Fog lights not working after installing LED headlamps
Discussion in 'Lighting' started by DickeySeamus, Dec 8, 2016.
  1. Sep 1, 2019 at 7:52 AM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    I bought the part from super bright leds and it worked perfect just plug and go.
  2. Mar 12, 2020 at 7:25 PM
    Cbjohnson81
    Cbjohnson81 New Member
    Barrett
    Thanks!! HUGE HELP, resistor is on the way. i was really bummed when i saw how much brigther my LED bulbs were and that the fog lights werent working. So cool i found your post!
  3. Mar 21, 2020 at 8:21 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    I’m experiencing the same issue and I read about the resistor fix. I’m curious though, is there an LED headlight relay?
    I did the turn signal relay mod to help with the hyper flash and that was a super easy install.
    I wonder if there’s a relay for the head lights.
  4. May 11, 2021 at 5:54 PM
    Gball33
    Gball33 New Member
    Tundra 2000
    I have a 2000 tundra, I just installed new headlights and fog lights. Both LED both the same brand. But now my fogs don’t work, pushing the button in turns my high beams on. Would the resistor work in my case ?
  5. May 12, 2021 at 3:03 AM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    The resistor is what you will need.
    NewImprovedRon likes this.
  6. May 12, 2021 at 7:13 AM
    2006Tundra
    Lou
    Long Beach, CA
    You need this (link below). You need one but I bought 2, 1 for back up. It's plug n play. I just install this on ONE light and mount it on the fender support. It gets really hot.
    https://www.superbrightleds.com/mor...ad-resistor-h4-led-headlight-bulbs/2932/6284/
  7. Oct 18, 2021 at 8:03 PM
    ToyotaGuyDL
    ToyotaGuyDL New Member
  8. Oct 19, 2021 at 6:03 AM
    2006Tundra
    Lou
    Long Beach, CA
    Do you have DRL (Daytime Running Lights)?
  9. Oct 20, 2021 at 9:32 PM
    ToyotaGuyDL
    I do not have DRL.
  10. Oct 21, 2021 at 6:09 AM
    2006Tundra
    Lou
    Long Beach, CA
  11. Oct 21, 2021 at 10:41 AM
    ToyotaGuyDL
  12. Oct 30, 2021 at 5:48 PM
    ToyotaGuyDL
    Got the resistor. It makes them work, the LED headlights and Fog lights, but not for the LED turn signal lights. I'm happy with the results. But any suggestions for the LED turn signal lights would be appreciated. Thanks.
  13. Nov 5, 2021 at 4:16 PM
    2006Tundra
    Lou
    Long Beach, CA
    I bought these and they worked for me.
    https://www.amazon.com/gp/product/B0756B3T1D?ie=UTF8
  14. Jan 15, 2022 at 11:20 PM
    COElkHunter
    COElkHunter New Member
    Jeremy
    2012 Silver Tundra TRD limited Crewmax 4x4
    3" OME lift w/ UCAs. ARE overland shell w/ ARE roof rack. 34" Falken Wildpeaks. ARB awning. Road shower. Wilco Offroad Hitchgate Solo High Clearance. LED lighting upgrades. Lockerdown console safe. Weathertech floormats. Duluth deluxe rear seat cover to go under the offroad approved car seats.... :P
    I just installed my Morimoto XBs, and now my LED fog lights will not work. I saw someone mention DRLs as an issue, so wanted to ask for further input on the effect of adding DRLs and where exactly I would put the resistor on Morimoto's to get my fog lights working again. Am I correct in thinking it will go inline with my driving lights?
  15. Nov 8, 2022 at 4:20 PM
    Dragon daddy 1980
    Dragon daddy 1980 New Member
    Gary
    2003 Toyota tundra
    Led fog lights and headlights
    I’m having the same problem I will look into to a load resistor and try it
  16. Nov 9, 2022 at 4:56 AM
    Dragon daddy 1980
    Gary
    2003 Toyota tundra
    Just ordered the resistor from Superbrightleds should be here on the 14th fingers crossed
    2006Tundra likes this.
  17. Nov 12, 2022 at 7:45 PM
    Dragon daddy 1980
    Gary
    2003 Toyota tundra
    Resistor works lights look fu——- great
  18. Jan 20, 2023 at 8:50 AM
    Pronto13
    Pronto13 New Member
    ‘06 white DC SR5 V8/4wd
    Where did you mount it exactly? do you have pics?
  19. Jan 27, 2024 at 3:42 AM
    Shakapr
    Shakapr New Member
    Rafael
    Puerto Rico
    Tundra 2000 Limited
    Ordered the load resistor from SuperBrightleds and installed it yesterday, problem fix. It works great!!!
