Loose/shaky fog lights
Discussion in 'Lighting' started by tuckertravis, May 19, 2018.
  1. Oct 21, 2021 at 10:32 PM
    azimuth
    azimuth New Member
    2010 double cab SR5
    This is how I fixed my jiggly Morimoto fogs
    mikesTundra77 and Redmanreaction like this.
  2. Oct 22, 2021 at 5:06 PM
    Redmanreaction
    Redmanreaction New Member
    2012 Silver Platinum
    Azimuth:
    Looks like strong, fresh new zip ties will do the job!
    Complete satisfaction afterwards by not having them shake all the time!
    mikesTundra77, jewsNbrews and azimuth like this.
  3. Nov 11, 2021 at 8:18 AM
    mikesTundra77
    mikesTundra77 BRAAAAP BRAAAP
    M_i_k_e
    earth, sol system
    BLOOD,SWEAT+BEERS
    4 " ready lift kit General grabbers 35" Rock warrior wheels 17" Leather Clazzio seat covers KN intake StartX remote starter HRS sequential tails Custom grille+badge ME-SO map lights+dome light Lots of CHROOOOME
    This happens on mine as well. Just noticed it last week and it's really driving me nuts!! At first I assumed it was my headlights! I'm gonna mess with it today and see if I can come up with anything. Might resort to zipties and foam gasket
  4. Nov 11, 2021 at 8:26 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    One thing to make sure to check in your own scenario is whether or not its your fog lights wobbling in their brackets, or if it's the bezels themselves wobbling in the bumper. I've got the second one going on, and will be digging into my solution once the snow stops flying this weekend...
    jewsNbrews likes this.
  5. Nov 11, 2021 at 8:42 AM
    mikesTundra77
    M_i_k_e
    earth, sol system
    BLOOD,SWEAT+BEERS
    Mine is the fog lights loose in the bezels. The bezels seem tight
  6. Nov 11, 2021 at 10:23 AM
    mikesTundra77
    M_i_k_e
    earth, sol system
    BLOOD,SWEAT+BEERS
    So I used around 5 zip ties on each side running from various spots on the pod and the bezel housing to the bumper and structural and it was a bit tight getting my head and torso in there..but it seems to be fixed. I'll see how long it lasts now. Could get pretty cold this winter so I'm hoping they don't break. I didn't take any pics but it's pretty easy and straight forward to do just basically secure it with cable/zip ties a few times however you can and it fixes it.
    azimuth likes this.
  7. Nov 11, 2021 at 10:53 AM
    azimuth
    azimuth New Member
    2010 double cab SR5
    So far so good on mine. They are tight and no more bounce.
    mikesTundra77 likes this.
  8. Dec 23, 2023 at 5:15 PM
    TundraJedi
    TundraJedi New Member
    Eric
    2021 Tundra Pro
    The best solution I came up with for shaky or loose fog lights:
    —> Silicone around the inside edges.
    I have rigid fog lights on my 2021 Tundra Pro. Use a caulk gun and buy an expensive tube of outdoor clear or black silicone. Apply between the cracks and on outer edges. The silicone will flex and withstand bumps and freezing or super hot weather. If done right, you can hardly tell it is there. Let it dry and go for a drive… you’ll see. Hope this helps! It’s easier than removing paneling to get to places where you can strap some tie downs. Use the rest of the tube around your house.
    gosolo and RainMan_PNW like this.
  9. Dec 23, 2023 at 6:21 PM
    gosolo
    Ray
    NW Oregon
    This is exactly what I did several years ago. I have written about it as a solution several times, since. It is good that you have explained it, again! Simple and pretty bulletproof
  10. Dec 23, 2023 at 6:22 PM
    TundraJedi
    Eric
    2021 Tundra Pro
    Wish I had seen your post! Would’ve saved me a good 20 minutes searching for a fix on this forum.
  11. Dec 23, 2023 at 6:25 PM
    TundraJedi
    Eric
    2021 Tundra Pro
    I’m glad to hear it is still going well after many years! Awesome. Thank you. Wish I saw your solution earlier.
    gosolo[QUOTED] likes this.
  12. Dec 23, 2023 at 6:33 PM
    gosolo
    Ray
    NW Oregon
    After 8 years on this awesome forum and over 7000 posts, a lot has been buried. I don’t write as much anymore but I’m still checking stuff out every day!
    Plus I’m still pretty sure that I have the best year/model tundra and am absolutely sure it’s the fastest color ever imagined! SUPER WHITE!!!!
  13. Dec 23, 2023 at 6:45 PM
    RainMan_PNW
    RainMan_PNW SSEM #82 RGBA #4 “That Guy” Vendor
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    <cough>bull<cough>shit<cough>
    Super “Work Truck” White
    :boink:
    jewsNbrews and gosolo like this.
  14. Dec 23, 2023 at 8:08 PM
    gosolo
    Ray
    NW Oregon
    Hey, you have seen my sweet truck and I have pictures of our trucks, side by side. You can’t really tell me that you think mine looks like a “work truck”!
  15. Dec 23, 2023 at 8:10 PM
    RainMan_PNW
    Casey
    Clark County, WA
    It looks like it will get work done, for sure.
    :fistbump:
  16. Dec 23, 2023 at 8:44 PM
    gosolo
    Ray
    NW Oregon
    :anonymous:
  17. Dec 25, 2023 at 9:33 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Are you applying the silicone around the edge of the lens? Noticed while running ranch roads last week that one that is shaking. I did the zip tie fix years ago.
  18. Dec 25, 2023 at 12:57 PM
    TundraJedi
    Eric
    2021 Tundra Pro
    Hopefully, the photo uploads. The blue highlight is where I put silicone. The housing is what was shaking for me because it’s just plastic snapped in and not tight. Silicone fills the gaps.
  19. Dec 25, 2023 at 1:32 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Thanks I might need to pull the liner and check the zip tie make make sure bulb is snug. I have not noticed on pavement but don't drive much at night.
  20. Jan 23, 2024 at 7:24 PM
    #50
    SolarEclipse
    SolarEclipse New Member
    20 TRD Pro
    Stock
  21. Jan 23, 2024 at 7:25 PM
    #51
    SolarEclipse
    20 TRD Pro
    Stock
    Useless fucking video..tundra guy a doushcebag
    TacomaTRD4x402 likes this.
  22. Apr 5, 2024 at 6:57 PM
    #52
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Brand new cabin air filter!
    Evening all,
    I'm getting ready to install my new squadrons on my '18 and hopefully fix the wiggle.
    I took the plastic liner off just to take a peek in there. Install seems easy enough.
    I do have a question though, noticed this open plug on the driver's side(I'm guessing same on the passenger side?) Is this plug for the front bumper sensors for those Tundras that are equipped with them? Or would it be for additional aux lighting?
  23. Apr 7, 2024 at 2:54 PM
    #53
    RainMan_PNW
    Casey
    Clark County, WA
    Yes.
    It is for the parking sonar sensors.
  24. Apr 7, 2024 at 2:56 PM
    #54
    TacomaTRD4x402
    Southern California
    Thank you @RainMan_PNW
