General Supercharger Thread
  1. Nov 8, 2021 at 5:58 AM
    #721
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I'll delve into the "turning off the nannies" soon.
    that ought to be a hoot.
  2. Nov 8, 2021 at 6:10 AM
    #722
    snivilous
    SW UT
    300k+ Supercharged 2008
    I assume you have an external AFR gauge. I monitor AFR constantly, especially anything higher than cruise. It's just another gauge to constantly glance at like everything else. Idle and WOT seems pretty straightforward, the middle section is where I get nervous and watch it more (how I found lean outs before). I had Viktor set up my tune so the instant I start building any boost it starts richening out so I watch that to make sure it's adding fuel when I expect. I also have TorquePro on my phone, and besides monitoring the obvious like the trans and coolant, I have AFR again (just to cross reference my external gauge), intake temp, and timing. Intake temp is at the MAF, timing I have an idea of where things should be after watching the truck for so long so glance at that to make sure it's not getting pulled for some weird reason. For 99% of things, as long as AFR is happy I'm happy, if I'm pushing anything then I start watching ATF and coolant but that's about it really.
    There's been a few automatic nanny shut off kits that people have made. I don't know if they work on the 2020, but I'd look into them. Start the truck, by the time oil pressure is up all the traction control has been fully disabled. Pretty nice.
  3. Nov 8, 2021 at 6:10 AM
    #723
    boringdriver
    boringdriver New Member
    2015 LX 570
    Do you have a Dragy unit to capture 0-60, 1/8th and 1/4 mile times? Whatcha waiting for lol
  4. Nov 8, 2021 at 6:25 AM
    #724
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Thanks Snivilous
    AFR gauge...I am using the scanguage. it is not instant & runs thru the OBD system. it is not reading the same as before the tune. looking into that now.
    I will ask D3 about installing an external one. Will this need a new bung on the exhaust?
    one of my graph requests is HP+TQ+AFR for Stage 2.
    and I assure you, I do not need Nannies automatically shutting off!! I know me.
  5. Nov 8, 2021 at 6:27 AM
    #725
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Looking it up now....
  6. Nov 8, 2021 at 6:31 AM
    #726
    nobodyintexas
    nobodyintexas What?
    South of Houston
    is there an app that does this without ordering the in car gizmo?
  7. Nov 8, 2021 at 8:04 AM
    #727
    nobodyintexas
    nobodyintexas What?
    South of Houston
    as promised...notice TQ is moving higher @ lower RPM.
  8. Nov 8, 2021 at 8:21 AM
    #728
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Wow those low RPM gains are massive. That must feel like night and day from no tune.
  9. Nov 8, 2021 at 8:24 AM
    #729
    nobodyintexas
    nobodyintexas What?
    South of Houston
    tru dat
  10. Nov 8, 2021 at 1:41 PM
    #730
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    We should do a comparison dyno, I'm installing mine around X'mas break and going to run D3 vs vftuner.
    Platinum714 and omgboost like this.
  11. Nov 8, 2021 at 1:48 PM
    #731
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Now we're talking.
    one of the D3 tuners has a mean Mag Tundra.
  12. Nov 8, 2021 at 2:15 PM
    #732
    Downytide
    GTA
    I've mentioned to Dinesh that I'm not chasing ultimate hp, I'll leave that up to you crazy lots.
  13. Nov 8, 2021 at 2:23 PM
    #733
    nobodyintexas
    nobodyintexas What?
    South of Houston
    famous last words....
    omgboost likes this.
  14. Nov 8, 2021 at 2:42 PM
    #734
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I remember a guy sayin' he was OK with Stage 1
    ...and won't be the guinea pig for stage 2
    that same guy is looking at the Sequoia air intake Chris-Harrop built.
    Diderot effect.
    AZTundra, Saltyhero13 and sd172 like this.
  15. Nov 8, 2021 at 2:54 PM
    #735
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Man, now that you've upgraded, gonna have to start a stage 2 thread
    :monocle:
    SnowyTundra and Saltyhero13 like this.
  16. Nov 8, 2021 at 2:56 PM
    #736
    nobodyintexas
    nobodyintexas What?
    South of Houston
    as soon as some of you hombre's get off your wallet and come inside the big tent.
    folks go to the circus to see the elephants.
  17. Nov 8, 2021 at 3:05 PM
    #737
    Dr Doobie
    Talkeetna,Alaska
    I'd love to upgrade to a harrop , but I'll be stuck with my Maggie and the clowns for a long time, my wife and kids owns my wallet:(
  18. Nov 8, 2021 at 3:28 PM
    #738
    nobodyintexas
    nobodyintexas What?
    South of Houston
    One can get a smaller pulley for the mag.
    and still sleep inside with the rest of the family
    1UP, AZTundra, snivilous[OP] and 2 others like this.
  19. Nov 8, 2021 at 3:32 PM
    #739
    Dr Doobie
    Talkeetna,Alaska
    :yes:
  20. Nov 8, 2021 at 3:55 PM
    #740
    snivilous
    SW UT
    Unless you're building the bottom end, the mag will keep up with the Harrop so I wouldn't worry. Victor was pushing like 15psi through it before he determined he needed to swap to the Harrop and he fully built his engine to reach the magnusons limit to begin with. Not to say the Harrop isn't "better", but until 600-700whp they're comparable.
  21. Nov 8, 2021 at 4:15 PM
    #741
    Dr Doobie
    Talkeetna,Alaska
    Yeah I definitely have no plans on building and don't want to replace my engine any time soon!
    It received the used blower later in life at 183k and I'm plenty happy with the performance and power (and speeding warning from troopers) that I have with my Maggie right now...
    But the ol' Maggie will need a tune up at some point, so instead of refurbishing my blower I'll hopefully be able to upgrade to a harrop.
  22. Nov 8, 2021 at 4:27 PM
    #742
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    2019 platinum 4x4 magnetic gray
    Is the D3 tuner able to revert back to original ecu if Needed? Do you feel that it’s worth cleaning up the tune for stage one? Or not worth the overall cost?
  23. Nov 8, 2021 at 4:39 PM
    #743
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Stage one tune is necessary and worth it
    see my graphs
    you can live without it. I did. For a while
    And yes. You can revert
    Platinum714[QUOTED] likes this.
  24. Nov 8, 2021 at 4:49 PM
    #744
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    I wonder if you went to stage 2 (pulley, fuel rail, air box) but reverted back to stage 1 to pass California smog, would that damage anything during that testing period?
  25. Nov 8, 2021 at 4:55 PM
    #745
    AZTundra
    Paul
    Phoenix, AZ
    You guys are really making me consider moving up to the smaller pulley and dyno tuning on my Maggie.
  26. Nov 8, 2021 at 4:57 PM
    #746
    Saltyhero13
    Saltyhero13 Throbbing Member
    I would guess most likely yes you would damage something based purely based on the Harrop tech paper. Not sure if you swapped back to the bigger pulley though, probably run rich.
  27. Nov 8, 2021 at 5:13 PM
    #747
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Thanks to you both! You answered exactly what i was asking.
  28. Nov 8, 2021 at 5:21 PM
    #748
    Saltyhero13
    @Platinum714 I would like to hear others thoughts on your question. I'm not a motor head so this is new to me.
    I'm thinking big pulley allows the stock components to operate on the stock fuel map (by pulling timing). This is Stage 1.
    Upgrade to smaller pulley is pulling in more air which requires ECU remap for fuel table and bigger injectors for more fuel flow. This is Stage 2.
    Delete the tune and revert back to stock ECU you are off the fuel map with the smaller pulley but now the ECU is in danger of running lean since it doesn't know it can increase fuel flow (or can it?). Going back to the bigger pulley puts you back to Stage 1 but with bigger injectors. I think there is another feedback loop besides MAF that allows the ECU to adjust AFR.
    Curious to hear how others think this through.
    nobodyintexas and Platinum714 like this.
  29. Nov 8, 2021 at 5:52 PM
    #749
    Silver17
    Eastern PA
    My thought is it probably wouldn’t hurt to just about idle it down the street into their parking lot for inspection. But in my state they take it for a test drive, so I’d think that could be a problem. I wouldn’t dare drive it any kind of distance, significant amount of time, or give it any more than the bare minimum amount of throttle without the tune flashed though. Maybe my thoughts would be considered being overly cautious? Can’t say with certainty, maybe someone else can.
    To add to this I don’t think the additional airflow from the smaller pulley is as much a concern when driven easy because the supercharger doesn’t start making boost until you get deeper into the throttle due to the bypass valve. I think the additional fuel from the 650cc injectors would be more likely make it run rich under this scenario.
  30. Nov 8, 2021 at 11:32 PM
    #750
    Saltyhero13
