  1. Nov 15, 2021 at 7:10 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Really? May want to look into that, that doesn't sound confidence-inspiring.
  2. Nov 15, 2021 at 7:12 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Good question just finished alot if work on Tundy. Completely front end redone, AAL, LED everywhere, power steering fluid flush and brake flush. Moving to exhaust just to expensive so looking to maybe putting something together myself.
    NUDRAT and shifty` like this.
  3. Nov 15, 2021 at 7:13 PM
    Especially D’s Nutz!
    Darkness, bmf4069, Punk1974 and 2 others like this.
  4. Nov 15, 2021 at 7:42 PM
    Desert Dog
    No, man, I meant so you could do my brake res like yours. Lol!
    Voss, bmf4069 and Dave8699[QUOTED] like this.
  5. Nov 15, 2021 at 7:43 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    Figured that's what you meant, but I'm sure your your not close to NJ.
    Desert Dog[QUOTED] likes this.
  6. Nov 15, 2021 at 7:44 PM
    Desert Dog
    No, I'm not but I've got all day. PM you my addy.
  7. Nov 15, 2021 at 8:17 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    nut trick?
    Darkness and FrenchToasty like this.
  8. Nov 15, 2021 at 8:20 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    Put inside the reservoir 32 nuts with cleaning solution and shaked. The nuts scrub the inside of the tank.
  9. Nov 15, 2021 at 8:23 PM
    No more, no less!
    Darkness and bmf4069 like this.
  10. Nov 15, 2021 at 8:26 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    I found out that 20 wasn't enough so I added the rest of what I had. A little more would be better and faster.
    But on the other hand Funny joke
  11. Nov 15, 2021 at 8:47 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    :rofl:Literally laughed out loud:rofl:
  12. Nov 15, 2021 at 8:50 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    The RC and AC have the same frame per @empty_lord
  13. Nov 15, 2021 at 8:51 PM
    empty_lord
    05 rollover special
    yes. body mounts are different and possibly some reinforcement.. but the main members should be the same
    Darkness and RUSTYNUTS[QUOTED] like this.
  14. Nov 15, 2021 at 8:57 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    More info on the gussets please. You buy them or you makin them yourself?
    oscardog86 likes this.
  15. Nov 15, 2021 at 10:14 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    I did the GM diode mod this evening. My idle voltage went from 13.7 vdc to 14.2 vdc. It peaks around 14.4 vdc. I'll take it.20211115_182014.jpg 20211115_213241.jpg
  16. Nov 15, 2021 at 11:03 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I got the TCs. Ordered them a while back waiting for a time to install them. The diver's side fits well - it's just tacked for now.
    RUSTYNUTS[QUOTED] likes this.
  17. Nov 16, 2021 at 2:53 AM
    daveeasa
    Awesome. I will let you all know how the expensive as F inline harness from Singer works once I get it. Seeing voltage in the mid 13’s on scan gauge right now.
  18. Nov 16, 2021 at 2:56 AM
    daveeasa
    Which is why I think they would be compatible. But I wasn’t sure if Billy does something special with the lines for RC vs AC. I assume not but just didn’t get into specifics with him on that. I feel bad wasting his time on that level of detail because he is so busy. Truly a fantastic guy though and our communication goofs here are a bummer so if there is some way I can help stoke out someone else I will gladly do it.
  19. Nov 16, 2021 at 4:39 AM
  20. Nov 16, 2021 at 7:09 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
  21. Nov 16, 2021 at 7:42 AM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    Nice. Which LEDs did you put behind the instrument cluster and HVAC controls?
  22. Nov 16, 2021 at 8:17 AM
    daveeasa
  23. Nov 16, 2021 at 9:37 AM
    alb1k
    Left Coast
    It's good
    If my dyslexia hasn’t attacked, they go this way…
  24. Nov 16, 2021 at 9:49 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Whats involved to weld these gussets in? Like what needs to be removed to properly get to the spindles to weld them in? Im thinking of giving this a go down the road and just curious how much of a pain it is to do. Thanks!
  25. Nov 16, 2021 at 9:55 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @oscardog86 when I did mine I pulled the spindles right off the truck. You need to be able to grind the area clean of paint and get in there at funny angles to weld them.
    Some say you should pull the hubs and bearings to avoid cooking them but if you do short passes and give plenty of cool down time between they should be fine to leave in.
    RUSTYNUTS, oscardog86 and alb1k like this.
  26. Nov 16, 2021 at 10:13 AM
    alb1k
    Left Coast
    It's good
    Agreed with everything @Darkness said. I’m doing mine on truck, but am very thoughtful of temps. Off truck is preferred, and if I wasn’t exhausted, would do that.
    RUSTYNUTS and Darkness[QUOTED] like this.
  27. Nov 16, 2021 at 10:15 AM
    alb1k
    Left Coast
    It's good
    The second one is the backside.
    RUSTYNUTS, oscardog86 and Darkness like this.
  28. Nov 16, 2021 at 10:24 AM
    alb1k
    Left Coast
    It's good
    When you have 700lb coils, the mere weight of these is not a concern (to me). Flame on
  29. Nov 16, 2021 at 10:32 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Getting there...
    Voss, NUDRAT, Lil Steve and 15 others like this.
  30. Nov 16, 2021 at 11:47 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Mine have been sitting in the garage for over a year... eventually they'll get put on.
