Blown head gasket 5.7 at 190k miles
Discussion in '2.5 Gen Tundras (2014-2021)' started by Luckydog, Oct 28, 2021.
  1. Oct 29, 2021 at 8:03 AM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    I am no expert on the 5.7 engine… but I have replaced many a head gasket in my day…engine running with billows of white smoke, even BMW’s, and steam from coolant etc. and the cheap fix was to replace the head gasket. Generally the problem was solved with no ancillary damage. I don’t trust someone who offers a ridiculous price. I would find a good REAL mechanic willing to attempt that fix before throwing away a ton of cash.
  2. Oct 29, 2021 at 8:09 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I wouldn't have any issue with a used engine if the price is right.
    It may still be worth having a compression test done on your engine to verify head gasket.
    I'm not saying this is you, but there are some Toyota owners get accustomed to never having to open the hood except for oil changes and washer fluid. So the coolant levels seem to get missed. It eventually gets low and the car runs hot one day.
    Luckydog[QUOTED][OP] likes this.
  3. Oct 30, 2021 at 9:43 AM
    Luckydog
    Luckydog [OP] New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    I was slacking on the coolant. Religious about oil changes but I need to be more thorough elsewhere. $6,800 plus tax for labor and materials. Motor going in has 130k miles. Sounded like that was the only choice that was available locally. Yesterday the mechanic stated 10 business days, but this morning he texted a pic taking the front bumper off so he is getting after it.
  4. Oct 30, 2021 at 9:54 AM
    Luckydog
    Dominic
    I agree with you. That doesn’t seem like a catastrophic failure. The mechanic that is doing the swap noticed some oil on bottom of engine as well. The mechanic recommended the swap as the best option. The choice was mine. I do not have the time or patience to get this sorted twice.
    Tripleconpanna and Dr Doobie like this.
  5. Oct 30, 2021 at 9:57 AM
    Luckydog
    Dominic
    I will probably regret not investigating going that route. That seems like a reasonable price. What killed the previous motor?
  6. Oct 30, 2021 at 10:04 AM
    Luckydog
    Dominic
    Compression and drop down(?) test we’re done by Toyota and new shop. No water in coolant or vice versa and I didn’t notice the temp rising. I was hoping that this would mean all it needed was a head gasket.
    mambo143 likes this.
  7. Oct 30, 2021 at 10:06 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Compression and leak down tests would tell you if there was indeed a leak somewhere and often where it’s coming from.
  8. Oct 31, 2021 at 5:14 AM
    blanchard7684
    blanchard7684 New Member
    Compression test tells you if there is a problem in the integrity of the combustion chamber. Leakdown tells you where the problem is or is not.
    Are you the original owner?
  9. Oct 31, 2021 at 5:26 AM
    joesTundra
    joesTundra New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    pick up a short block and recondition the cyl heads and do all the work yourself save alot of money. dont put money into the truck.
    Luckydog[OP] likes this.
  10. Oct 31, 2021 at 7:16 AM
    Luckydog
    Dominic
    No. I bought late 2017 with 45kmiles, for $29,500.
  11. Nov 1, 2021 at 4:07 PM
    rugerm44
    rugerm44 New Member
    2021 Tundra
    Never had to replace an eng for blown headgaskets.My 2002 Tacoma blew 2 and both heads had cracked between valve seats.I bit the bullet and replaced both heads for 2800 plus labor.Factory parts
  12. Nov 2, 2021 at 12:23 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    The 4cyl VVTI engines (camry) have a habit of pulling the threads out of the block when they overheat do those guys usually aren’t worth fixing. I haven’t ever seen an exploded 5.7 in person but maybe that’s an issue?
  13. Nov 4, 2021 at 1:46 AM
    Jhinesvl
    Jhinesvl New Member
    Clarksville tn
    I think they mixed they mixed the coolent and it gelled and it overheated bad. They said it was head gasket but i think it was cracked. It had 220k on it so i figuered that was my best route. I used Powertrain Products
  14. Nov 9, 2021 at 11:53 AM
    Luckydog
    Dominic
    The junkyard engine had a ton of corrosion, and the mileage claim was dubious so the mechanic returned it. Couldn’t find any other motors. Maybe because it is flex fuel. Mechanic is rebuilding engine. 58A7E86A-5AF3-4DE8-A4DC-580FF3680E55.jpg
  15. Nov 9, 2021 at 12:02 PM
    worktruckwhite
    worktruckwhite bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    The video explains it all. There is fact and evidence backing up liquid gasket sealers. They work under the right circumstances. Would I put it in coolant if I was going to replace the engine in a few weeks? No. But ChrisFix got 2yrs on an old Jag that had a head gasket leak. 2 years for the price of a bottle of sealer is a no brainer.
    NickB_01TRD likes this.
  16. Nov 9, 2021 at 8:33 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Perfect time to replace those timing chain tensioners and guides! :p
  17. Nov 10, 2021 at 3:24 AM
    blanchard7684
    post a picture of the blown head gasket when you get down to it.
    worktruckwhite likes this.
  18. Nov 13, 2021 at 9:46 AM
    Luckydog
    Dominic
    Does machining Head’s take care of that?
  19. Nov 14, 2021 at 6:37 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    The cost to replace or fix a supposedly blown headgasket on these engines is really disconcerting. So has it been confirmed that it really was a blown headgasket?
    I remember Toyota’s 3.0L V6 headgasket fiasco from the 90’s. They were fairly common and cost about $1500 at the time to fix. But Toyota was so concerned with its reputation, it offered to fix them for free the first time. They usually blew at around 100K miles. The second time, though, was on the owner to pay.
    Mine blew twice on my ‘92 4Runner. The engine did not need replacing, either. They just checked the mating surfaces, machined the cylinder heads and replaced the crappy headgaskets with another one. I eventually traded it in on a ‘99 Tacoma.
  20. Nov 14, 2021 at 8:30 AM
    #50
    Shark Bait
    Shark Bait Not new anymore
    2019 Platinum
    $37k! And they wonder why people call them “stealerships”!
    I has a Nissan Sentra one time that wouldn’t start. The dealer said the engine was shot and needed replaced. Some stupid $$$. The car wasn’t even worth it, so I brought it home. My buddies dad stopped by to look at it and it turned out to be a cracked distributor cap, like $10 he had it running again.
    TK1979, 2mchfun, equin and 1 other person like this.
  21. Nov 20, 2021 at 3:34 AM
    #51
    Luckydog
    Dominic
    Update. Engine finally back in truck yesterday. Imagine one more day to get everything buttoned up. Besides all of the obvious seals and gaskets that were replaced, the mechanic replaced cam tensioners, chains, chain guides, looked like the 2nd gen air pump(think he called it fuel injection valves), alternator, water pump, air conditioning condenser, starter, (4) valves, and oil pan Because of a stripped drain plug . (I knew it was weeping. I had a fumoto valve. Don’t know if I messed it up, or the few times I went to oil change place. Not doing fumoto valve anymore) I am paying the labor regardless, so it’s basically just cost of parts, and I do not want to deal with any issues for a long time. A mechanic I know tried to persuade me to sell the truck and not put a bunch of money into it, but I like it. Also the rediculous replacement prices are making it easier to justify. Haven’t got a grand total yet, but I am think we are definitely north of $10k. The mechanic sends update pics constantly, and I have accepted all of his suggested replacement recommendations. Looking forward to getting this wrapped up and getting on with my life.
  22. Nov 20, 2021 at 3:43 AM
    #52
    Luckydog
    Dominic
    Would that be part of condenser? Can you see those hoses in pic? There is some new hoses but I don’t know what they are for. This whole experience has been great to really familiarize me with the engine components. I have crawled under and inspected truck a ton of times, and I never realized that the starter was buried under that heat shield.
  23. Nov 20, 2021 at 4:01 AM
    #53
    Luckydog
    Dominic
    Sounds like you have dealt with those. Haha. Thank you, I will ask the mechanic. This whole thing snowballed fast. I have to remind myself that this better than dealing with a collision, and hopefully an opportunity to get many more years of use.
  24. Nov 20, 2021 at 4:03 AM
    #54
    Luckydog
    Dominic
    @07DCLimited how many miles on your truck? I was/am hoping to get 500k+ miles.
  25. Nov 20, 2021 at 5:21 AM
    #55
    Jhinesvl
    Jhinesvl New Member
    Clarksville tn
    Not bad
  26. Nov 20, 2021 at 6:34 AM
    #56
    Jhinesvl
    Jhinesvl New Member
    Clarksville tn
    Any picks of the old gasket
    equin likes this.
  27. Nov 20, 2021 at 7:42 AM
    #57
    equin
    Ed
    DFW, TX
    So was it confirmed the headgasket failed?
  28. Nov 20, 2021 at 7:44 AM
    #58
    Lordaca
    Lordaca New Member
    2019 Calvary Blue Limited 4x4 crewmax
    Did I miss the final diagnosis? This mechanic should have down a tear down video. Man, this job seems like it would have been a blast to do.
    equin likes this.
  29. Nov 20, 2021 at 9:35 AM
    #59
    Luckydog
    Dominic
    Toyota and the current mechanic both did compression and “blow down”(?) tests to confirm head gasket.
    equin[QUOTED] likes this.
  30. Nov 20, 2021 at 9:39 AM
    #60
    Luckydog
    Dominic
    No. I forgot to ask. Someone on here asked earlier as well. My bad
