  1. Oct 14, 2021 at 10:40 AM
    Iirc somebody recently redid their vacuum lines in the engine bay. Was there a kit for that, or does anyone else know?
  2. Oct 14, 2021 at 10:42 AM
    Strangebird22
    Strangebird22 New Member
    Terry
    Ohio
    2000 Tundra AC 4.7 4X4 SR5
    Not sure what I'm missing here, but on my 2000 AC the 19" blade on the drivers side goes to the top of the windshield. If I put a 24" on there it would go over the top of the cab by 2". It looks like most of you talking about this have later FGs. Is that the difference?
    CodyP[QUOTED] and Outbackrob like this.
  3. Oct 14, 2021 at 10:48 AM
    NWPirate
    Zach
    WA
    I remember that too.
    I thought they bought universal vacuum line because the oem lines were real pricey when you add them up.
    Jack McCarthy and FrenchToasty like this.
  4. Oct 14, 2021 at 10:58 AM
    Openbaffle
    Openbaffle New Member
    Does anyone know the torque specs on the bumper receiver bolts (the 17mm ones that a factory tow hitch would bolt onto). These are the bolts on the frame on either side.
  5. Oct 14, 2021 at 11:16 AM
    Mine are like yours as well, 19 inch.
    I suppose 24" would be possible but it would have to be offset from center to cover the lower area of the windshield. I'm not sure how you would do that.
  6. Oct 14, 2021 at 11:27 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    IIRC @CodyP has a DC and the windshields are different.
  7. Oct 14, 2021 at 1:30 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yep, I feel like your comparisons would be a 16” wiper for you guys to see what I was talking about. The 19” didn’t clean much of the windshield at all.
  8. Oct 14, 2021 at 2:22 PM
    You're thinking of me and Noah. I replaced most of mine with OEM lines. There is one that even McGeorge can't figure out. They sent the wrong part twice.
    @Tundra2 can probably tell you more about the kit he bought.
    NWPirate[QUOTED] likes this.
  9. Oct 14, 2021 at 2:44 PM
    Openbaffle
    Got this nicely buttoned up today. I think it looks pretty BA. A couple of things yet to do. Ended up drilling a small hole behind the license plate to run the cable for my backup camera. It looks pretty clean. Wiring up the license plate lights was relatively straightforward. I am going to try and find LED versions to match the rest of my lights. But yea, pretty happy, don't have to look at my dented bumper anymore and the chrome delete continues.
    HBTundra, TRDGen, ktundra and 9 others like this.
  10. Oct 14, 2021 at 2:47 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Buy or build? Looks great
  11. Oct 14, 2021 at 2:49 PM
    Openbaffle
    I bought this -- it's a Tough Country TB0325T. Just added these pics to the armor thread as well.
  12. Oct 14, 2021 at 5:00 PM
    alb1k
    Left Coast
    It's good
    I think a manual tubing bender for up to 2.5" .120 wall starts around $1600. Probably find a shop with a tubing bender and have them do it.
  13. Oct 14, 2021 at 9:03 PM
    YarbianTheBarbarian
    YarbianTheBarbarian New Member
    Ian
    Bloomington, IN
    '05 SR5 TRD 4x4 double cab
    None yet!
    Helped my buddy install my new Kenwood head unit and added a backing camera today. Gotta figure out the reverse signal wire though. We found the 2 wire with the backing signal and speed wire, but for some reason putting it in reverse still isn't activating the camera. The camera works with the button push though. It's possible we didn't get a good connection with just trying to jam the wire into the little plug, so maybe I just need to cut the wire and get a good splice?
  14. Oct 14, 2021 at 9:38 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Your truck not qualify for frame replacement?
  15. Oct 14, 2021 at 10:29 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    925 starting with 1 die for a RogueFab bender. Having a selection of Dies is expensive but benders arnt bad if you get use out of them. Hell RogueFab dies arnt even that bad compared to my JD2 model 32 dies.
    Its the Dimple Dies, big compressor, and all the other things you just HAVE to get after to complete projects thatll really get ya. It helps to have a supporting wife that also wants armor....
    FrenchToasty and oscardog86 like this.
  16. Oct 15, 2021 at 12:14 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    This is from a 2003
    Openbaffle[QUOTED] and des2mtn like this.
  17. Oct 15, 2021 at 12:22 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Told ya!
    RUSTYNUTS and FrenchToasty like this.
  18. Oct 15, 2021 at 12:24 AM
    empty_lord
    05 rollover special
    I still can’t find a local willing to do it. If you dont mind post how much you took off when your done. I want to say 2-3mm right?
  19. Oct 15, 2021 at 12:26 AM
    empty_lord
    05 rollover special
    Double cabs are physically taller and have taller windshields if I remember right
  20. Oct 15, 2021 at 3:14 AM
    Openbaffle
    This is exactly what I needed.
  21. Oct 15, 2021 at 4:27 AM
    Back in 2012-2013, it did not. Since that time the wonderful state of of Massachusetts decided to switch from regular salt to brine.
  22. Oct 15, 2021 at 5:42 AM
    I still haven't wired mine up yet, but to prepare for when I do, I saved the following links in my truck task list:
  23. Oct 15, 2021 at 6:44 AM
    YarbianTheBarbarian
    Ian
    Bloomington, IN
    None yet!
    Thanks! I read those threads and even may have found another comment by you with those links all together. I was able to locate that reverse signal up in the dash and would prefer to do that rather than tapping into a wire in the taillight. I was just hesitating to cut that nice stock plug off to make the junction. Probably just need to stop worrying about it!
    TRDGen and shifty`[QUOTED] like this.
  24. Oct 15, 2021 at 7:20 AM
    Is it not something you can Posi-tap? Posi-taps are the "sane" (far less intrusive) way to feed off a stock wire so no splicing is required. Just makes a small penetration in the sheath, versus the super-shitty way other clamp-lock systems use.
  25. Oct 15, 2021 at 9:35 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I replaced both upper ball joints last night with moog and I can't get one of them seated all the way. I had a breaker bar on the ball joint press and cranked until I physically couldn't any more and I still have a 3-4mm gap on the underside of the steering knuckle. Any ideas?
    They were both incredibly hard to get seated so I'm wondering if maybe OEM would be better.
  26. Oct 15, 2021 at 11:46 AM
    alb1k
    Left Coast
    It's good
    I'm guessing the 80-90 LB range, but honestly, I would just tighten those firm. Maybe someone will disagree, but a standard length 3/4" driver length and no breaker bar to a firm pull should be just fine.
    Openbaffle and FrenchToasty like this.
  27. Oct 15, 2021 at 12:13 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    I've seen others say 3.0mm and 3.2mm in the brake thread, mine appear to need 2.6-2.8mm.
  28. Oct 15, 2021 at 12:21 PM
    Mounted my gauge bracket. @Cummins3500 i barely notice the non covered grab hold hole. 599EC033-20A6-40FC-8975-F9266295440B.jpg03201049-F5AD-43CD-BF70-469D295417DE.jpg
  29. Oct 15, 2021 at 1:09 PM
    empty_lord
    05 rollover special
    Go cut a second set and send them my way for $$$ lol.
  30. Oct 15, 2021 at 1:14 PM
    Openbaffle
    Yea. Torqued to 75 lbs. and that started distorting the washers. So not sure. Maybe I need new 17mm washers, perhaps? I was able to level the bumper by just having the center bolt moderately tight and then jacking up the rear end.
    This is 1-week post suspension upgrade install including the extra weight of the new bumper. It looks pretty level to me, maybe still a little bit tall in front. We will see how much more it settles. May have to add another leaf in the back or replace the springs. I'm still leaning toward picking up a custom set of Alcans.IMG_6489.jpg
