  1. Nov 3, 2021 at 5:28 PM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    it sure does.. but shit happens.
    800 for her, 500 for me and everyone is happy..... besides.....me :anonymous:
  2. Nov 3, 2021 at 5:34 PM
    raymond_hb
    raymond_hb New Member
    Oakland, CA
    07 Tundra Limited 2WD
    I tend to push my sensors until I can hear them scream for help. Being the owner of a pick up taught me geometry a class I failed multiple times in school but better late than never lol. Glad you didn’t tear those bumpers off that’s for sure I would cry for that Land Cruiser
  3. Nov 3, 2021 at 5:41 PM
    Blang805
    Blang805 New Member
    Build in Signature
    they screamed until it stopped and i thought i was clear... next thing you know i give it gas and her entire car moves...i knew a fuged up then.
    Her cruiser is a little bruised up. The missing paint under the light was from her backing into a hill.. the big obnoxious stuff was me :facepalm:
  4. Nov 3, 2021 at 5:55 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    $500 for you? Yours just like it needs a little touch up paint
  5. Nov 3, 2021 at 6:00 PM
    Blang805
    Blang805 New Member
    Build in Signature
    its got some clear coat pealing and a few little rock chips so im just getting it all repainted.
    azimuth likes this.
  6. Nov 3, 2021 at 7:12 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Changed the steering rack bushings to polyurethane while I have the whole front end torn apart for 6" lift. I'm not sure if the lift brackets are going to block access to remove the rack bolts later.
    I'm going to try cracking the clamshell diff open and welding it this weekend if I can get it apart without too much work. :monocle:
    worktruckwhite and Dr Doobie like this.
  7. Nov 3, 2021 at 7:42 PM
    Ouch
    Blang805[QUOTED] likes this.
  8. Nov 4, 2021 at 11:40 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    welding the front diff?
  9. Nov 4, 2021 at 5:00 PM
    Half Assed
    Heartland Florida
    Yes. ARBs are expensive. And if you're putting in a locker, you might as well get 5.29 gears too. Next thing you know you're $3000 poorer. :laughing:
    I think I'm going to buy a slide hammer tomorrow and remove the half shaft. That way i can completely remove the carrier from the rest of the axle assembly.
  10. Nov 4, 2021 at 5:29 PM
    CM2007
    CM2007 New Member
    Northern California
    2007 CrewMax SR5
    TRD Exhaust, Dark Tint, Bluetooth (2020 or earlier) License Plate Camera (2021) Tyger T1 Roll Up Tonneau (2021) Loncky leather steering wheel wrap (2021) Dechromed with Plasti-Dip (2021) Osram Reverse Bulbs (2021) Bilstein 6112s up front (April 2021) 2022/2023: New Head Unit (Android?) Sliders/concealed running boards
    I did this wrap a few months ago and it still looks really good. I used the double stick tape on the front…and I can definitely see a faint outline and it kind of bugs me. Not worth redoing! Took 4 hours.
    WVI and omgboost like this.
  11. Nov 5, 2021 at 1:38 AM
    Blang805
    Blang805 New Member
    Build in Signature
    you can check my build thread in my signature but i did get my wheels and Eibach lift installed.
    Tomorrow it goes in for an alignment.
  12. Nov 5, 2021 at 8:00 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I think you'll like the Eibachs.
    Been rocking them for about a month and liking them more and more.
    I really need to get on some trails, but the truck is way more engaging to drive around town. To the point my mileage has taken a definite hit from being more aggressive on the throttle.
    My other main driver is quite low and relatively stiff, so I quite enjoy being able to disregard speed bumps in a drama-free way.
    Git yerself aligned and start breaking those bad boys in!
  13. Nov 5, 2021 at 1:10 PM
    joseph_womack
    Joe
    Louisiana
    I like mine a lot! I've had them on for a good 2-3 months now, I've got them set on the top setting (added weight of my front bumper) and I'm gonna get aftermarket UCA soon
  14. Nov 5, 2021 at 2:42 PM
    Blang805
    Blang805 New Member
    Build in Signature
    Got it aligned today and it’s rides super true and extremely nice. No UCA was required which was nice. 295/70 don’t rub at all either which was surprising but also a relief. I did cut the “wings” off the skid plate to be sure but that’s nothing to serious. This was with it installed with the 2” option.
    Hope I can help with peoples decision on lift and tire size.
    Edit: I have a very very light rub on the sway bar in both directions at full lock. You cannont hear it inside unless the radio is off. I only noticed it from tiny feedback in the steering wheel.
  15. Nov 5, 2021 at 4:10 PM
    TXTundraSC
    TXTundraSC New Member
    College Station, Tx
    2011 Tundra Platinum 4x4 s/c
    Magnuson S/C, trd exhaust, trd rear sway bar, trd front sway bar, toytec 2.5” level, debadged, toyo r/t 305/55r20
  16. Nov 5, 2021 at 5:19 PM
    Danny3737
    Did the first of 3 drain and fills on my trans. I was expecting it to look worse after 175K. I don’t think the previous owner ever changed it. I was happy it didn’t have a burnt smell. My daughters boyfriend works for a dealership and got me 2 cases of WS fluid for $8.00 a quart.
  17. Nov 5, 2021 at 5:52 PM
    chaosbooboogunner
    chaosbooboogunner New Member
    Dennis
    2012 Tundra Crewmax White
    Added a new trd rear sway bar this afternoon. It’s truly amazing how much room is under these trucks when the spare tire is removed.
  18. Nov 5, 2021 at 5:58 PM
    biebs96
    PA
    you should save this comment and repost it whenever anyone asks “will a 35” spare fit..”
  19. Nov 5, 2021 at 6:15 PM
    Danny3737
    Did you notice a difference? I noticed It right away.
  20. Nov 6, 2021 at 9:42 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
  21. Nov 6, 2021 at 12:35 PM
    worktruckwhite
    worktruckwhite bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    Replacement mirror! Dealer installed a backup camera mirror at purchase, a few years later a screen was put in the dash so it's been moot. Had a replacement windshield installed and the guys found out that it was superglued on due to a missing bracket, so off it went. Cut the cable, tucked it into the headliner, and the "mod" is restoring the mirror to OEMIMG_4383.jpg IMG_4388.jpg IMG_4389.jpg
    Prostar 190, D4x4TRD, MTRock and 3 others like this.
  22. Nov 6, 2021 at 12:41 PM
    joseph_womack
    Joe
    Louisiana
    TheBeast, MTRock and omgboost like this.
  23. Nov 6, 2021 at 12:41 PM
    joseph_womack
    Joe
    Louisiana
  24. Nov 6, 2021 at 1:30 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I'm always afraid some db would take the magnet and run with it. And the price is $10 vs $40. I'd rather pay the $10 and then donate $30 directly to a veterans charity.
    joseph_womack[QUOTED] likes this.
  25. Nov 6, 2021 at 1:46 PM
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    F86CADED-61FA-423B-AAFA-6EF214448E77.jpg When the RV ends up in the shop….. you go with Plan B. Drove it to Gordon’s Well for a 1 nighter :)
  26. Nov 6, 2021 at 1:51 PM
    drobb
    EB4DFEF1-52F2-44A6-A7B1-F880FAEC177A.jpg Camp set up…. Time to ride!
  27. Nov 6, 2021 at 2:33 PM
    Danny3737
    Installed a black Rock Warrior grill on my Platinum to match the paint. Now I just Need to decide what I’m going to do about the chrome emblem. 59A2E4F9-99A9-4FA4-A22C-DB236658BCCE.jpg
    Prostar 190, Dr Doobie, drobb and 7 others like this.
  28. Nov 6, 2021 at 3:48 PM
    Half Assed
    Heartland Florida
    Welded the front diff and put it back together.
  29. Nov 6, 2021 at 4:21 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Whoa going full on offroad army now huh haha. Nice I’m excited to see how you like it after. If it’s legit I’m copying you haha
    joseph_womack and MTRock like this.
  30. Nov 6, 2021 at 4:21 PM
    Blang805
    Blang805 New Member
    Build in Signature
    Truck is all done!
