My 2001 needs a tail gate latch handle…again!!
Discussion in '1st Gen Tundras (2000-2006)' started by Adventundra, Nov 9, 2021.
  1. Nov 9, 2021 at 10:43 AM
    Adventundra
    Adventundra [OP] New Member
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    I think this is the 3rd one that shit the bed!!
    anyone have same experience or recommend what brand to get? They range from $12-$109….I shud just buy 3 at a clip n keep em at the ready!!
  2. Nov 9, 2021 at 12:48 PM
    Two tips:
    1) Handles break when you don't lube the damn tailgate mechanicals, something you should do at least once every couple of years depending on your climate and use.
    2) If you buy aftermarket garbage chinesium parts on Scamazon and Fleabay, you're gonna go thru this time and time again and spend far more than OEM over time!
    I highly recommend you find a used genuine OEM part on fleabay or at the local junkyard OR go buy a new OEM unit, part number for '01 appears to be 690900C010 or sometimes stylized as 69090-0C010, and you should be able to run the same numbers thru eBay to find used parts if you don't want to spend the coin on new.
    Better yet - hit your local junkyard or find a part through car-part.com
    bmf4069, KNABORES and Adventundra[OP] like this.
  3. Nov 9, 2021 at 2:38 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Outstanding!!
    Thanks!! I will definitely keep up w lubing mechanicals of handle!!
  4. Nov 9, 2021 at 2:51 PM
    It's usually not the handle that causes it. It's lubing the latches on either side of the tailgate, from the inside and outside.
  5. Nov 9, 2021 at 6:36 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Mine was taking a lot of effort to drop the tailgate, and I knew that if I didn't lube it, something would break. So before that happened i pulled the access panel, cleaned all the pivot and friction points, lubed with some white lithium grease, and now it opens and releases the tailgate with just one finger. Took about 20 minutes.
    Adventundra[OP], bmf4069 and shifty` like this.
  6. Nov 13, 2021 at 3:30 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Bought 2 handles to keep one on hand in case in happens again. Will definitely keep an eye on lubing mechanics n linkage of system. And I reinforced the new handles where they always seem to break…along the inside angle of plastic handle.
  7. Nov 14, 2021 at 7:38 PM
    ionstorm66
    ionstorm66 New Member
    The cheap ones have no glass fiber in the plastic, you can twist the entire assembly by hand. The OE ones are glass fiber reinforced. You can make the cheap ones last by only grabbing the passenger side of the handle.
    Adventundra[OP] likes this.
  8. Nov 15, 2021 at 3:56 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Thanks
  9. Nov 15, 2021 at 4:55 AM
    mgxsequioa
    mgxsequioa New Member
    I had a similar issue on my 01 Sequoia, it broke 2 times the night before a trip (not sure why during the hot summer vs cold winter nights). It was always the plastic piece that was connected to the latch release cable. I never thought about reinforcing that part, but it makes sense. I just put a pair of needle nose pliers in my door pocket to release it.
