5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Oct 26, 2021 at 2:47 PM
    #1081
    Chip_Tundra
    Chip_Tundra New Member
    Even if you don't tow, it's a must have.
  2. Oct 26, 2021 at 6:21 PM
    #1082
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Just ordered my kit , can someone please provide some insight on the below
    1) when installing the thermostat , is it only the O rings from the spacer that needs to be replaced or also the ones on the puck
    2) when level check the fluid , you need to shift to all gears and reverse based on the install guide , do you need to do it once or keep doing it till it reaches 99?
    3) I have read couple of comments where the bottom bolt on the puck won’t thread and they had to replace it with the horn bolt , is it something common or expected with each install ?
    4) anyone tried running the hard lines without removing the skid plate or removing it is a must ?
  3. Oct 26, 2021 at 6:27 PM
    #1083
    pursuit2550
    pursuit2550 New Member
    The new T-stat brings new o-rings.
    PDF for oil check on here https://www.tundras.com/threads/gen-3-transmission-fluid-level-check-temperature-range.18359/
    Havent read or ran into that issue, yet.
    Its a must. Have to get to bolts and lines.
    Jtundra81[QUOTED] likes this.
  4. Oct 26, 2021 at 6:42 PM
    #1084
    Jtundra81
    Joe
  5. Oct 26, 2021 at 6:48 PM
    #1085
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    I ran through gears until it reached temp, including hopping into S and bouncing through the gears. Dunno if necessary but that’s what I did.
    The horn bolt wasn’t for the puck. The horn bolt was up front, for the cooler itself. I had to use it on the lower most bolt for the bracket where the bracket bolts onto the truck.
  6. Oct 27, 2021 at 7:50 AM
    #1086
    Wheresmytranscooler
    Wheresmytranscooler New Member
    Brad
    2019 Tundra SR5 TRD
    Does the OBDFusion app with Toyota enhanced diagnostics allow the user to reset the transmission thermal degradation estimate?
  7. Oct 27, 2021 at 8:01 AM
    #1087
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    I haven’t found an OBD app that allows for that. I’ve got myself a very basic Asus laptop with deleted WiFi card that runs Techstream.
    http://blog.obdii365.com/
    You will probably need a 2.0.4 firmware cable that supports newer ECUs and live data.
  8. Oct 27, 2021 at 8:07 AM
    #1088
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Possible Supercharger in the future is why I went with the Setrab.
  9. Oct 27, 2021 at 9:39 AM
    #1089
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I just ordered the Setrab.
    On the day I install, I cannot guarantee that the universe will not run out of cuss words.
    sd172, Jtundra81 and Saltyhero13 like this.
  10. Oct 27, 2021 at 9:40 AM
    #1090
    :rofl: That was me while trying to install my S8 in the hood bulge.
  11. Oct 27, 2021 at 9:43 AM
    #1091
    Jtundra81
    Joe
    Got mine too yesterday , I think I will hook up the cooler and hard lines first and keep the thermostat / refill as last steps , let us know how it goes . Will be doing mine in the next couple weeks
    nobodyintexas[QUOTED] likes this.
  12. Oct 27, 2021 at 9:45 AM
    #1092
    Allrsdup
    Allrsdup New Member
    Joe
    24 Lunar Rock Limited crewmax trd ord
    I ran the hard lines without removing my TRD pro skid plate Is it a little bit tricky Yes but it can be done.
    I shifted the transmission through all the gears a couple of times and then waited for attempts to reach 99° before checking fluid.
    No issues with the bolts they line up right up it's an OEM part shouldn't be any problem.
    When you remove the spacer the o-rings will be stuck to the side of the transmission take them off the thermostat replaces the spacer and has its own o-rings
  13. Oct 27, 2021 at 9:46 AM
    #1093
    Jtundra81
    Joe
    Thank you
    Allrsdup[QUOTED] likes this.
  14. Oct 27, 2021 at 9:48 AM
    #1094
    nobodyintexas
    nobodyintexas What?
    South of Houston
    if Lazy-Boy made a creeper that lifted you off the ground....I wouldn't even ask the price.
    Pig Rig, Saltyhero13 and Bammer like this.
  15. Oct 27, 2021 at 10:35 AM
    #1095
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
    1) the orings from the spacer stuck to the mounting surface of the transmission when I removed the spacer. If this happens just ensure you remove them as the thermostat has its own orings. The puck reuses it’s orings.
    2) I had my wife continue to cycle through the gears til the pan temp reached 99f, maybe about 2 or 3 times.
    3) I did not have an issue with any of the bolts.
    4) I removed my RCI skid before install. Didn’t even look to see if it could be accomplished without removal. If anything it adds a little more clearance to roll around on the creeper.
  16. Oct 27, 2021 at 2:42 PM
    #1096
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    To my understanding the thermostat switch opens at 195f. I assumed it would be triggered by the pan temp however it seems to be opening when the TC hits 195+. I only have a few country drives since installing the aux cooler but I haven’t been able to get the pan temp above 185f since install. Does anyone know the relation between the pan temp and TC temp in reference to triggering the thermostat? Just curious is all.
    Saab95v6 likes this.
  17. Oct 27, 2021 at 3:08 PM
    #1097
    EatSleepTacos
    Randy
    West Valley, AZ
    I was wondering that too, just out of curiosity.
  18. Oct 27, 2021 at 8:16 PM
    #1098
    Allrsdup
    Allrsdup New Member
    Joe
    It's not a full open or full closed situation It will partially open similar to a thermostat in your cooling system.
    batman900 likes this.
  19. Oct 30, 2021 at 11:03 AM
    #1099
    Wheresmytranscooler
    Brad
    2019 Tundra SR5 TRD
    I was told by my local dealer that the 2019 trans temp check mode was the same procedure as earlier models. I was not able to get it to work. The issue I had with using an IR thermometer on the pan is that I was seeing about 20+ degrees difference depending on where I was measuring temp.
  20. Oct 31, 2021 at 8:13 PM
    #1100
    dankberries
    dankberries New Member
    2020 Tundra
    Just got mine installed two nights ago. MHX-514
    Had I not Stubbled across this thread I would have never thought about it being a problem.
    Before I made any commitment to purchasing I got the obd reading process going to collect some data.
    To my surprise the trans in my truck runs hotter than I expected or am comfortable with accepting.
    I commute up and down a mountain 6 days a week and gain 3000ft elevation between 5500ft and 8500ft.
    In the first week with ambient temps between 50-70° F the trans was peaking as high as 245°F and consistent in the 200-230°F range.
    No load in the truck or towing during the data collection but the truck is on 37's.
    After the install my peak temp at the TC has been 215° but briefly gets there before falling lower.
    Very happy with this install. Thank you forum!
    I'm would love a data sheet or something from the FSM showing the temperature range between close and fully open on the thermostat.
    Also I found the install pretty easy, one thing that helped me fit the in/out lines from the cooler to the chassis mounted hard lines was removing the dust/dirt curtain by the strut. I was able to reach my right hand through and made it a little easier.
  21. Nov 1, 2021 at 9:19 AM
    #1101
    68rs75z28
    68rs75z28 New Member
    2020 tundra sr5 dc
    Awesome!
    Also that new peak temp is just the thermostat opening and working!
    Mine seems to open around 190 and then settles the temp at 185. When I pinned it, the temp would never get above 175. Glad to hear its working for you!
    dankberries[QUOTED] likes this.
  22. Nov 4, 2021 at 12:45 PM
    #1102
    Jtundra81
    Joe
    Got my kit last Saturday , the cooler itself had a bent bracket , Nick shipped a brand new replacement after 5 min from when I sent the email.
    Got the new one today and I started assembling the cooler kit and brackets , once I get some free time , will level up the truck and get everything installed .
    Everything is premium and overall awesome kit and Nick is an awesome guy to deal with.
  23. Nov 4, 2021 at 4:32 PM
    #1103
    Genuine Cooling Systems [OP] New Member Vendor
    *** SOLD OUT *** MHX-514 oil coolers with ugly welds that will fit the 2019-2021 Tundra. The welds are still structurally good however, one may call them ugly. I’m offering $200 off these MHX-514 coolers which will be put the total price of the kit at $799. These oil coolers will still be covered under Improved Racing’s lifetime warranty. Link to the kit is referenced below. Please email me at genuinecoolingsystems@gmail.com if you’d like a MHX kit at a steep discount.
    https://genuinecoolingsystems.com/product/mhx-514-complete-kit/
  24. Nov 4, 2021 at 4:41 PM
    #1104
    18" TRD Off Road Wheels
    DAMMIT! That's such a good deal! I already planned to snag a bed rack on a Black Friday deal, and now you do this! :annoyed:
    batman900 and RobertD like this.
  25. Nov 4, 2021 at 4:48 PM
    #1105
    Only 4 left!
  26. Nov 5, 2021 at 6:56 AM
    #1106
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    PM and email sent!
  27. Nov 5, 2021 at 8:13 AM
    #1107
    Only 1 more left folks!
    GODZILLA likes this.
  28. Nov 5, 2021 at 8:36 AM
    #1108
    That's nuts! I hoped they'd last just a little longer. I'll have to get one a bit later and "settle" for my bed rack later this month. This is a screamin' deal and congrats to the lucky 5!
  29. Nov 5, 2021 at 4:30 PM
    #1109
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
  30. Nov 5, 2021 at 4:33 PM
    #1110
    GCanuck
    Gary
    BC,Canada
    The software numbers listed on the OP. Are they for post install of a cooler or general for a Tundra?
