  1. Oct 22, 2021 at 8:03 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I had the same issue, I don’t think the dealership takes that off. I’m sure they use an impact and 3/8 extension to take your filter housing on and off instead of the right tool, so it gets over torqued. As soon as my Toyota care oil changes were used up I replaced the housing with the metal version. I had to put my plastic housing in a vise to get the drain plug out.
    Rc23 likes this.
  2. Oct 22, 2021 at 8:04 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    I haven’t been on here in awhile. When did we get downgraded to gen 2.5?
  3. Oct 22, 2021 at 8:07 AM
    RobertD
    Robert
    DFW, Texas
    When they released the 2022 and Toyota officially called it the 3rd Gen
    GODZILLA, Mike59 and Tundrastruck91 like this.
  4. Oct 22, 2021 at 8:11 AM
    justcuz
    justcuz 2.5 Gen Member
    found some replacement parts here: https://www.carid.com/2018-toyota-tundra-oil-filters/?filter=1&sub-model[Liter][]=5.7L
  5. Oct 22, 2021 at 8:11 AM
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    '16 Super White CrewMax
    Wahayes, GAknight, AggiePhil and 4 others like this.
  6. Oct 22, 2021 at 8:52 AM
    normagene
    normagene New Member
    Normagene
    New England
    2021 Cement DC Limited Texas Edition
    Texas Edition
  7. Oct 22, 2021 at 8:54 AM
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    Sparks website does that a lot. I have this exact one purchased from that link on my 2016. It fits
  8. Oct 22, 2021 at 9:54 AM
    BWPRO
    BWPRO New Member
    Bryce
    2021 Tundra TRD PRO
    It's the little things. Not perfect on the driver door but I like the look. Before and and after photos.
    D4x4TRD, GAknight, vipgs3 and 9 others like this.
  9. Oct 22, 2021 at 10:23 AM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    C4 Overland bumper shipped today to a powder coating company near me. Few more weeks to get it on. Still waiting on the Icon stage 10 I ordered from SDHQ back in August.
    AZ Red Nek and AZTundra like this.
  10. Oct 22, 2021 at 10:24 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    It does that because it's not available from the factory on the 5.7. It's originally from another engine but the size and threads are the same.
    For example many places will say TRD Pro rims don't fit on SR5, Platinum, etc. because they don't come standard on that trim. But they all have the same hubs so they fit not problem.
    AggiePhil and normagene[QUOTED] like this.
  11. Oct 22, 2021 at 1:00 PM
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Currency converter= Earned to wasted dollars
    If you don’t mind me asking…
    How much were you quoted to have it powder coated?… I love that bumper… Just think at that price it should come painted..
    GODZILLA likes this.
  12. Oct 22, 2021 at 2:07 PM
    GovtCheese
    GovtCheese New Member
    Oklahoma
    10k service, oil change, tire rotation, etc. Does it drive anyone else crazy with the cooler temps the tire pressure monitoring says the tires are low on pressure every cool morning? My door jam says 30 psi for front and 33 for back. Should I up that a bit for the winter months to avoid the tpms warning me every morning?
  13. Oct 22, 2021 at 2:18 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I run 35 front and 38 in the back.
    Jaypown and GovtCheese[QUOTED] like this.
  14. Oct 22, 2021 at 2:31 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    With the stock tires, I found going up a few lbs made an improvement, less squishy feeling. Tires wore better too.
    WILLINH and GovtCheese[QUOTED] like this.
  15. Oct 22, 2021 at 2:48 PM
    belanger9
    Edmonton, AB
    A bunch
    Depends when you check the tire pressures and then when you drive the most. Rule of thumb is 1 psi for every 10 degrees F change. So fill at 70 but drive at 20 and you lose 5 PSI. I personally like driving on 33 front/35 rear. So most often I fill to 34/35 front and 36/37 rear since I don't have early morning commutes, and tweak it every few months. The light coming on at -40 doesn't bug me, usually goes out 5 minutes into the drive, that's the only time of year I'll run a little low.
    GovtCheese[QUOTED] likes this.
  16. Oct 22, 2021 at 3:05 PM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    AJT Design handle covers. Nice fit for them. C0994981-565D-41D9-87D9-DBBED6FCF7AE.jpg
  17. Oct 22, 2021 at 3:18 PM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    Scored some old man oem steps for only $20 today. Exciting, I know. But damn are they handy.
  18. Oct 22, 2021 at 3:19 PM
    Nice score.
  19. Oct 22, 2021 at 3:20 PM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    Very strange. I worked 9 years with insurers brokers. 4 of those in claims. A policy is not made per state. Most insurers do not cover aftermarket parts if its not noted on the policy. The rule of thumb is that they will cover whats insured. Rims, wheels, stereo, leather seats, turbos…. Nothing is automatically covered. Most of them are more expensive. Of course they are cheap aftermarket parts but I dont know about GOOD “cheap” aftermarket parts. There are always exceptions to the rule but if you dont pay for the extras then its not covered. Again there might be ways around this. Also there is the liability behind what they approve to installed on the truck. GOOD LUCK.
  20. Oct 22, 2021 at 3:30 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Not sure why you’re wishing me good luck.
    It’s not my claim.
    We’ll have to agree to disagree.
    I can only go by personal experience.
    btw. Policies are absolutely different by state.
    I’ve had more than one vehicle registered in different states under the same insurer.
    twistedcricket and GODZILLA like this.
  21. Oct 22, 2021 at 4:00 PM
    mcharfauros
    mcharfauros Hafa Adai
    MO
    06 AC SR5 4X4
    Dumb Truck Thangs
    Diggin it! Dad truck activated
  22. Oct 22, 2021 at 4:17 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    I like them more than I should to be honest. It’s just so nice being able to step in and out of the truck versus slide off of the edge of the seat, which I know will wear it out.
  23. Oct 22, 2021 at 4:27 PM
    mcharfauros
    MO
    06 AC SR5 4X4
    Dumb Truck Thangs
    All about it too, at 20 bucks hell yeah
  24. Oct 22, 2021 at 5:45 PM
    FirstTruck
    Stock, for now
    I thought you said that your insurance company had covered aftermarket parts for you. Good luck with your claims. Or maybe not. Don't know. Im confused. Ill take back the “Good luck” then. Sorry for trying to be nice.
    RainMan_PNW and NWPirate like this.
  25. Oct 22, 2021 at 5:53 PM
    Hightide
    Abalama
    Magic School Bus
    They did cover them.
    You are confused.
    Are you actually reading or just pretending you know more than everybody?
    TRDFerguson and NWPirate like this.
  26. Oct 22, 2021 at 6:06 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
  27. Oct 22, 2021 at 6:08 PM
    Hightide
    Abalama
    Magic School Bus
    Hey man, quit picking on me.
    easleycrawler[QUOTED] likes this.
  28. Oct 22, 2021 at 6:09 PM
    easleycrawler
    Travis
    I'm not picking, notice I didn't quote neither of you. Lol.;)
    3xYOTA, FirstTruck, GODZILLA and 3 others like this.
  29. Oct 22, 2021 at 6:10 PM
    Hightide
    Abalama
    Magic School Bus
    I’m just tender.
    I marinated all day.
  30. Oct 22, 2021 at 6:22 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Husky X-act, front windows tint, Xpel PPF, center console organizer and tray, TRD rear sway bar, touch screen cover, transmission cooler, wireless charger, keyless tailgate lock.
    Those looks sweet. Link?
