'Sploded Wheel Cylinder
Discussion in '1st Gen Tundras (2000-2006)' started by DarkMint, Nov 15, 2021.
  1. Nov 15, 2021 at 10:12 AM
    DarkMint
    DarkMint [OP] just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Dumbass moment. I was changing out a leaking wheel cylinder while doing my drum brakes and forgot to open the bleeder valve as I pumped the brake pedal, causing pressure to build up in the cylinder and making one of the pistons explode out. Of course, brake fluid everywhere as well. Make sure you open the bleeder valve... Maybe I'm the only one who needs that reminder.
    I ended up popping the new wheel cylinder parts back together and installed it with my brakes. It doesn't seem to be leaking.
    Anything wrong with using the wheel cylinder after it exploded? Is there any special trick to reassembling wheel cylinders, or was it ok for me to just pop the parts back in and verify correct functioning?
  2. Nov 15, 2021 at 3:39 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Take it off, reassemble while vertical so the spring is properly centered on both pistons and reinstall.
    Don't bleed the brakes without everything assembled.
  3. Nov 17, 2021 at 4:25 AM
    I'm pretty sure Heather rebuilt his. You might check towards the end of his build page.
    w666 and Punk1974 like this.
  4. Nov 17, 2021 at 4:30 AM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    who is heather and where is his? build page??.
  5. Nov 17, 2021 at 5:45 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    "Heather" aka PHM was a valued member in the first gen section, even though they had their moments where they could be a butt. They got the perma-ban earlier this year. The name Heather comes from an Amazon review they left on a product which we later found; the name Heather seemed totally out of left field.
    Lots of good info in their build thread: https://www.tundras.com/threads/the...vestment-‘build’-a-chronological-story.46816/
    Jack McCarthy and bmf4069 like this.
  6. Nov 17, 2021 at 1:25 PM
    Punk1974
    J.P.
    interesting. Did not even know there was a build section. I saw golde hands all over the what did you do section with some ground breaking stuff and he/she? even helped out a few other butts around here. Dude? seemed very comical! I’ll check out the bulit section link. Thanks
