Elka Reviews
Discussion in 'Suspension' started by BCTRD, Oct 26, 2021.
  1. Oct 26, 2021 at 10:49 AM
    BCTRD
    BCTRD [OP] New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    Planning to lift the front 1.5" to 1.75" and improve the ride/suspension performance over the factory Bilstein's.
    Very interested in the Elka 0-2" kit.
    Dealers I've called in the area don't much feedback for this setup.
    Wondering how the overall on and off road ride changed when you switched from factory suspension to the Elka's.
    Not many online reviews for the 2" body and just a few for the 2.5"
    Reservoir models aren't required and even 2.5" may be more than needed for the amount of gravel/fire roads we'll be driving although washboard isn't uncommon.
    Considering coachbuilder .625 or 1.25" to retain 1.5" rake for towing and not throw the Toyota TSS off.
    The Icon expansion pack may be an option for the rear (advertised @ 1.5") although the finished result seems to vary from truck to truck.
    Does anyone know the approximate amount a front can be lifted without throwing the TSS off or causing errors on a 2020 or newer model.
    A few threads mentioned around 1" although a heavy load in the back could represent a fair bit more than 1".
    I'd imagine a little of tolerance would be built in to account for heavier towing or load situations causing the sensor angle to change.
  2. Oct 26, 2021 at 11:07 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
  3. Oct 26, 2021 at 11:15 AM
    2mchfun
    3/2 here on 21 no tss issues.
    BCTRD[OP] likes this.
  4. Oct 26, 2021 at 11:18 AM
    BCTRD
    B.C.
  5. Oct 26, 2021 at 11:57 AM
    BCTRD
    B.C.
    Good to hear.
    I said f*k it and hit the order button.
    Will be sure to give a review in a few months when they arrive and are installed.
    Sleeper16plat, 66Platinum and Warreng like this.
  6. Oct 26, 2021 at 9:26 PM
    66Platinum
    66Platinum New Member
    Angel
    Salinas Valley CA
    20 Platinum MGM
    Interested in this set up as well, let us know your experience once installed and driven
    BCTRD[QUOTED][OP] likes this.
  7. Oct 27, 2021 at 4:14 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Suscribed... Looking forward to your reviews.
  8. Oct 27, 2021 at 4:23 AM
  9. Oct 27, 2021 at 12:06 PM
    BCTRD
    B.C.
    Will be sure to post results.
  10. Nov 1, 2021 at 8:44 PM
    BCTRD
    B.C.
    What's your suspension setup with the 3/2?
  11. Nov 2, 2021 at 5:30 AM
    2mchfun
    Front Fat Bob's Garage Vated adj. Coilovers with 700# coils, SPC adj. uca's. Sway bar drop spacers, diff drop spacers, timbren active bump stops. Rear Dobinson's HD 7 leaf packs, yello Sumo Springs, Roadmaster HD active Suspension kit, BDS traction bars, Bilstein 5160 shocks w/ res, Ironman greasable shackles and poly bushings, OME brake line relocate, Ironman carrier bearing drop kit. Set up for weight here. My point is a slight lift doesn't bother my tss function.
  12. Nov 2, 2021 at 7:54 AM
    BCTRD
    B.C.
    Copy that on the TSS. Impressive package.
    2mchfun[QUOTED] likes this.
  13. Nov 2, 2021 at 8:07 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Too bad you aren't local in YYC @BCTRD - you could come drive my Tundra and get a feel for the Elkas.
  14. Nov 2, 2021 at 5:47 PM
    BCTRD
    B.C.
    Be nice to compare the ride, we're over in YYJ.
    Decided to go 2.5 Elka on the rear as well.
    Probably set the fronts @ 1 5/8" to 1 3/4" with CB shackles or an aal type pack in the rear for around 1 1/4" to 1 1/2" rake.
    If there was an add a leaf set up with decent ride & a little extra capacity I'd be set.
    Will look into firestones at a later date if required.
    I'll install everything in the new year due to delays in production.
    The Toyo Open Country ATIII's are backordered for up to 2 months so no rushing this build.
  15. Nov 14, 2021 at 6:45 PM
    J.Clarke
    J.Clarke New Member
    2023 Tundra Crewmax SR5 L TRD off-road
    You’ll love the set up I have 2.5 non-res all round set upfront at 2.5” with a CB 2” shackle with open country at3 (285/75 18) and it’s awesome all around for everything I do which is tow, off road it does the job is comfortable I have JBA UCA’s no issues with the sensors only had to recal. Cause the size change I do need to get the 3” Shackle replaced cause I’m just about level and I want the take back cause of the sag while towing my camper
    Teddybear18 likes this.
