For Sale: Blind Spot Monitor Sensor part # 88162-0C033
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by RickC, Nov 14, 2021.
Thread Status:
Not open for further replies.
  1. Nov 14, 2021 at 3:52 AM
    RickC
    RickC [OP] NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    I had an issue with my BSM where basically, it stopped working. I took the truck to the dealer and they thought the issue was the sensor. Due to the cost to fix the issue, I decided to order the sensor and replace it myself. Long story short, the sensor wasn't the problem, so I now have a brand new sensor that I do not need. This could be used for a failed unit or possibly as a replacement if you have been in an accident. The retail on the part is 1100.00, I will sell it for 500.00.
    If anyone is interested, let me know and I can ship it out.
    Thanks,
    AggiePhil likes this.
  2. Nov 14, 2021 at 4:11 AM
    timsp8
    NY
    Can you not return it?
  3. Nov 14, 2021 at 4:17 AM
    RickC
    Rick
    Knoxville TN
    Can't return electrical parts.
  4. Nov 14, 2021 at 4:29 AM
    Motor71
    Motor71 teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
  5. Nov 14, 2021 at 4:36 AM
    AggiePhil
    College Station, TX
    Dang, that sucks man.
  6. Nov 14, 2021 at 4:49 AM
    RickC
    Rick
    Knoxville TN
  7. Nov 14, 2021 at 4:49 AM
    azs406
    azs406 New Member
    Do you have the techstream software to do calibration?
  8. Nov 14, 2021 at 4:52 AM
    RickC
    Rick
    Knoxville TN
    No
  9. Nov 14, 2021 at 4:54 AM
    azs406
    azs406 New Member
    That calibration has to be done after the sensor it replaced, and if there hasn’t been an accident it should be pretty straightforward.
  10. Nov 14, 2021 at 4:55 AM
    AggiePhil
    College Station, TX
    What are we getting at here?
    RainMan_PNW likes this.
  11. Nov 14, 2021 at 4:59 AM
    RickC
    Rick
    Knoxville TN
    That is correct.
  12. Nov 14, 2021 at 5:24 AM
    azs406
    azs406 New Member
    Did you have it calibrated?
  13. Nov 14, 2021 at 5:26 AM
    RickC
    Rick
    Knoxville TN
    Did I have what calibrated?
  14. Nov 14, 2021 at 5:30 AM
    azs406
    azs406 New Member
  15. Nov 14, 2021 at 5:41 AM
    timsp8
    NY
    He never installed it. Said that wasn’t the issue.
  16. Nov 14, 2021 at 5:45 AM
    RickC
    Rick
    Knoxville TN
    Right, this is a brand new part that wasn't used. My problem turned out to be a wiring issue so I still am using the original sensor that was on the truck to start with. Nothing had to be calibrated. And yes, calibration of the new part is required when replacing the original sensors.
    timsp8 and AggiePhil like this.
  17. Nov 14, 2021 at 10:45 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    So just 1 of the sensors around the truck costs 1100 to replace. Its gonna be a sad day when one of mine goes out.
  18. Nov 22, 2021 at 5:36 PM
    IA_Tundra
    IA_Tundra New Member
    Gator Mats
    Had one go out on my wife’s 15 highlander. Any idea if it’s compatible? Dealer ship wanted $1800 to fix one. It would have been $3000 for both.
  19. Nov 23, 2021 at 10:42 AM
    RickC
    Rick
    Knoxville TN
    From what I can see, the part number is different for a highlander.
  20. Nov 23, 2021 at 11:22 AM
    luckystiff
    luckystiff New Member
    Ken
    2016 XP in MGM
    Highlander is different part number.....
    I am an ADAS Tech by profession....
    RickC[OP] likes this.
  21. Nov 26, 2021 at 11:37 AM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    What/where was the wiring issue located with your BSM system? My BSM is currently not working and I’m getting a message on the screen in my dash saying “BSM Error contact dealer”.This just randomly appeared when driving home from work one day so I’m curious if it’s just a wiring issue and not anything to do with the sensors themselves.
  22. Nov 26, 2021 at 12:45 PM
    RickC
    Rick
    Knoxville TN
    At the passenger rear along the top of the frame is where the wiring is located and a critter had chewed mine which broke the line and I had no power to the sensor. I did not have any error codes on the dash. My symptom was no light came on when pushing the dash switch in.
  23. Nov 26, 2021 at 1:41 PM
    Yota303
    Washington
    Damn critters! Bummer you bought the sensor before you found the culprit. I honestly have no idea why mine stopped working although I do remember possibly blasting a big puddle on the side of the road while driving in the rain that day… I’ve read that if the sensors get covered with mud or other debris they might not function properly. Seeing as how they are tucked up in the bumper caps pretty well I don’t think that would be the case, I just haven’t had the time to pull the bumper covers to where I can actually see if they are clean or not. I guess that’s my best place to start though. Thanks for the input and good luck with your sale. If I end up needing to buy a new one I will let you know for sure.
  24. Nov 27, 2021 at 5:11 AM
    RickC
    Rick
    Knoxville TN
    They are protected pretty well but I have heard that mud, snow and ice can interfere with them. Good luck!
    Yota303 likes this.
  25. Nov 28, 2021 at 5:49 AM
    coTony
    Tony
    Montrose, CO
    I have my sensor in the garage cabinet. Removed it when the bumper was replaced
  26. Dec 3, 2021 at 5:34 PM
    Akaklutz
    Akaklutz New Member
    Alan
    2021 Tundra
    New stock
    Any issues not using the sensors?
    The winch bumper I have coming doesn't take the sensors. Thought about drilling it out to accept the sensors. But broke one today.
  27. Dec 3, 2021 at 5:40 PM
    Kdogg77
    Kdogg77 If it ain't broke, it will be...
    Ken
    Central Cali
    2017 Tundra Crewmax
    6" RC suspension lift, 18" Pro Comp wheels, 35x12.5x18 tires, RC front/rear bumpers, RC Grill insert, Spider No Drill Roof Rack, Lighting by RC and Cali Raised. Interior mods include AJT Designs, Pioneer, and Rockford Fosgate.
    And to think I sold both of mine when I replaced my rear bumper for $200 on eBay.
  28. Dec 21, 2021 at 7:21 AM
    coTony
    Tony
    Montrose, CO
    No issues because I turned them off on the steering wheel, otherwise you get errors. I would think one could get in the ECU and just turn off the sensors not used
  29. Aug 11, 2022 at 8:53 AM
    RickC
    Rick
    Knoxville TN
Thread Status:
