One Heck Of a Project
Discussion in 'General Tundra Discussion' started by RoasterOven, Oct 7, 2021.
  1. Oct 8, 2021 at 5:29 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Stoked to see where this project goes. :headbang:
    RoasterOven[OP] likes this.
  2. Oct 8, 2021 at 7:32 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    That is freaking genius!
  3. Oct 8, 2021 at 9:01 PM
    RoasterOven
    RoasterOven [OP] I make custom Tundra lighting
    Jordan
    Columbia, SC
    2017 Tundra Crewmx SR5
    TRD Pro grill Color matched bumpers Cold Air Intake Muffler delete Custom interior/exterior lighting
    My first print using ASA, just using recommended temp and speed settings. It didnt turn out too bad.
    .8mm nozzle
    .6mm layer height
    .8mm line width
    25% infill
    I actually had to lower to temp to 235 °C probably becase of the ambient temps in the chamber being so warm I dont need to have the nozzle as hot which is a good thing
    Some tweaking still needs to be done.
    Also I quickly tried sanding, and wow, it's so much better than trying to sand PLA or PETG. They just melt under that friction heat, but ASA is actually sandable
    Sanded quickly
    I know it may not look good, but I'm running a nozzle thats 2 times larger than what's usually used. Also using layer heights 3 times higher than standard, so this is actually looking really good for those who may not understand 3d printing too well.
    For example this is Carbon fiber PLA printed on the same printer with:
    .4mm nozzle
    .2mm layer height
    .4mm line width
    75% infill
    You can barely see the layer lines. This is good for small high detail parts like this, but for the purpose of this project high detail isn't needed, speed is.
    Speaking of speed the boat "Benchy" only took 34 minutes to print, which with normal settings (listed above) but 25% infill, Cura said would take 1 hour and 25 minutes so almost 3 times faster.
    Also got the chamber set up as well, and oh boy she holds some heat.
    I guess I can call it hot box now :rofl:
  4. Oct 8, 2021 at 11:11 PM
    RoasterOven
    Jordan
    Columbia, SC
    Also for those of you with printers this video does a good job showing different filaments inside a car, and why I chose ASA.
  5. Oct 9, 2021 at 12:39 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Well, that’s pretty badass. Good luck!
  6. Oct 23, 2021 at 12:58 PM
    RoasterOven
    Jordan
    Columbia, SC
    Update!!
    here's some renders
    Almost done just have to do the cutout for the fuel door
    Im excited
  7. Oct 23, 2021 at 1:27 PM
    TRDblvd
    TRDblvd New Member
    2019 Toyota Tundra TRD 4X4 Sport
    Coming along nicely!
  8. Oct 23, 2021 at 1:58 PM
    Saltyhero13
    Those look ****ing sweet!
  9. Oct 30, 2021 at 9:06 AM
    RoasterOven
    Jordan
    Columbia, SC
    Finnally cut out the gas door,
    And some more renders:
  10. Oct 30, 2021 at 9:14 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Oof. I love this
  11. Oct 30, 2021 at 9:14 AM
    Danimal86
    Daniel
    Sacramento, CA
    Freaking awesome!
    THORYOTA and RoasterOven[OP] like this.
  12. Oct 30, 2021 at 9:33 AM
    baby-shark
    baby-shark Propaniac and Certified Tundra Enthusiast
    Kevin
    VA
    2021 Wind Chill Pearl Limited CrewMax
    Rear Sway Bar, Retrax Pro, TRD wheels and Cooper Tires, TRD shift knob!!!
    The longer I lurk on the forum the more confident I am that one could restart the world (in the event of an apocalyptic scenario) with the collective knowledge of this body of Toyota Tundra Enthusiasts. Well done, sir! Very freaking cool!
    meanwhile, I’m over here in the last century…
  13. Oct 30, 2021 at 9:59 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    No WAY!!!! That is sooooo coooollll! Nicely done. I like it when a plan comes together for someone!!!! Good On Ya!!!! For that.:)
  14. Nov 2, 2021 at 4:52 PM
    RoasterOven
    Jordan
    Columbia, SC
    Update: Finally getting the fenders cut and adding 1/2" alignment dowel holes
    I should start printing the first piece of the front driver fender soon tonight.
  15. Nov 2, 2021 at 6:43 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
  16. Nov 3, 2021 at 12:59 PM
    RoasterOven
    Jordan
    Columbia, SC
    She's still going even though the screen on my printer went white probably becase it's SO hot in the chamber
    I already had a failed print last night because my Octo-Print crashed. I think due to the Raspberry Pi's CPU overheating :mad:
    And yes for those wondering I just started building a Voron 2.4 350x350x350. The frame kit came Monday and motion parts are on the way. So this poor printer won't have to suffer too much longer :rofl:
  17. Nov 3, 2021 at 2:06 PM
    RoasterOven
    Jordan
    Columbia, SC
    Welp, misson failed....
    The thickness modifer I used the take the 2D mesh and make it a manifold 3D object intersects the model and I over-looked it so it doesn't sit flush on the real truck.
    Back to the drawing board:frusty:. This is easily fixable though.
    On the bright side the bodylines match up well.
    But this is the beauty of 3D printing I only used about 620 grams of filament so around $20 worth. Plus it requires no man power to prototype. So who's the real loser?
    (My wallet:spending:)
    This is a learning process for me and probably y'all too.
  18. Nov 3, 2021 at 3:09 PM
    TRDblvd
    TRDblvd New Member
    That's how it goes w a prototype. Making great progress though
  19. Nov 3, 2021 at 3:17 PM
    18" TRD Off Road Wheels
    The ingenuity here is awesome!
  20. Mar 1, 2022 at 7:24 AM
    #50
    THORYOTA
    THORYOTA God of Thunder
    Thor
    Asgard
    2021 MGM TRD CM "Mjölnir"
  21. Mar 5, 2022 at 10:52 AM
    #51
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
  22. Oct 9, 2022 at 2:48 PM
    #52
    RoasterOven
    Jordan
    Columbia, SC
    So after almost a year, I finally got my new printer built a: Voron 2.4r2 350. This will help print parts faster and more efficiently (since im not using a printer regular cheaper Cartesian-style printer in a grow tent anymore).
    Also I decided to possibly ditch ASA and use PETG, becase its a little cheaper, easier to come by in 3/5kg spools and prints ALOT easier with less chance of warping. PETG has excellent outdoor protection, considering I've had the TRD Pro grill backlit letters on my truck for over a year with no problems, other than a little yellowing from UV from the sun. But thats to be expected since it was clear/transparent PETG.
    I might still be going with skinning it with a couple layers of fiberglass so as long as the filament I use doesn't melt in the sun (which PETG won't) like PLA it will be fine.
    WVI, saybng, AZTundra and 1 other person like this.
  23. Oct 9, 2022 at 3:41 PM
    #53
    RoasterOven
    Jordan
    Columbia, SC
    I had a eureka moment last night and fixed the problem with the parts being printed too thick, using a program called Autodesk Meshmixer I was able to thicken the 2D mesh to be just 3mm thick which is perfect for this application.
    I have matched it up to my truck. Just didn't take pictures. BUT it fits good enough so when its time to fiberglass and do final fitment, stuff can be trimmed and sanded. It's way better than it was when it was thick and saves alot on filament and print time.
    Warreng, WVI, saybng and 1 other person like this.
  24. Oct 9, 2022 at 4:11 PM
    #54
    Danimal86
    Daniel
    Sacramento, CA
    I was wondering about this thread, but I couldn't find it.
    Glad you posted and update and that it's still moving forward.
  25. Oct 9, 2022 at 4:13 PM
    #55
    dorton
    dorton #RockCreekOverland
    North Carolina
    2020 Black Tundra SR5
    CBI Off Road Front Bumper, Rock Sliders, Skids, and Bed Rack. Prinsu Designs Roof Rack, CVT Hybrid Rainier Tent, Old Man Emu lift, Fuel Vectors, Yokhama 305/70r18s
    Pretty awesome project! Subscribing.
  26. Oct 10, 2022 at 5:27 PM
    #56
    RoasterOven
    Jordan
    Columbia, SC
    Update: I got 3 pieces printed and melted together!
    So far so good and it matches up fine. The front black piece needs a bit of cutting on the part the touches the truck other than that the 2 grey pieces sit flush to the body. (pictures tomorrow when there's light out.)
    The inside of the fenders are just melted with a soldering gun, but ill use plastic weld or CA (superglue) on the visible side.
    Passenger front fender:
    20221010_201739.jpg 20221010_201729.jpg 20221010_201718.jpg 20221010_201710.jpg 20221010_201658.jpg
    Video of it printing: https://www.youtube.com/shorts/P_x6hd-_teQ
    Hotwire and AZTundra like this.
  27. Oct 11, 2022 at 7:15 AM
    #57
    RoasterOven
    Jordan
    Columbia, SC
    I should also mention that the black is the Final PETG material I'll be using the grey is just PLA I have just sitting around.
    I'm just testing with random PLA I have laying around to using it as a fit test piece and probably testing the effects of resin on the PLA and PETG for the fiberglass encapsulation step
    I only bought a 1kg spool of Polymaker Polylite PETG to test how it prints on my printer and dial in settings. I ended up using the whole spool dialing in the settings and printing the first part which took over 530g of filament due to the weird shape and the amount of support it has to print. that piece took 10 hours to print while the 3rd piece only took 2 ½ hours and only 300g because it has little to no over hangs.
    given everything goes to plan, theoretically I could have a whole panel printed in 3 days (at least the front ones). (I have yet to cut and slice the Rear panels yet)
    I have a BIG 5kg spool of Polymaker PETG on the way, and should be here by the end of the week.
    by the way Amazon have Polymaker filaments on sale right now a 1kg spool normally $21.99 is $17.59 just a FYI for other Printer owners
    Troybentley likes this.
  28. Oct 11, 2022 at 2:16 PM
    #58
    RoasterOven
    Jordan
    Columbia, SC
    looks really good:
    this is not the final position exactly, but gives me and y'all an idea.
    There's a bit on the underside that needs to be shaved down but I'll probably do it after its fiber-glassed.
    dorton, Warreng and Saltyhero13 like this.
  29. Oct 11, 2022 at 3:55 PM
    #59
    breynolds
    breynolds New Member
    Future Tundra owner
    This is cool! I have to ask, and it was probably answered already but how did you get the Tundra body into CAD?
    Also what is the capacity on your printer? I have a Prusa MK3S+ and I think I can only print like 8"x8"x9", not very big. Haven't dabbled in ASA or ABS yet as my machine isn't enclosed and it lives in the house. Mainly print with PETG and PC CF from Prusa.
  30. Oct 11, 2022 at 4:02 PM
    #60
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    This is awesome.
