Brake controller issue 2016 Tundra
Discussion in 'New Member Introductions' started by qvidas1, Oct 29, 2021.
  1. Oct 29, 2021 at 6:17 AM
    qvidas1
    qvidas1 [OP] New Member
    stacey
    As we all know YOU cant troubleshoot intermittent problems. Well I have one with my Tundra. I have had this intermittent brake controller message + ABS light + Check engine light + intermittent speedometer and cruise control. With all of that going on, there is not change to the operation of the truck. Sometimes the lights stay on for a few days to weeks sometimes its off for few days to weeks. 've seen a lot of issues with this junk. I've only towed my Jet Ski twice and on neither occasion did I have the fault Yet. I don't want to dump a bunch of money into a mystery fix, especially if its a DIY issue. Please inform if anybody knows a resolutions. Thanks in advance
  2. Oct 29, 2021 at 7:01 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
  3. Oct 29, 2021 at 8:05 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    I bypassed my whole OEM brake controller all together. In short, it’s junk.
    Go aftermarket, save yourself the headaches
  4. Oct 29, 2021 at 8:26 AM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    There is an brake controller update the dealer can do. It improved mine but I still didn't care for how it worked even with the update and went with Teckonsha P3. Very happy with the aftermarket unit.
  5. Oct 29, 2021 at 4:14 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Good luck finding and correcting the issue. Looks like others have started you down the right track.
  6. Oct 29, 2021 at 4:20 PM
    biebs96
    PA
    when you bypassed it what all is involved? Can you simply disconnect the OEM controller and not use it?
    Did the aftermarket one get wired into the factory plug? Or is there a plug and play option?
    thanks in advance. I have been wondering about upgrading, just curious what all was involved.
  7. Oct 31, 2021 at 6:38 AM
    Bear
    Bear
    Custer, SD
    Exactly!
    Unplug old harness under dash.
    Plug in new controller and install. I mounted the new controller to the lower dash just under the OEM controller panel.
    Takes about 10 minutes.
