Upper control arm 305/55r20
Discussion in 'Wheels & Tires' started by Chingo31, Oct 21, 2021.
  1. Oct 21, 2021 at 12:53 PM
    Chingo31
    Chingo31 [OP] New Member
    2019 Toyota Tundra 1794 4X4
    Lift Kit
    Just installed new tires now the tire hits the upper control arm. What’s the solution?
  2. Oct 21, 2021 at 1:12 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    -Smaller tire (width).
    -Wheel spacers.
    - new wheels with lower offset.
    Hightide likes this.
  3. Oct 21, 2021 at 1:19 PM
    Chingo31
    Lift Kit
    I do have the SPC adjustable control arm not the stock.can it be aligned different.
  4. Oct 21, 2021 at 1:22 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    This.
    Not to correct your issue.
  5. Oct 21, 2021 at 1:30 PM
    Danman34
    Danman34 New Member
    Danny
    No.
  6. Oct 21, 2021 at 2:52 PM
    Chingo31
    Lift Kit
    Here are some pics should I be concerned with that spacing?
  7. Oct 21, 2021 at 3:03 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Given that you confirmed it is hitting, I would say yes.
  8. Oct 21, 2021 at 3:23 PM
    Chingo31
    Lift Kit
    Also what tire pressure should my tires be at
  9. Oct 21, 2021 at 3:41 PM
    MadMaxCanon
  10. Oct 21, 2021 at 4:29 PM
    Chingo31
    Lift Kit
    That did not show for this tire size
  11. Oct 21, 2021 at 6:29 PM
    Hightide
    Abalama
    Magic School Bus
    Its best to contact manufacturer and give the truck and uses.
  12. Oct 22, 2021 at 5:04 PM
    Chingo31
    Lift Kit
    What spacer do you recommend. I’m only trying to go as minimal as possible I want the stock look
  13. Oct 22, 2021 at 5:09 PM
    Hightide
    Abalama
    Magic School Bus
    Spyder or Bora
  14. Oct 22, 2021 at 5:15 PM
    2mchfun
    Maybe that rub mark just occurred during the install and is not actually rubbing during driving.
    Hbjeff likes this.
  15. Oct 22, 2021 at 6:07 PM
    pvmike
    pvmike Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
    What wheels are you running? I have the same tires and SPC UCAs with no issue.
  16. Oct 22, 2021 at 6:48 PM
    Chingo31
    Lift Kit
    Stock rims
  17. Oct 23, 2021 at 10:02 PM
    pvmike
    Los Angeles
    I have aftermarket wheels, +25 offset. Stock 20" rims are +60 offset. You should get 1" to 1.25" spacers, giving you an effective offset of +35 to +28. +35 should still be relatively flush.
  18. Oct 24, 2021 at 9:23 AM
    Chingo31
    Lift Kit
    Please post some pics with the spacer
