Show off that REFLECTION.
Discussion in 'Detailing' started by Ted4311, Apr 22, 2019.
  1. Oct 23, 2021 at 7:56 AM
    #2611
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    Silky smooooveee.
  2. Oct 31, 2021 at 12:56 PM
    #2612
    Ckatz53
    Ckatz53 Newish
    MD
    Practicing my wetsanding on severe defects on one of the hardest doors you could think...OEM black Honda paint. Not pictured is the upper door that I royally fucked attempting to dry sand lol. Never tried dry sanding before...it is intense. It's a donor door so no harm no foul. Last photo shows the middle portion that was just as bad as the bottom.
    20211030_145102.jpg 20211030_150631.jpg 20211030_153248.jpg 20211030_153314.jpg
  3. Nov 1, 2021 at 4:24 PM
    #2613
    briarpatch
    briarpatch New Member
    I need to go to the local yard and pick up some panels to practice on. I've done a little wet sanding in my day, but not for many many years.
    Ckatz53[QUOTED] likes this.
  4. Nov 1, 2021 at 7:27 PM
    #2614
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    From the weekend.
  5. Nov 3, 2021 at 6:14 AM
    #2615
    TXTundraSC
    TXTundraSC New Member
    College Station, Tx
    2011 Tundra Platinum 4x4 s/c
    Magnuson S/C, trd exhaust, trd rear sway bar, trd front sway bar, toytec 2.5” level, debadged, toyo r/t 305/55r20
    Coated the wife’s new whip last night!
    2D9596E2-26D5-45CC-A407-BD94577B3050.jpg C1CE9A67-04C7-4ED5-A7F5-5EBE70108C04.jpg
    Prostar 190, Ckatz53 and Fotnot like this.
  6. Nov 3, 2021 at 6:20 AM
    #2616
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    looks good. what was your process and what did you use?
  7. Nov 3, 2021 at 6:47 AM
    #2617
    TXTundraSC
    College Station, Tx
    @Fotnot I washed, clay barred, Adam’s water spot remover(seriously magical) then used Adam’s Polishes one step polish w/ one step pad. I experimented with the Adam’s Ceramic Spray coating on my tundra and the results were phenomenal, so I used it on the X7 as well. Just need a microfiber applicator and crosshatch the spray coating over the entire vehicle. Just have maintain with a ceramic boost every 4th wash or I use their Graphene detail spray when drying the vehicle off after every other wash.
    Fotnot likes this.
  8. Nov 3, 2021 at 6:56 PM
    #2618
    doggiecareman
    doggiecareman YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    Traded in wife's '16 Rav for this '21 Hybrid Rav and picked it up today. Two coats of Gtechniq.
    737AF85E-8AB0-42F2-8FCE-88B5FBD2575D_1_201_a.jpg FFD43B38-8290-44DA-88D0-C0CE080300DC_1_201_a.jpg 1230CC2C-5EF1-444D-9270-5285A72FFFD9_1_201_a.jpg
  9. Nov 3, 2021 at 7:37 PM
    #2619
  10. Nov 6, 2021 at 1:49 PM
    #2620
    Ckatz53
    Ckatz53 Newish
    MD
    One stepped and Undrdog Pro coating on everything. I really enjoy this stuff.20211106_164612.jpg
  11. Nov 6, 2021 at 4:40 PM
    #2621
    briarpatch
    What was your one step? I've been looking for a 3D One alternative
  12. Nov 6, 2021 at 4:45 PM
    #2622
    Ckatz53
    Ckatz53 Newish
    MD
    This was Uro 50/50s and 3D One. I've been messing around with a different application process that has been helping me circumvent the oily wipedown. Instead of blotting onto my pad, I've been putting dabs on the panels down the entire length of the car (as if I were doing rotary work), and spreading it as usual on low speed and working on full panel at a time. Blow out my pad, move to the next panel. Once I'm done the entire half of the vehicle, I go back to wipe where I began and it is significantly easier/less messy to wipe by the time I've made it back to panel #1.
    If I were to do anything else, it would be a mixture of Angelwax Regenerate (medium cut) and Redemption (fine polish) 2 dabs of each on a pad. I haven't found anything that's cuts and finishes as well/quickly as that combo in the way of a one step. Toss some of their heavy cut in there and it still finishes out amazing with a bit more initial bite. Angelwax is just super expensive so in the name of saving $$$ with the business overhead, I've continued with 3D One and altered my procedure.
  13. Nov 7, 2021 at 11:33 AM
    #2623
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Wash, hand wax, beadmaker, ready for winter.
  14. Nov 7, 2021 at 11:56 AM
    #2624
    Ckatz53
    Ckatz53 Newish
    MD
    F250 and X5 M Competition today.
  15. Nov 7, 2021 at 12:06 PM
    #2625
    18" TRD Off Road Wheels
    :drool:
    Both. :muscleflexing: I'm so lucky you live on the other side of the country. My truck would be absolutely gorgeous, but I'd be paying your mortgage!
  16. Nov 7, 2021 at 12:08 PM
    #2626
    Ckatz53
    Ckatz53 Newish
    MD
    Hah this dude is a retired coworker and has more money than he knows what to do with. The toy hauler next to it has 100k worth of ATVs in it and the garage has a Lambo and white X5. We are coating both these vehicles sometime this winter when he can find some free time.
    Prostar 190 and GODZILLA[QUOTED] like this.
  17. Nov 8, 2021 at 4:53 AM
    #2627
    Ckatz53
    Ckatz53 Newish
    MD
    Fun fact: this '19 Taco's color code looks black but after polishing her up, you can see a ton of dark dark dark blue metallic flake. Pretty nifty. Owner didn't even know it had those until we dropped it off to him last night and he had a first look since the work.
    One stepped and UD Pro.
  18. Nov 8, 2021 at 9:40 AM
    #2628
  19. Nov 8, 2021 at 11:10 AM
    #2629
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
  20. Nov 15, 2021 at 7:02 AM
    #2630
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Still trying to get a good reflection out of the lunar rock. Better lighting would prob help tho
  21. Nov 15, 2021 at 8:35 AM
    #2631
    cementsharktrd
    cementsharktrd New Member
    Demetrio
    2021 Cement Tundra TRD Off-Road
    7 inch bds coilover lift kit
  22. Nov 19, 2021 at 4:47 PM
    #2632
    Ckatz53
    Ckatz53 Newish
    MD
    Work cut out for us tomorrow. Only a one step going on with a coating, however a shit body shop repainted and sanded/buffed this panel. The scaling on the bottom portion is velcro hook and loop where whatever they were using wasn't the correct size so the backing plate was just going to town on the freshly painted panel. The rest of the haze is from a rotary on too high of a speed and an aggressive pad (intense holograms and swirling).
    Second photo shows what the rest of the car looks like (looks better than the repainted part lol). People suck...
    Prostar 190 and Fotnot like this.
  23. Nov 20, 2021 at 2:20 PM
    #2633
    Ckatz53
    Ckatz53 Newish
    MD
    Finished product and some test spotting/before afters. Ended up using Uro 50/50s and 3D One on the Flex long throw DA (the forced rotation Flex left micromarring with the same combo and Angelwax was too aggressive for this soft paint and left micromarring as well). One step on this 2011 Lexus with 101k miles and coated in Undrdog Pro. I'd estimate a 70% correction after everything was said and done for this one stage.
    20211120_165516.jpg 20211120_094007.jpg 20211120_112653.jpg 20211120_115046.jpg
  24. Nov 20, 2021 at 2:37 PM
    #2634
    Runway
    Runway New Member
    Kenneth
    Houston, Texas
    2016 White Tundra 1794
    That is an incredible remake of that car! It’s guys like you that really want me to hone my craft. To be able to transform that POS looking car to what you did should make the customer very happy. Tip ‘O the Hat, Sir.
  25. Nov 20, 2021 at 2:59 PM
    #2635
    briarpatch
    Still amazes me what some body shops are turning out these days....when I was in that business, such nonsense would not have been tolerated
    Ckatz53 likes this.
  26. Nov 20, 2021 at 3:03 PM
    #2636
    Ckatz53
    Ckatz53 Newish
    MD
    I appreciate the kind words. I've come a long way since my beginning and still have even farther to go. Just try to learn every chance I get and better myself with every job. He's a neighbor from a couple blocks over and stopped halfway through and asked if we had repainted it lol. Then said he's happy he decided to coat it..until I told him it wasn't even coated yet and his jaw dropped. Elderly couple who's retired and want to keep the car for a few more years so they're happy!
    I'll take a pic if you don't believe me...but that repainted panel had up to 43 mils of paint on it in spots. Not a typo. Forty-three mils. Ranged from 11 to 43. Was all over the place. Then the shotty rotary job....we took care of that though.
    Fotnot likes this.
  27. Nov 29, 2021 at 7:42 AM
    #2637
    Joemh711
    Joemh711 New Member
    Joe
    2013 Crewmax Texas Edition-Sold, 2015 Red TSS Crewmax-Sold, 2020 TRD Sport Crewmax-Sold, 2023 Tundra TRD Pro
    Washed the wife’s Camry and was home sick so this is what 2 layers of Q2 and 2 layers of jescar spray wax look like on a graphene coated car.
  28. Nov 29, 2021 at 7:53 AM
    #2638
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    SO....MUCH...:jellydance::jellydance::jellydance::jellydance:
  29. Nov 29, 2021 at 10:59 AM
    #2639
    Ckatz53
    Ckatz53 Newish
    MD
    I fuck with those floors hard. I wish I wasn't poor.
    thunder100 and Fotnot like this.
  30. Nov 29, 2021 at 11:01 AM
    #2640
    Ckatz53
    Ckatz53 Newish
    MD
    2019 Audi Q7 one stepped and coated in UD Pro. And current status of a 2021 Chevy 2500HD we are prepping for coating.
