Upper control arm 305/55r20
Discussion in 'Wheels & Tires' started by Chingo31, Oct 21, 2021.
  1. Oct 21, 2021 at 12:53 PM
    Chingo31
    Chingo31 [OP] New Member
    2019 Toyota Tundra 1794 4X4
    Lift Kit
    Just installed new tires now the tire hits the upper control arm. What’s the solution?
  2. Oct 21, 2021 at 1:12 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    -Smaller tire (width).
    -Wheel spacers.
    - new wheels with lower offset.
    Hightide likes this.
  3. Oct 21, 2021 at 1:19 PM
    Chingo31
    Lift Kit
    I do have the SPC adjustable control arm not the stock.can it be aligned different.
  4. Oct 21, 2021 at 1:22 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    This.
    Not to correct your issue.
  5. Oct 21, 2021 at 1:30 PM
    Danman34
    Danman34 New Member
    Danny
    No.
  6. Oct 21, 2021 at 2:52 PM
    Chingo31
    Lift Kit
    Here are some pics should I be concerned with that spacing?
  7. Oct 21, 2021 at 3:03 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Given that you confirmed it is hitting, I would say yes.
  8. Oct 21, 2021 at 3:23 PM
    Chingo31
    Lift Kit
    Also what tire pressure should my tires be at
  9. Oct 21, 2021 at 3:41 PM
    MadMaxCanon
  10. Oct 21, 2021 at 4:29 PM
    Chingo31
    Lift Kit
    That did not show for this tire size
  11. Oct 21, 2021 at 6:29 PM
    Hightide
    Abalama
    Magic School Bus
    Its best to contact manufacturer and give the truck and uses.
  12. Oct 22, 2021 at 5:04 PM
    Chingo31
    Lift Kit
    What spacer do you recommend. I’m only trying to go as minimal as possible I want the stock look
  13. Oct 22, 2021 at 5:09 PM
    Hightide
    Abalama
    Magic School Bus
    Spyder or Bora
  14. Oct 22, 2021 at 5:15 PM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Maybe that rub mark just occurred during the install and is not actually rubbing during driving.
    Hbjeff likes this.
  15. Oct 22, 2021 at 6:07 PM
    pvmike
    pvmike Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
    What wheels are you running? I have the same tires and SPC UCAs with no issue.
  16. Oct 22, 2021 at 6:48 PM
    Chingo31
    Lift Kit
    Stock rims
  17. Oct 23, 2021 at 10:02 PM
    pvmike
    Los Angeles
    I have aftermarket wheels, +25 offset. Stock 20" rims are +60 offset. You should get 1" to 1.25" spacers, giving you an effective offset of +35 to +28. +35 should still be relatively flush.
  18. Oct 24, 2021 at 9:23 AM
    Chingo31
    Lift Kit
    Please post some pics with the spacer
