Squeaking after sway bar install
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bentarm13, Oct 20, 2021.
  1. Oct 20, 2021 at 6:45 PM
    Bentarm13
    Bentarm13 [OP] New Member
    Anyone experienced this? All of the bolts are rock solid, torqued correctly. Double checked after 200 miles. Truck just seems to make noise exiting|entering at times.
    Pac12AfterDark likes this.
  2. Oct 20, 2021 at 6:54 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
  3. Oct 21, 2021 at 6:33 AM
    Bentarm13
  4. Oct 21, 2021 at 7:02 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Looks killer.. Congrats
  5. Oct 21, 2021 at 9:49 AM
    Dallas007
    Dallas007 New Member
    Dave
    2021 Tundra Pro Max
    Maybe it’s pure coincidence but could it be the squeaking skid plate issue? I started hearing squeak shortly after installing sway bar and re-torqued etc only to discover it was actually the skid plate. Did the fix on that and no more squeaking. Good luck!
  6. Oct 21, 2021 at 10:07 AM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Similar to a woman then, right?
  7. Oct 21, 2021 at 10:13 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Exiting / entering what?
    If a sharp incline or not so smooth road the sway bar could be putting the suspension in a bind.
  8. Oct 23, 2021 at 4:15 PM
    Bentarm13
    Hmmm, just had an oil change.. will check
  9. Oct 23, 2021 at 5:08 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    No I didn’t have this issue but have found a few odd squeaks that I’ve found over the last 3 years that it could be.
