  1. Nov 10, 2021 at 5:07 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I used CRC TB cleaner and a spare toothbrush. Let the spray cleaner work and lightly brush.
    TheBeast and SkipperPete[QUOTED] like this.
  2. Nov 10, 2021 at 6:16 PM
    SkipperPete
    SkipperPete New Member
    Pete
    Nicholasville, KY
    2012 Silver Tundra Crewmax
  3. Nov 10, 2021 at 6:39 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    D4x4TRD, Prostar 190, WVI and 5 others like this.
  4. Nov 10, 2021 at 7:38 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Started the install of my RTMR. Then it started raining again.
    D4x4TRD, Prostar 190, WVI and 4 others like this.
  5. Nov 11, 2021 at 10:14 AM
    shannon
    shannon New Member
    shannon
    Asheville, NC
    2010 DC
    What is an RTMR? Looks complicated.
  6. Nov 11, 2021 at 10:32 AM
    COElkHunter
    COElkHunter New Member
    Jeremy
    2012 Silver Tundra TRD limited Crewmax 4x4
    3" OME lift w/ UCAs. ARE overland shell w/ ARE roof rack. 34" Falken Wildpeaks. ARB awning. Road shower. Wilco Offroad Hitchgate Solo High Clearance. LED lighting upgrades. Lockerdown console safe. Weathertech floormats. Duluth deluxe rear seat cover to go under the offroad approved car seats.... :P
    Ordered my color matched Sequoia Pro grill from sparks parts... after much debate decided to go with this option, as I would probably be sleeping in the truck for a long while if I decided to do the Gen 2.5 front end swap... Much easier to justify "look at how chipped the chrome is on the grille, needs to be replaced... vs. "I decided to replace the entire front end of the truck, just so it would look cool..." Time to start shopping some ebay sequoia headlights. Already settled on a C4 overland bumper with a hoop to conceal the gap. Also my Victory cabover rack showed up last week.... So I looked at it for a few minutes, need to figure out when I'm going to get around to installing it, local 4x4 shops want almost as much as the rack cost to put it on... May need to send the wife on a "spa weekend", and send the kids to grandmas for a "sleepover"... :rofl:;)
  7. Nov 11, 2021 at 11:20 AM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    details on the cluster please. I have seen them for sale before.
    plug and play? Everything work? What color does it light up at night?
    more pics?
    thanks for your help
    joseph_womack likes this.
  8. Nov 11, 2021 at 1:22 PM
    Windsor
    Homeless in Oregon
    Some.
    Eaton/Bussmann Rear Terminal Mini Fuse and Relay panel (RTMR), auxillary panel. Wired with 5 constant power and 5 switched power with relays. A good way to get a clean aux power setup without multiple inline fuses coming off the battery.
    Very easy to install, the switched lines have color matched trigger wires and load wires. Constant power wires are a separate range of colors so nothing can get confused. Just looks confusing with 10ft leads rolled up, once installed it is clean.
    I ran #6 welding cable with an 80A breaker above the driver side headlight to provide power.
  9. Nov 12, 2021 at 5:55 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Just finished the last of 3 transmission drain drain and fills. The fluid is now nice and pink again.
    Half Assed, WVI, Mountun Goat and 3 others like this.
  10. Nov 13, 2021 at 1:12 PM
    Ricos
    Ricos New Member
    Ricardo
    2010 Tundra SR5 White Widow
    Never stopping ...
    Took the heads of because of a misfire and not smooth running V8 ‍♂️
    Half Assed, D4x4TRD, wv00097 and 6 others like this.
  11. Nov 13, 2021 at 6:23 PM
    shannon
    shannon New Member
    shannon
    Asheville, NC
    2010 DC
    Nice, look forward to seeing the finished product
  12. Nov 14, 2021 at 5:16 AM
    Danny3737
    3B419B4C-E985-47BD-A5CD-552502129211.jpg I added a new anti car-jacking device. It’s an FN 509 Tactical. Just have to figure on how I’m going to mount it in the console safe. I’m guessing I could probably use the same gun magnet I’m using for my SIG P365
  13. Nov 14, 2021 at 10:25 AM
    RikkiBobbi
    RikkiBobbi i'm Literally Rikki Bobbi
    RikkiBobbi
    Austin, Texas
    2021 Toyota Tundra TSS Off Road
    Linkit 3.0 wireless CarPlay, Husky Xcut, Tundra metal letter on trunk, upcoming .... Smartcap EVO shell, Rail system, bed cover, ceramic tint including windshield, tinted headlights and tail lights, full time gps alarm system with dash camera front and rear, bull nose for front, debating rear bumper, waiting on long gun locker for under rear seat with seat rail mods to sit flush and not raise back seat, Pedal Commander ordered as well as fender flares and tinted film for front logo and led conversion lights for all interior lights
    NOICE!
    Funny enough, got super lucky and was able to find a FN 502 last Tuesday in the coyote fd color, can't wait to get my can for it, ATF cashed the check 8 months ago so any day hopefully
    joseph_womack and MTRock like this.
  14. Nov 16, 2021 at 7:32 AM
    chaosbooboogunner
    chaosbooboogunner New Member
    Dennis
    2012 Tundra Crewmax White
    Yesterday I pulled the trigger and ordered some AlphaRex Pro Series jet black headlights. Hopefully will have in a couple weeks.
    toyofan87, MTRock and joseph_womack like this.
  15. Nov 16, 2021 at 5:56 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Nice! What are you plans for the low beam?
  16. Nov 16, 2021 at 7:36 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Tis the season y’all :burp:
  17. Nov 17, 2021 at 5:00 PM
    Silverghost
    Silverghost New Member
    13 tundra 4x4
    Ahhhh there she is and in its natural environment
    Mountun Goat[QUOTED] likes this.
  18. Nov 17, 2021 at 5:08 PM
    worktruckwhite
    worktruckwhite bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    Would love to hear how the ride improved when you get everything set up. Coming up on 190k now and know I'm in for some work in the future.
    Asmith2945[QUOTED] likes this.
  19. Nov 17, 2021 at 5:41 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    Got a $54 parking ticket for not parking between the lines after I paid $8 to park in the lot. No parking space to the right of me and didn’t want a door ding. Good job city of Spokane. :censored:
  20. Nov 17, 2021 at 5:58 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Isn't that the entrance/ exit beside you?
  21. Nov 17, 2021 at 6:06 PM
    20GR8 Super
    Corey
    PNW Outskirts
    Yeah but there is also a pole that marks the entrance/exit if you look at the back corner of my truck that I am within. Also that entrance/exit is wide enough to fit 4 trucks thru at the same time. Just confirms why I stay out of downtown.
  22. Nov 17, 2021 at 6:08 PM
    Shanet421
    San Diego,CA
    If we all could be so lucky
    Sleeper16plat likes this.
  23. Nov 17, 2021 at 6:26 PM
    Dr Doobie
    Talkeetna,Alaska
    Sucks man. you made yourself a easy target for the parking authority to take some of your hard earned coin.
    It was kinda like waking up opening day of hunting season and that legal bull is standing in your backyard.
    That's how easy it was
  24. Nov 17, 2021 at 6:28 PM
    20GR8 Super
    Corey
    PNW Outskirts
    Yeah I know…. My Christmas present to the city of Spokane.
    Dr Doobie[QUOTED] likes this.
  25. Nov 17, 2021 at 6:49 PM
    EagleClaw972
    EagleClaw972 New Member
    2008 Tundra Crewmax
    Straight Pipe, A/T on stock 20s, towing mirrors, kickers pro comp subs and amp
    Do you think a narrower wheel provides a smoother ride rather than a wider when. For example your 20x8.5 compared to a 20x10?
  26. Nov 17, 2021 at 7:07 PM
    Shanet421
    San Diego,CA
    You will get a “smoother” ride without 20s. The smaller the circumference of the rim allows for more sidewall on the tire.
  27. Nov 17, 2021 at 7:15 PM
    Just keep that shit up North of me. Lol
  28. Nov 17, 2021 at 7:16 PM
    That sucks.
    20GR8 Super[QUOTED] likes this.
  29. Nov 17, 2021 at 9:36 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    anyway to contest it?
  30. Nov 17, 2021 at 9:53 PM
    20GR8 Super
    Corey
    PNW Outskirts
    Ya there is. Thought about that just to be a pain in their side. Thought I would tell them that my truck is offended for calling her fat for not fitting in the spot. :)
