Body lift for 03 tundra?
Discussion in '1st Gen Tundras (2000-2006)' started by tundra037, Jun 1, 2015.
  1. Jun 1, 2015 at 6:35 AM
    tundra037
    tundra037 [OP] New Member
    J
    2003 tundra limited
    Spectre cold air intake/throttle body spacer, bilstein 5100 shocks, 10 series flowmaster exhaust, black custom wheels 17in, 33" nitto Terra grapples tires, bull bar.
    Is there a body lift for a 2003 tundra? If there is... is it possible if I already have bilstein suspension lift?
  2. Jun 1, 2015 at 9:41 AM
    our first gen expert @Mike may know...
  3. Jun 1, 2015 at 10:41 AM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    Avon calling...
    http://performanceaccessories.com/vehicles/311-2000-2002-toyota-tundra-2wd-4wd-stdext-cab.html
    This is the ONLY kit im aware of on the market. its for a 2002 but it will fit our 2003 access cab only. As far as i know toyota didnt change the frame or body mounts on the 2002 to 2003. It all had to really to with front end and grill work minor differences but the body and frame was unchanged. Everything else when it comes to parts is the same. Only difference is when its from access cab to 4 door models.
  4. May 16, 2017 at 5:21 AM
    titoPR
    titoPR New Member
    2003 tundra SR5
    new toy to mess with
    Has anyone been successful installing the 2002 kit on the 03 access cab Tundra it is a bit pricey to experiment and them just leave it on the garage collecting dust
