I figured the occasional bright lights I kept receiving were indication enough to adjust them.
    Voss, bmf4069, NUDRAT and 2 others like this.
  30. Nov 20, 2021 at 11:32 PM
    empty_lord
    05 rollover special
    installed my junkyard injectors for the 12 hole mod. will monitor fuel trims and if i feel any differences. Also installed my long awaited battery. truck fires up quick now!
    next step is the wiring upgrade and finally wiring up the 3rd brake light i keep putting off. then its back to trying to figure out my backup camera
    [​IMG] [​IMG] [​IMG]
    KingSequioa007, Voss, 912 and 12 others like this.
