  1. Nov 18, 2021 at 9:30 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
  2. Nov 18, 2021 at 10:08 AM
    daveeasa
  3. Nov 18, 2021 at 10:14 AM
    alb1k likes this.
  4. Nov 18, 2021 at 10:15 AM
    daveeasa
    @empty_lord can confirm once he gets it in.
    alb1k likes this.
  5. Nov 18, 2021 at 10:19 AM
    alb1k
    Left Coast
    It's good
    I think I'll be running my own cables sometime after my terminals show up. My neg is due for replacement after looking at it the other day.
  6. Nov 18, 2021 at 10:47 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    iPhone 11
  7. Nov 18, 2021 at 10:47 AM
    empty_lord
    05 rollover special
    Yea when I get the free time
  8. Nov 18, 2021 at 10:51 AM
    alb1k
    Left Coast
    It's good
    @EvilMilkshake sounds like he knows a lot about this, but GPS seems to be the only real battery suck? Or screen not sleeping.
  9. Nov 18, 2021 at 11:28 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Also in case you guys didn’t know, you can go under the settings and then battery to see what’s your biggest battery drains
    alb1k and daveeasa like this.
  10. Nov 18, 2021 at 12:30 PM
    EvilMilkshake
    EvilMilkshake New Member
    05 AC Limited 4x4
    Cool. And what are you connecting your iPhone 11 to? You said Bluetooth kills your battery, but not what you connect it to when stating such. If using an older radio, speaker, fitness tracker, etc., it may only contain an older inefficient bluetooth radio chip, which means even though your 11 can do 5.0 and LE, your old device will force it to use Bluetooth 2.0 for instance, which sucked for battery life.
    If your battery life sucks with the 11 and your 2020 radio, then Pioneer/Harman are putting shitty old chips in that stereo unless your screen is on while your driving as well.
  11. Nov 18, 2021 at 1:36 PM
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    It was a rainy day here today (which I hate) so I finally did this leather steering wheel cover I’ve been sitting on. It took me about three hours from start to finish and it’s as big a pain in the ass as everyone says. The fit of this kit isn’t perfect, I had to do some trimming and adjusting but manageable if you take your time. I took the steering wheel off, 19 mm nut, and be sure to mark the position. Didn’t need a puller to get it off the column. Overall, the steering wheel feels super nice now. If you like a fresh interior, I highly recommend it for $60 and a few hours.
    https://smile.amazon.com/gp/aw/d/B019H9DJFM?ie=UTF8
    Oiringal crappy SR5/XSP wheel
    13250048-8D57-4BA2-B2DA-5E4B4FBFCFA0.jpg FB1E25F4-153A-4491-871E-EB0760C6913B.jpg
    Stretching it on is surprisingly difficult.
    0576E503-2D5B-4736-B12C-4336E9E37859.jpg FF9C7B9F-ED0E-414E-99CD-2481E1D5C1D7.jpg
    Started at the bottom. In the corners, I did every stitch and on the stretches with less stress, I did every other.
    Looks good in my refreshed interior. Not bad for 16 years old and 200,000 miles, eh?
    4E73887D-3687-497B-BFA9-BE821446FE4A.jpg 173787F0-20DC-4FD3-970C-9EE5CBFFD8A0.jpg
    Voss, jerryallday, hammeron and 9 others like this.
  12. Nov 18, 2021 at 1:39 PM
    I hate the newer steering wheels. The older one lets me put my right hand on the bottom in the 6 o'clock position and one arm out the window on the sill like I was taught in driver's ed. :D
    Okay, maybe not driver's ed. More than likely crusing at the beach as a teen with a car.
    bmf4069 likes this.
  13. Nov 18, 2021 at 1:50 PM
    alb1k
    Left Coast
    It's good
    That looks good, nice work.
    Voss and 912[QUOTED] like this.
  14. Nov 18, 2021 at 1:55 PM
    daveeasa
    Looks amazing. I wonder if maybe I could buy any old wheel and just leather wrap it so color wouldn’t matter?
    I would still need to figure out the airbag part though. And I guess the steering wheel controls can’t be leather wrapped.
    912[QUOTED] likes this.
  15. Nov 18, 2021 at 2:15 PM
    What I ended up doing was waiting for a fair-to-good condition leather-wrapped wheel from a 4R popped up on eBay, snatched it up, and figured I'd install it, then get the Lonckey kit, zip up my original wheel, and if happy with it, swap the original wheel back in.
    I've had the 4R steering wheel in my shop for about a year now. Along with the right-hand controls to manage bluetooth and whatnot. I just haven't gotten to it.
  16. Nov 18, 2021 at 2:22 PM
    daveeasa
    Yeah, my pile of stuff to do is big.
    I have a few days of freedom sat - tue
    but stuck with minivan as one truck is in palm desert and the other at my mechanic.
    so I think I’ll focus on harness building.
    shifty` and mcharfauros like this.
  17. Nov 18, 2021 at 3:03 PM
    Outbound
    Aaron
    Northern Alberta
    I put the winter tires on today. I got them aired up properly and went for a 20 minute drive. Once things settled back in, it would appear that my vibration problem is gone. This confirms my and my mechanic's latest idea that the vibration was caused by cupping and uneven wear on my Coopeer ST Maxx tires. Looks like I'll be buying new tires next spring which is ok, I've been wanting to try Falken Wildpeaks anyways.
    @empty_lord , any luck with your vibration issue? Maybe check your tires as well?
    chrisb, NUDRAT, bmf4069 and 1 other person like this.
  18. Nov 18, 2021 at 3:07 PM
    empty_lord
    05 rollover special
    The 19 radio or 20 radio drain the battery the same
  19. Nov 18, 2021 at 3:30 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    I've got a good condition leather wheel if you decide you want one.
  20. Nov 18, 2021 at 3:36 PM
    0h6SR5
    0h6SR5 New Member
    2006 Phantom Grey Tundra
    3 inch OME with AAL wheels and tires. 285 70 17
    Today I got some time to install my ditch lights that were on my 18 Tacoma. Took them off before I got rid of the truck. Using Rago brackets. Had to trim in order for hood to close correctly. One of the brackets doesn’t have the R cut out so it was a little annoying because that’s where one of my zip ties went. Took off relay from old harness wired directly into the auxbeam 8 gang. Lights pull 2 amps so terminated on the 5 amp slot. I added the rago radio antenna mount as well. Should have a midland radio with antenna coming soon. Not sure how I will end up adjusting it. Fine for now. Also I fished the wires through the hood.
  21. Nov 18, 2021 at 3:51 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Does it have steering wheel controls? If he doesn't want it, I may be interested.
    daveeasa likes this.
  22. Nov 18, 2021 at 3:55 PM
    daveeasa
    Steering wheel buttons? I’m gonna guess no?
    Cue Dr Dre and 16 switches.
    Darkness, chrisb and bmf4069 like this.
  23. Nov 18, 2021 at 4:00 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    No switches or airbag for switches. I do have the non-switch airbag.
    Darkness likes this.
  24. Nov 18, 2021 at 4:02 PM
    daveeasa
    Thanks. I think if I take the time to swap the wheel I gots to get switches. But that’s a nice offer leather-wise.
    living without volume buttons is hard.
  25. Nov 18, 2021 at 4:37 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    3k miles this year (so far). Where you at @shifty`
    Voss, NUDRAT, bmf4069 and 3 others like this.
  26. Nov 18, 2021 at 4:43 PM
    Wow. Obviously not your daily driver.
    abcinv[QUOTED] likes this.
  27. Nov 18, 2021 at 5:21 PM
    I'll likely pass 72k this month. Got a lot of year-end errands to manage.
    Voss, bmf4069 and abcinv[QUOTED] like this.
  28. Nov 18, 2021 at 5:22 PM
    Oh, and I wish my needles were still that red! Everything in this truck faded. PO parked outdoors often, apparently.
  29. Nov 18, 2021 at 5:31 PM
    Just to go back on topic ... MORE PARTS! Thanks to @daveeasa for this DIR harness. Talk about a quality f'n product, you can really see the care in the detail and craftsmanship here. Love it.
    I'm hoping to get time to work on the truck next week before family gets here. I'd really love to get the backup camera finally installed!
    bmf4069, alb1k and mcharfauros like this.
  30. Nov 18, 2021 at 5:33 PM
    mcharfauros
    mcharfauros Hafa Adai
    MO
    06 AC SR5 4X4
    Dumb Truck Thangs
    Nice, got a shipping notification for one. Looking forward to getting it all wired up.
    shifty`[QUOTED] likes this.
